Old 08-17-2018, 04:21 AM   #1
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Default B234F TwinTurbo Concept
Heyho fellow TBrickers
I have two more or less mint condition 13c laying around.. did one of you ever consider to make a TwinTurbo concept out of it? I can remember a green 242 which had this.. but i cant find it anymore..
Old 08-17-2018, 04:50 AM   #2
TurboDenny
Why am I here?
Twin Turbo Thread
Only one I've seen moving under it's own power is a factory twin turbo 2jz swap
Instagram: @itstotesdenny
Old 08-17-2018, 06:46 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
damn.. i found this thread by myself 10 secs ago ;)
thx anyway..
Old 08-17-2018, 09:35 AM   #4
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Twin turbos makes Doug angry
Hello My Glorious!
Old 08-17-2018, 12:49 PM   #5
EivlEvo
The twin turbo thing typically seems to go down the road of... why?
To be clear. I am 100% on board with doing ridiculous things and could answer the why with "because" but I digress.
I would say that people would shy away from the TT setups simply because they're "excessively complex" but more importantly they're less optimal than simply running a modern single turbo setup.
Still. Who cares? I say do it! But it'll probably cost you more than just buying a legit single turbo.
Old 08-17-2018, 02:36 PM   #6
Duder
His Dudeness, El Duderino
Duder's Avatar
There are some compelling arguments for twin turbos on a 4-cylinder when you compare the setup to running a single twin-scroll turbo. It should theoretically let you tune the turbine housing A/R precisely on each of the smaller mono-scroll turbines. If done right it could offer better power and response vs. a single twin-scroll turbo with a single compressor that performed comparably to 2x the smaller units. Mass and complexity are always going to count against twin turbos, but it's not a ridiculous idea.
Old 08-17-2018, 06:28 PM   #7
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I’m glad this is still a thing
Old 08-17-2018, 06:29 PM   #8
A tough rowing ho
Didn't the rx7s run 2 tiny turbos?
Old 08-17-2018, 06:30 PM   #9
Stiggy Pop
Stiggy Pop's Avatar
the juice isn't worth the squeeze
'79 242
943 pickup
Old 08-17-2018, 06:41 PM   #10
naterhater
naterhater's Avatar
The only real advantage is this would turn more heads at a car show. There isn't any practical reason why you need two equally sized units functioning in parallel to perform the desired work, if anything you're probably sacrificing the gains by adding weight and complexity. There also isn't any reason to run compound turboys for any boost setting under 35psi.
"It's probably fine!"
"If you find yourself doing it a second time, do it right this time"
'93 940 Turbo thread:
http://forums.turbobricks.com/showthread.php?t=288116
naterhater is offline   Reply With Quote
Old 08-20-2018, 02:06 AM   #11
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
To be more serious on this.. i could think of 2 13c are way too big for a responsive 400hp config? Should have quite much lag until 2900-3100rpm?
Old 08-20-2018, 07:01 AM   #12
JerryJS8
der Junge
JerryJS8's Avatar
http://turbochargerspecs.blogspot.co...48-200-hp.html
Get two of those, rig them up sequentially and you got yourself a plan for 400hp
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 08-20-2018, 08:26 AM   #13
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
they look sh1te :D
Old 08-20-2018, 08:51 AM   #14
M.H. Yount
M.H. Yount's Avatar
Go for it.
https://www.youtube.com/watch?v=xUXA1SIqJFY
Old 08-20-2018, 08:54 AM   #15
centason
Knipex=welfare queen
centason's Avatar
Could always
Member: TBCCS
"Democracy is the art and science of running the circus from the monkey cage. Democracy is a pathetic belief in the collective wisdom of individual ignorance." -H. L. Mencken
Old 08-20-2018, 12:33 PM   #16
John V, outside agitator
There are some compelling arguments for twin turbos on a 4-cylinder when you compare the setup to running a single twin-scroll turbo. It should theoretically let you tune the turbine housing A/R precisely on each of the smaller mono-scroll turbines. If done right it could offer better power and response vs. a single twin-scroll turbo with a single compressor that performed comparably to 2x the smaller units. Mass and complexity are always going to count against twin turbos, but it's not a ridiculous idea and just because even the few OEM twin turbo set ups on cars never work correctly that shouldn't deter anybody because those OEM applications didn't have the benefit of all the knowledge of the whole Intra-webz...
4 would still be better...Go big or go home.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-20-2018, 02:25 PM   #17
Duder
Duder's Avatar
People are throwing in "sequential" and series/compound turbo systems into this discussion...yeah, that's not what the OP is asking about.
Probably worth clarifying some terminology.
  • Twin: two identical turbos in parallel
  • Series: two differently-sized turbos, one feeding the other. The larger turbo is the LP (low pressure) and feeds the smaller turbo (HP) on the compressor side. On the exhaust side, the small turbine feeds the larger one. Sometimes called "compound" setup, but that's actually something else (see below).
  • Sequential: can be parallel or series. Indicates that there is staged control of airflow, i.e. one turbo handles all of the flow at low engine speeds and the other is brought in to help at higher speeds...in sequence. Implies a change over time.
  • Turbocompounding: geared connection between turbine and engine crankshaft. Converts exhaust energy back into mechanical shaft power to the crankshaft of the engine. Like an inverse supercharger.
Old 08-21-2018, 02:02 AM   #18
JerryJS8
der Junge
JerryJS8's Avatar
Krister is just bench racing again...
But he was talking about using a couple of spare mint condition 13c turbochargers to accomplish two things:
A: 400 hp
B: a responsive 400 hp
As I see it, either we change turbos to make A and B happen, or we keep the turbos and change the configuration. But if he's going to go through the hassle, 13c turbochargers aren't sexy, so why bother?
@Duder
Thoughts?
@Krister
Thoughts?
@JohnV
Du verrücktes Huhn!
Old 08-21-2018, 03:07 AM   #19
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. it is benchracing.. it would be more for the looks but also it is a cool challenge fo myself to get that kinda setup going ;) And i have these 13c here... so everything which goes in different directions is nono cause i dont buy other turbos just because.
In the end it would be best if i spent some money for a BorgWarner EFR ;)
BTT! That setup in that picture.. wtf is wrong with that wastegate config? At first it points backward from the flow, and second: it is hyperliquid cause the hotsides got their own wastegates and they should be capable of handling the half amount of exhaustgases??
Old 08-21-2018, 03:42 AM   #20
JerryJS8
der Junge
JerryJS8's Avatar
Well if you're thinking new turbos...
Here's a t3 twin scroll manifold for your B234F
And maybe not an EFR, a Holset would also be fitting
Old 08-21-2018, 06:26 AM   #21
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Whoa.. that 3d model is very nice.. compact!
And yes.. since i cant afford EFRs.. it will be a holset hx35II with water from TZB.. BW 200sxe also is an option, but too big..
Old 08-22-2018, 08:54 AM   #22
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
https://www.autoevolution.com/news/v...15.html#agal_0
Btw.. Volvo stole my idea.. 5 years ago.. ;)
Old 08-22-2018, 10:55 AM   #23
CAPT_BLOTTO
#Crush It
Wasn't there a picture that went along with it?
Old 08-22-2018, 11:44 AM   #24
240240
Solely ruined TB
240240's Avatar
Or just do 8 turbos like real man
Old 08-22-2018, 12:18 PM   #25
Vincent Gagnon
Vincent Gagnon's Avatar
