Old 09-20-2013, 07:23 AM   #351
Roy 940
I was hoping you're joking, but it seems to not be the case... Damn, I've never seen a so unlucky guy in all my life!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 09-20-2013, 08:29 AM   #352
Steve T5R
Hey Roy, Krister needs some encouragement...
So let's hope that the engine did not get a damage cause of this.
@Krister: my 940tic has the mechanical van with the visco clutch. Last year the visco broke. But not as usual, what would mean a continously cooling, the silicone oil droped...I was driving half summer without the fan and received no damage until now. The temperature gauge didn't moved though. That's why I asked you.
Have a nice weekend,
Steffen
Steve T5R is offline   Reply With Quote
Old 09-20-2013, 09:27 AM   #353
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah but you do smogtesting while standing still... So no airflow to cooldown the water... It revved about 90secs at 3000 rpm and started to cook the **** out... :/ hope the head hasnt warped... .... Grml
Old 09-20-2013, 09:36 AM   #354
JohnMc
JohnMc's Avatar
As long as you didn't drive it with no coolant in it, a boil over is no big deal at all.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-20-2013, 09:53 AM   #355
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ha... That makes me calm down
So.. What the smogtest said is that CO is too high... Started with 1.987 and settled down to. 750 when the boilover occured...
Old 09-20-2013, 07:29 PM   #356
Roy 940
Good luck! Don't give up!!!
Old 11-07-2013, 09:20 AM   #357
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Megasquirt or not.... this is the question..
If.. it will be MS3x with every bit of it like Seq. Injection and Ignition Because i can
First item arrived..
One question.. is that Block removeable which reads the mitsu logo and 1Z10? i can see 4 pins when i bend it a bit.. but it doesn't look like its made to be removable ;)
Old 11-18-2013, 07:01 AM   #358
Steve T5R
any further news regardings the issues you had?
Steve
Old 11-18-2013, 07:17 AM   #359
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
No signs of the pistons hitting the valves again.. i think it was the totally broken valve guides which caused this.. pity for the SPM Valves...
but no news.. last action was that boilover thingy... i feel like.. **** you against the car right now
Need a new Cat though... CO value was way too slow in green area...
Old 01-02-2014, 08:19 AM   #360
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
MS3X loom ordered...
Old 01-03-2014, 09:15 AM   #361
Roy 940
When your car'll be back on the road?
Old 01-03-2014, 10:20 AM   #362
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
It can at any time and wasnt yet ;)
I will do the swap over the year but wont cut the original harness out...
Old 01-03-2014, 10:45 AM   #363
JohnMc
JohnMc's Avatar
Probably *way* late to answer this - but not, that block doesn't come off. You can remove the screws and *very* gently bend it upward to provide clearance to swap the trigger disc if you got a hi-def replacement, but bend it too far and you'll break the soldered in contacts.
Old 01-03-2014, 11:16 AM   #364
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thx john... I thought something like this
Old 03-10-2014, 04:44 AM   #365
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
took it for a ride last days.. wow.. makes fun to drive.. but seems i need to get that MS3x in there real quick.. the tune i have in LH still seems inappropiate for a dyno.. dies from time to time when falling back in idle.. having troubles getting in loadmode... stuttering while accelerating from part load from low rpm ranges, rly lean conditions while on half throttle but boost...
Oh and the AMM stalls at 5500rpm.. you're biting in the steeringwheel when that happens.. fuelcut..
Pic of it with "rote nummern" ;)
Old 03-10-2014, 08:43 AM   #366
okoye
okoye's Avatar
So what computers are you running? a normal 8v turbo computer? or 16v turbo computers?
Old 03-10-2014, 08:52 AM   #367
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
lh2.4 with modified 16v N/A and 8v turbo software... "ostriched"
Old 03-10-2014, 09:08 AM   #368
okoye
okoye's Avatar
anymore info, or an explanation?
Old 03-10-2014, 09:24 AM   #369
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
on what?
I'm using a 977 (newest/fastest ECU without Immo) together with a 219 Goldbox..
Loaded the 3L AMM Maps into the bin and merged the 16v ign tables to the 8v board... to get a "16v turbo ECU" the rest is fiddling with details which cannot be explained.. tuning****.. .. Danger to the Manifold and so on... ;)
Old 05-22-2014, 04:57 AM   #370
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. i think this Project comes to an end now...
I Headed to the guys who wanted to get me TüV and smogtested and they told me some regularities changed in germany since my last visit, which makes it nearly impossible for me to realize this thing roadlegal.. this really sucks and i don't know what to do now...
If it stops the 16V will get into my Racecar.. there are some T5 Conversions Roadlegal where i can get a homologation from.. we'll see..
Man... Germany sometimes sucks big time.. :(
Old 05-22-2014, 12:45 PM   #371
Råda
Volvoretard/Partshoarder
Råda's Avatar
Too bad :( What's the problem?
Jonas
Old 05-22-2014, 03:54 PM   #372
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
The problem is that i now need the car officially exhaustlicensed? Like i am a car manufacturer builds a new car... Instead of just being smogtested... This unfortunately costs big money... About 3000€
Why? Because my car is newer that 01.10.1989 and german smoglaws are crap.. More ****tier than florida..
Old 05-23-2014, 05:33 PM   #373
Roy 940
Damn! That sucks!
Old 05-24-2014, 05:14 AM   #374
Råda
Råda's Avatar
Sucks, but to be fair this engine could only be approved in a 1975 or older here
Old 05-24-2014, 06:05 AM   #375
Turbosteen
I was born at a young age
Turbosteen's Avatar
Move to The Netherlands, cars before 1995 (or something) can have any engine you want haha
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
