Jack
junkman
- Jul 7, 2011
- The Ass Cheek Of History
any advantage in using a Mallroy unilte dizzy on a B18/b20 vs stock other than bling and no points ?
Thanks
Jack
Thanks
Jack
While I do have ms setup and yoshis stuff. I think the b18/b20 beauty comes from KISS.It used to be bling, nowadays doesn't even wiggle the needle on the bling meter.
Max bling is a crank trigger or,
Get a Yoshi Fab CAS adapter and a VW coil and do wasted spark. Ooops you'll need a few more parts unless you inject it.
The single coil of a distributor ignition limits the amount of spark energy you can put across the plug gap.
Looks like you already have the Mallory distributor, so your best avenue is to get a Mallory CD box or a MSD to fire a matching hot coil.
I'm using an old Mallory dual point distributor body on my PV's motor. It has more adjustability in the advance curve. You can move the weights on the arms, and (IIRC) move where the springs attach.
Still not enough total advance for the way my motor works, though. I have to balance it between retarding it some to enhance low RPM torque and advancing it some to enhance high RPM power.
Where does one acquire a match book cover nowadays?
They're usually on a matchbook.
