Old 10-09-2018, 06:43 AM   #1
BBR745T
Default 745T endurance racer: WHEELS
Im building a 745T for endurance racing and Im trying figure out the best wheel and tire combination. The race organizers will allow brake calipers to be swapped for a minimal fine. With that in mind Im thinking of running 16 inch wheels. 17 rims are another option but it would have too much of a negative impact on the cars gearing.
-Can anyone recommend a 16 inch wheel with a 5x108 bolt pattern?
-How wide can one go with the tires (225 or 245)?
BBR745T is offline   Reply With Quote
Old 10-09-2018, 11:35 AM   #2
5 (five) NIP IPD Pegs Hyper Silver 7.5 x 17 RWD 20mm NEVER OPENED BRAND NEW CONDITION
http://forums.turbobricks.com/attach...1&d=1538602315
Old 10-09-2018, 11:41 AM   #3
225 50 16 with a 16x8 is a good combo for a enduro.
Not many 245 choices in 16" if you want more options go to 17"
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.
Old 10-09-2018, 01:04 PM   #4
Stiggy Pop
Stiggy Pop's Avatar
I love pegs
I have money
I have a car that really needs wheels
Ain't nobody paying $1250 for pegs, no matter how new they are
'79 242
943 pickup
Old 10-09-2018, 01:51 PM   #5
Pro Sneaker Peddler
This. That said, for endurance racing (I'm assuming lemons racing based on OPs restrictions) a 225 with decent compound should be plenty.
You are spoiled for choice when it comes to 200 rated tires, and wheels can be had for not terrible money.
tires: https://www.tirerack.com/tires/TireS...earDiameter=17
Old 10-09-2018, 02:00 PM   #6
Originally Posted by Stiggy Pop View Post
I love pegs
I have money
Ya but he's saying he's going racing so he has the monies, unlike the rest of you clowns.
Old 10-09-2018, 02:18 PM   #7
Jack
Banned
Jack's Avatar
but race car drivers have no monies - ask any of their wives
Old 10-09-2018, 02:20 PM   #8
300+hp on the shelf club
Team Dynamics wheels are light and reasonably priced for a performance wheel that actually gives you some performance. https://www.rimstock.com
I had a set of the 15 x 7 wheels and they were only 14lbs IIRC.
Old 10-09-2018, 02:23 PM   #9
Priorities man priorities ...
Old 10-09-2018, 02:37 PM   #10
https://www.bneshop.com/collections/...ker-classic-e1
Old 10-09-2018, 02:47 PM   #11
JW240
All idiot, no savant
JW240's Avatar
Those pegs are heavy.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 10-09-2018, 05:17 PM   #12
towerymt
the real Towery
towerymt's Avatar
I can sell you a rough set of 16x7.5 TSW wheels if you want cheap 16"s that are wider than what's commonly available.
http://www.pbase.com/towerymt/image/149708861.jpg
http://www.pbase.com/towerymt/image/138710801.jpg
We used them on our lemons car with 225/50/16.
We then switched to 16x8.5 & 16x9.5 Corvette C4 wheels w/wheel adapters. A bit heavier, looks cool, and stretching a street tire a little bit helps grip / stability / response. Not a huge difference, but a 225 on even a 7.5" is pinched slightly. 9" would be my preference for racing, but even 16x8 will be uncommon to find for RWD offset & 5x108.
Old 10-09-2018, 06:14 PM   #13
Pro Sneaker Peddler
Last time I checked, ESM did a decent 16x8 that bolts into a RWD Volvo.
Old 10-10-2018, 11:11 AM   #14
Stiggy Pop
Stiggy Pop's Avatar
A bit of a needle but Ferrari 308 Epsilon 3-pc check all the boxes: light weight, 5x108, don't require spacers, avalable in 16x8+
Old 10-10-2018, 04:35 PM   #15
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
This!
OR get some spacers from IPD and place late model 17s on there. Easy and cheap. 225/45/17 tires are very common and sticky meats are available.
#79WDP
Old 10-10-2018, 07:48 PM   #16
DrZiplok
DrZiplok's Avatar
Motegi MR131s (17x8) are cheap (though the adapters you will need make them less so), light, so far we haven't been able to break them, and 245/40R17 is the sweet spot in terms of rubber for your dollar. Only bad side so far is that our tire guy hasn't been able to make weights stick to them...
Previously we ran 16" Vxx MGAs, which are also cheap and durable (get them off eBay) , and you can get Direzzas in 225/45R16 so the tire problem is solved. If I hadn't already offered our old stock to another racer here I'd have made you a deal.
(Won't be Lemons or Lucky Dog; brakes/wheels/tires are 'free' and they don't do fines. Ditto AER though I don't expect a fresh 745T would be competitive enough to be accepted. Chump will dock you points, so maybe those guys?)
DrZiplok is offline   Reply With Quote
Old 10-11-2018, 10:49 AM   #17
It's a poor design, they're all heavy because of the way the rim is supported by the spokes.
Old 10-11-2018, 04:14 PM   #18
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
It's a poor and dated design, they're all heavy because of the way the rim is supported by the spokes. IPD reps BNIB or not will not carry that price premium when glamorous deep lip Eikers are available new for a lower cost.
FTFY
Old 10-12-2018, 08:24 AM   #19
BBR745T
ChumpCar (I hate the name change to ChampCar).
I plan to install lung studs and buy light weight spacers.
Thanks for all the suggestions.
17 inch wheel considerations (I’ve run both of these brands)
Konig Hypergram 17x8 (16.3#), $154 each
Advanti Storm SI 17x8 (17.8#), $214 each
