DET17
Reformed SAABaholic
- Nov 1, 2009
- NW Georgia
Rather than list it all again, here is my post in the "how to" article stating what I did, and what doesn't work:
http://forums.turbobricks.com/showpost.php?p=4963975&postcount=192
I went the Bosch Motorsport 2x2 coil and the 203 Bosch ignition module route, so I'm looking for suggestions from folks that went that road as well (not the Mitsu/Miata setup route) and who have the expected performance.
Seems to idle pretty well, although timing looked a little fast when I checked it; however that was after the car threw a CEL so perhaps the timing I saw then was normal for LIMP mode.
Since I've got idle, I'm going to presume the problem is in my primary and secondary side of my coils. The behavior is like classic "weak spark"....enough with little load, but as soon as you raise the engine RPM and load, it bucks & shudders. I've seen this before when primary side of the coil (wiring or current supplied) was deficient. The BOSCH catalog says that the 2x2 coil should see 7~8A max. on the primary side of the coils.
I believe Karl's board is working fine....he explained that all he did was separate the signals which originally went to the 124 ignition module transistor. Since it idles, the input side must be AOK. As I stated in the listed post, I've tried a pair of Bosch 407 coils, pair of 203 ignition modules, a pair of plug wires sets (well running current set and new BOGI's), ohmed out all the wiring which was triple checked (by 2 persons) and also AOK.
My experience is telling me that I'm not getting adequate primary coil saturation (either current or dwell, maybe both), but I'm looking for the cause & remedy.
Thanks TBers.
Thanks TBers.
