Hi all, new here,
Ive been following this post for some time now. In light of the recent talk of 97'GLTs ive decided to post some of my plans, so please give me what advice you have.
Being in college Ive never had enough money to actually do what you were talking about though, but I took it upon myself to research my options so i could upgrade if i gathered enough cash.
Im taking some time off from college (a degree in medicine is a loooong journy, i want to make d*mn sure that its what i want to do before i head into 8more years of school) and I should have enough money due to a new job (though i dont like to count my chickens before they hatch....excuse the lame idiom). I came across a kit at ATPturbo.com for $1995.00 that includes the following:
Stage II Turbo Upgrade Kit with Garrett Turbocharger (GT or T series), Wastegate, Blow-Off Valve, and all installation hardware; i.e. flanges, adapters, fittings, steel braided lines, and coolant lines and fittings.
They said to expect the following:
Garrett GT or T-Series Turbocharger
? Improved Wastegate Design for stable boost
? Larger Compressor to support up to 400HP
? CNC Custom Components for ease of installation
? Stock Downpipe and Manifold
? Larger Injectors
? Blow-Off Valve
Is this a good deal?
I plan to replace the stock 97' 850GLT engine with that of either a 850R or T-5 of the same year (if at all possible....would it fit? idiot newbie question, i know) to avoid any issues with the higher boost on the thinner cylinder walls.
Im also going to take your advice on replacing the transmission, so i plan to drop the auto gearbox and replace it with the kit you recomended (M56H kit via Bill at adrenalineracing). I plan to put in a new cat-back exhaust system, replace all the tubing with the higher strength silicon, upgrade the downpipe, and also upgrade to 17" wheels (nothing rediculous though....NO CHROME).
Ive already replaced the intake kit with a C/A intake (via eurosporttuning) and have a ECU upgrade ready to purchase at eurosporttuning as well. Ive done what i can to replace the stage zero components: Ive replaced the spark plugs and wires, tested compression and replaced rack and pinion system (nasty leak for a while, had to fill the power steering fluid like every 2days) as well as replacing a cracked boot joint in the front right. Oil seems to be fine, as well as most of the tubing in the engine bay. I still need to replace the vacuum lines and the distributor cap and rotor.
tell me if im missing anything or if i need to consider anything else
PS
Something thats really important to me is to keep the car looking relatively stock. The most i would do to alter its appearance would be to tint the windows or get more defined 6 spoke rims.
I like the way it looks (Fire engine red with stock spoiler).
