Old 05-21-2013, 09:32 PM   #1
mblue240
mblue240's Avatar
Default Double D
This is my new DD, so the current DD can be turned into a weekend car. The 242 was parked in the garage 13 years ago when a new car was bought, then never touched again. The windows were left open and all sort of dust and rodents got inside. There is also dust and rodent crap all over the roof of the car. The tires went flat, the gas turned bad, and she desperately needed love. I learned the car was in my neighbors garage 3 years ago, when my Dad bought a 1968 144S from him. For 3 years I kept hearing how he wanted my help to get it on the road so he could drive it again and I never pushed the issue, but he knew I wanted to buy it. After the stars aligned he realized he wasn't getting any younger and the car needed a new owner. We struck a deal and it was towed to my garage.
So far I've replaced the rear lights, front turn signals, all the belts, polished the valve cover a little, installed a K&N air filter, new plugs and wires, and a bunch of other crap that adds up to way too many weekends. At this point it should be running this weekend. Then I'll replace the brake calipers, pads, rotors, fluid, and lines. I'll also drain the differential and put in new fluid. Then I'll just need to pull out the interior and scrub everything down and it will be ready for duty.
A "before" shot of the engine bay
The battery cables were so corroded I couldn't loosen them, so I cut them off at the terminals.
A mess of zipties in the trans coolant lines.
The old tails. Good, but not great.
Sparkly new tail lights.
This is the cover for the muffler. The top one came off the car, the bottom one went on after I coated it with bedliner.
Old turn signal on the top, new on the bottom.
Old on the left, new on the right.
I think the end link bushings are shot.
A progress shot of the engine bay.
Pulled an old set of 25/22mm IPD sways out of the shed (still need to put the water pump pulley on)
That mess of zipties was replaces with new hoses and a single ziptie put on correctly.
-Michael
Tbricks build
Yep, Michael is right.
Old 05-21-2013, 11:28 PM   #2
Josh
WHITEGOLDTEETHNOFLOSS
So now there is like 10 of these cars driving around portland
Instagram: josh_keck
Josh is offline   Reply With Quote
Old 05-30-2013, 10:07 PM   #3
mblue240
mblue240's Avatar
"I'm not going to modify this car." - Me
Didn't take long to change my mind.
Old 06-01-2013, 05:26 AM   #4
diponyou
diponyou's Avatar
you were doing it before it was cool that is all that matters in the grand scheme of things.
Brandon B.
1993 240+T ms2v3, 96#s, e85, T5
1984 242ti Hi-Comp b23 N/A, m46. Work in progress
93's Build Threadhttp://forums.turbobricks.com/showthread.php?t=264885
84 242 Hi-Comp N/A Build Thread
http://forums.turbobricks.com/showthread.php?t=290023
diponyou is offline   Reply With Quote
Old 06-01-2013, 10:48 AM   #5
slow240
Home Schooled
slow240's Avatar
Originally Posted by diponyou View Post
you were doing whatever made you happy, that is all that matters in the grand scheme of things.
ftfy
242 looks good! keep her up, looks pretty rust free
I'll polish your face
'90 244. blue, tall, ghetto, fabulous.
http://forums.turbobricks.com/showthread.php?t=310740
Old 06-01-2013, 03:47 PM   #6
Old Iron
I Roll
Old Iron's Avatar
Nice find, lucky it sat in a garage and not under a tree collecting rust holes. Rat **** is better then rust holes any day.
Turbobricked
Old 06-02-2013, 02:59 PM   #7
swedishmafia!
swedishmafia!'s Avatar
Where is this mysterious blue 240 mine in Portland? I must find the source.
1991 245-Medium Beige
M47
A cammed
swedishmafia! is offline   Reply With Quote
Old 06-03-2013, 03:04 AM   #8
Pro Sneaker Peddler
This would make a much better weekend car than the 89...
Old 06-05-2013, 01:19 PM   #9
mblue240
mblue240's Avatar
I haven't found any rust yet, but sitting in the driveway wouldn't have changed that. The 68 144S we pulled from the PO's driveway 3 years ago (yes, we bought both cars from the same guy) is my Dad's weekend driver and its just about rust free.
Nope, the 244 already sucks too much gas. Swapping go fast parts from the 244 to the 242 and returning the 244 back to stock would take way too much effort. A 242 is a great DD for me, since my long legs make it so when I look left out the 244 I'm actually looking out the back window. Plus, I've always wanted to DD a car thats older than me.
By the end of summer this car will be at stage 0 and I am going to spend a lot more time on the 142. I've let it sit too long and its about time I show it how much I love it, and the boy is begging to go for a ride in it.
Old 01-16-2015, 09:59 AM   #10
mblue240
mblue240's Avatar
A year and a half in and it still isn't running. I blame 60+ hour work weeks keeping me out of the garage. It has a new windshield now, most of the interior is back in, front armrest, turbo triple gauge pack, and power mirrors waiting to go in.
The no start issue seems to be the in tank pump. Pulled that and found a pile of rust, looking in the tank showed even more rust.
Grabbed a rust free tank from RSI, but it was dented. The dent kept the pump from being able to drop in. I beat a piece of wood into the dent with a hammer and just splintered the wood, so I got creative in my fix.
Old 02-19-2015, 02:11 AM   #11
mblue240
mblue240's Avatar
The gas tank is in, just waiting for new gas lines to ship now. Got the new rollers on though. The black virgos have 2 good tires, so I'll have to find two more before I can really put on miles.
Old 02-19-2015, 02:19 AM   #12
Pro Sneaker Peddler
Eli is your man.
Old 02-20-2015, 04:02 AM   #13
mblue240
mblue240's Avatar
Old 04-29-2016, 07:15 AM   #14
mblue240
mblue240's Avatar
It is painful to think I've owned this car for nearly three years and haven't put a single mile on it. Life has gotten in the way and this sat way on the back burner. The car runs and drives (in and out of the driveway), I just need to put the interior back together, smog it, and buy insurance.
20160427_153106[1] by M. Blue 240, on Flickr
Old 04-29-2016, 07:43 AM   #15
RP80242GT+T
R-Sport Cluster Guy
RP80242GT+T's Avatar
I really thought this was going to be a thread on big boobs.
RP R-Sport and OEM Stock Instrument Cluster Restorations, Sales, parts, service, and customizing. LED Conversion Services
Volvo GT Stripe Kits.
1980 242 GT Turbo
2006 Mini Cooper S GP number 1148
1989 240 Wagon " The Beast" Daily Driver
RP80242GT+T is offline   Reply With Quote
Old 04-30-2016, 03:51 AM   #16
mblue240
mblue240's Avatar
My wife thought I was writing about her, then pointed out the last pregnancy pushed her past a DD. (pics won't happen, I've seen the TB hounds in action)
Old 06-10-2016, 06:48 AM   #17
mblue240
mblue240's Avatar
She drives! We drove it around the block on Wednesday and it went pretty smooth, so we insured it Thursday and I ran a couple errands.
My notes after the first drive (more so I can remember):
-still needs a driver's seat belt
-defrost vents seem to be plugged
-might be dragging the front right brake
-I'm using the driver's seat out of my 89, still need to button up the original seat
-there are no front turn signals
-hazard switch doesn't do anything
-setting up the stereo in the lower slot, while you drive, is impossible
-center lights of the quad rounds seem to glow when the headlights are on
-needs a belly pan
I love this thing though. It glides over speed bumps and the only exhaust note is from the hole in the muffler. I can't wait to take care of the little things so I can DD this.
Old 06-10-2016, 09:06 AM   #18
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Ha! I literally just did this last night at 945 trying to make it to Coldstone before they closed!
Nice ride, it'll be a great daily.
Uncleknucklez is online now   Reply With Quote
Old 06-16-2016, 08:33 AM   #19
mblue240
mblue240's Avatar
Added to the to-do list:
-replace wiper motor
-fix gas leak between tank and filler neck
Old 06-16-2016, 04:21 PM   #20
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Headlamps: 4x6 harness is wired differently than 5.75" round and 7" round. Same thing happens if E-code 4x6's are installed without repinning the harness plugs or using the adapters.
Wiper motor: Get an SWF unit (Nahnstört band on motor housing). Can swap brown and green wires for faster intermittent mode without having it turn into a 1/2 second delay, like what happens with the newer Electrolux motors.
-J
Old 06-16-2016, 08:11 PM   #21
LC4CARL
Aero challenged
LC4CARL's Avatar
-J
My wipers don't "park" on the cowl when switched off. Ideas?
Clean 242 by the way!
Life begins at 10PSI.
Old 06-17-2016, 08:47 AM   #22
mblue240
mblue240's Avatar
-J
I was hoping you would chime in. I was sure you had experience with the lights. What all do I have to do to get them to work right?
I have a small stack of spare wiper motors, so that will be the easiest repair on the list.
Old 09-07-2018, 01:43 AM   #23
mblue240
mblue240's Avatar
Something got in my head and I decided now was the time to tackle the suspension. It already has IPD sways, now I'm adding IPD springs, Bilstein TC, new rubber bushings everywhere except the trailing arms (those will come later), strut reinforcement plates, and later model vented brakes.
20180827_101028 by M. Blue 240, on Flickr
20180827_104523 by M. Blue 240, on Flickr
I'm also tracking down an oil leak, brake fluid leak, and coolant leak. While I wait for parts to come back from the powder coater I started looking into the leaks. First thing I found was a line that may have been attacked by the mice that got to this car while it was in storage. It runs from the fuel tank to the charcoal canister, so I'll need to find a replacement.
20180906_165716 by M. Blue 240, on Flickr
The brake fluid seems to be leaking from the hard lines that run to the rear of the car, just a couple inches back from the distribution block. I'll need to find a replacement for that too. The coolant seems to be from the hard heater hose that runs back from the water pump, but I need to look again to be sure. Lastly the oil is likely the front crank seal, thankfully I have spares on hand. I tore into it tonight, but I'm going to try to add some parts to my powder order.
20180906_213214 by M. Blue 240, on Flickr
Old 10-22-2018, 11:58 AM   #24
mblue240
mblue240's Avatar
242 by M. Blue 240, on Flickr
243 by M. Blue 240, on Flickr
