Old 05-08-2019, 10:43 AM   #1
gj940
gj940's Avatar
Default IPD HD CBV spring replacement
I'm embarred asking this but I just bought IPD's heavy duty CBV.
There already was a spring in the CBV but how can I get it out to replace it with a heavier spring? There are 3 options so im assuming its changeable.
Help is much appreciated
http://europeantuning.luondo.nl/en/1...r-bypass-valve
Dutch 940 LPT on BBS
gj940 is offline   Reply With Quote
Old 05-08-2019, 04:32 PM   #2
Fa182
Stage 1
Fa182's Avatar
Just remove the CBV - 3 bolts. The spring is inside the CBV pushing the diaphragm against the turbo. Is there something that I'm missing from your question?
He removes the the CBV in this video, the spring is inside the cover he is taking off.
Old 05-09-2019, 05:51 AM   #3
gj940
gj940's Avatar
Thanks for your reply.
Maybe I should be more specific: Indeed it's easy to take off the metal cap from the turbo but that's not the issue. The IPD set comes with 3 springs which you can install between two plastic parts that click into each other. Mine already had a spring installed from the manufacturer which I want to replace by the blue (heavier) spring. I can't find anywhere how you can detach the two plastic parts to change the springs.
Does anybody have an idea?
Old 05-09-2019, 06:21 AM   #4
Fa182
Stage 1
Fa182's Avatar
Ah, now I get it.
Here are IPD's installation from their website if it helps: https://www.ipdusa.com/files/product...LL%20GUIDE.PDF
Looks like the 2 parts just snap together? Maybe someone has the item and can chime in here.
Old 05-09-2019, 10:14 AM   #5
gj940
gj940's Avatar
Yep, I found this installation vid as well, now I would like to know how to take it apart again.
Old 05-09-2019, 10:59 AM   #6
ovlov760
ovlov760's Avatar
Can't they just be gently pulled apart?
Old 05-09-2019, 12:47 PM   #7
gj940
gj940's Avatar
Tried that for about 2 hours, until I was seriously worried breaking it. Anybody any experience?
Old 05-09-2019, 01:03 PM   #8
ovlov760
ovlov760's Avatar
That was my experience with the kit provided for P80 cars. Maybe I also used pliars to squeeze the little tabs a bit.
Old 08-05-2019, 02:56 AM   #9
4gone
Default Hey I got the same kit, and same prob!
It's actually pretty easy to separate, I poked some tweezers inside the hole and squeezed the center plastic pin while wiggling.
I guess that would be obvious if you were the one who clipped it together :<
4gone is offline   Reply With Quote
