Old 07-16-2019, 02:36 PM   #1
twowheeledlife
Default LH2.2 into an LH2.4 Car - Whats Needed?
Hey everyone, I looked through the forums and couldn't quite find my question so here's another LH2.2/LH2.4 thread.
I have a 93 240 n/a with an AW71 which I'd like to replace with a B230FT from an 88 740. I had originally planned on keeping it LH2.2 from the 740, but the more I've looked into it, the more it seems that the head mounted distributor from the 740's B230FT wont fit properly in the 240's bay. If I swap the FT into the 240, will I have to remove the head mounted dizzy, plug it's hole, and add a block mounted dizzy? If so, since the 240 is already LH2.4 would it make more sense to get a new (to me) turbo LH2.4 ignition? If I were to go this route would my MAF and other sensors still work properly/migrate over to the older turbo motor?
Thanks in advance!
twowheeledlife is offline   Reply With Quote
Old 07-16-2019, 02:41 PM   #2
iHateVolvoPeople
Put the 2.4 sensors on the 2.2 engine. Swap over crank sensor bracket (and crank sensor obviously). You’ll need lh2.4 turbo computers that take direct place of your lh2.4 na computers.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 07-16-2019, 02:45 PM   #3
twowheeledlife
So the CPS bracket and CPS will take place of the Hall sensor, correct Would the MAF sensor from the 2.2 work for the 2.4 or do I use my current 2.4 MAF sensor?
Old 07-16-2019, 04:11 PM   #4
iHateVolvoPeople
Use alllll the 2.4 parts, including the 2.4 maf. Nothing 2.2 related is used, except i think you can use the stock 2.2 distributor, but the Hall effect sensor remains unplugged and un-used. It would be a different story if using a 2.4 engine in a 2.2 car. If that were the case youíd have to use a 2.2 dist with Hall effect sensor.
And yes the CPS bracket is held to the 12 oíclock position of the back of the block via 2 10mm bolts. Remove, and install on new 2.2 engine. Itís worth noting that the really early blocks werenít drilled and tapped for the CPS bracket, but an engine from 88 will be so youíre lucky there!
Old 07-16-2019, 04:21 PM   #5
twowheeledlife
Sounds like my luck might be turning around finally! For the LH2.4 turbo ECU's are there multiple models, one I should look for or avoid, or is it one size fits all? Also since I'll be able to use LH2.4 I'll try the wasted spark upgrade instead of a coil/distributor.
Old 07-16-2019, 04:21 PM   #6
iHateVolvoPeople
So technically the CPS and bracket don’t take physical place of the Hall effect sensor, but they essentially serve the same purpose. 2.4 cars did not use a Hall effect sensor in the distributor, they used a crank sensor (and bracket) on the bell housing area of the block. If you re use the 2.2 dist, just leave the Hall effect sensor unplugged.
Swap the coolant temp sensor for the ECU from your 2.4 engine to the 2.2 engine. Same with knock sensor, etc. remember that a 240 uses a single spade connector for the temp gauge readout whereas the 7/9 cars use a 2 pin connector. This is NOT the ECT (engine coolant temperature) sensor that supplies the ECU with data. This is ONLY for temp gauge readout. The rear sensor in between intake runners 3 and 4 is the ECT sensor.
Old 07-16-2019, 04:27 PM   #7
iHateVolvoPeople
The newer the better, as long as it’s OBD1. Preferably get yourself a white label 9xx lh2.4 ECU and EZK from the wanted section or the junkyard.
Only thing to worry about is with the ECU, some require a cold start injector in order to not throw a CEL, some don’t. I’d opt for a 954 or 937(?) ecu. These are white label LH2.4 turbo ECUs that don’t look for a cold start injector signal.
As for the EZK, same story except some look for an EGR signal. Can’t remember the part number but I *think* I used a 148 EZK which is also a white label, LH2.4 EZK that doesn’t look for an EGR signal. But you’ll need to triple check that part number, my turbo car isn’t handy right now otherwise I’d look.
Basically, to turbo a 2.4 car is extremely easy. Absolutely no tuning necessary at all. It is 100% plug and play if you have turbo ECU/EZK at your disposal.
But if you have a Parts car with an older LH2.4 turbo ECU/EZK, it’ll work fine too. I just prefer the newer white label stuff. They progressively got better as they got newer. But if you get too new you have to worry about OBD2 and immobilizers.
Old 07-16-2019, 04:41 PM   #8
white855T
Thanks in advance!
That's exactly what you need to do. You need the auxiliary shaft and distributor from your current engine. You will swap that to the b230ft engine. You will need to source the LH 2.4 turbo ecu & ezk to make it all work. You will have to use the IAC from your 240 engine as the one from the b230ft engine is different. Also, unless someone changed the transmission on your 240, you will have an aw70 which isn't ideal for the b230ft engine.
Old 07-16-2019, 05:21 PM   #9
twowheeledlife
There's a very good chance I'm wrong about the transmission in the 240. What makes the AW71 better for a turbo than the AW70? My donor car has the AW71 I believe (according to the internet), I just haven't ran it before so I'm not sure the condition of it.
Old 07-16-2019, 06:40 PM   #10
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
But if you have a Parts car with an older LH2.4 turbo ECU/EZK, itíll work fine too. I just prefer the newer white label stuff. They progressively got better as they got newer. But if you get too new you have to worry about OBD2 and immobilizers.
Can you show me an OBDII Redblock?
Yet Asher here went with...
Old 07-16-2019, 07:32 PM   #11
iHateVolvoPeople
Hi, I know youíre entirely useless when it comes to actually helping people, but here you are, making posts thatís are also, in fact, useless.
Yes, they made OBD2 redblock 940s. But Iíll let you find them on your own.
Old 07-16-2019, 07:35 PM   #12
iHateVolvoPeople
All of the turbo cars had aw71s. NA 240s never did. Your 240 has an aw70 unless itís heen swapped out. You have to use the aw71 behind turbo power.
Old 07-16-2019, 07:41 PM   #13
Lord_Athlon
Chuckie Blows
So R, can you show me an OBD-2 redblock?
Old 07-16-2019, 07:43 PM   #14
95 940Ts. I have seen like, one.
Old 07-17-2019, 11:47 AM   #15
Lord_Athlon
Chuckie Blows
Have you? Volvo stopped selling 940's in NA because of OBD
Old 07-17-2019, 11:49 AM   #16
Well you know what? If PromisRing here says they exist, they do exist. Because reasons
Old 07-17-2019, 11:50 AM   #17
iHateVolvoPeople
All 940s in NA have OBD, moron.
Old 07-17-2019, 11:52 AM   #18
Lord_Athlon
Chuckie Blows
The LH 2.4 On Board Diagnostics, and the Federally Mandated OBD-II specification are completely different, and you should know that.
the 96-98 Redblocks in Europe didnt have OBD-II either.
Old 07-17-2019, 11:53 AM   #19
iHateVolvoPeople
You said OBD, not OBD-II. As I stated, all 940s here have OBD. Now, if you donít mind please stop wasting all of our bandwidth with your useless posts that are of no help.
Old 07-17-2019, 11:54 AM   #20
Lord_Athlon
Chuckie Blows
You said OBD, not OBD-II. As I stated, all 940s here have OBD. Now, if you don’t mind please stop wasting all of our bandwidth with your useless posts that are of no help.
Says the guy telling the kid not to use an OBD-II ecu.
Furthermore, OBD means On Board Diagnostics, of which OBD-II are a part of. Notice I specified The LH 2.4 vs OBD-II. Volvo stopped selling redblocks in NA because of the OBD requirements for 1996. So yeah, im still right.
Old 07-17-2019, 12:00 PM   #21
Lord_Athlon
Chuckie Blows
Thanks in advance!
Take the b230FT
Swap in a distributor from an 83-93 240 and use the accompanying intermediate shaft. This gives you a chance to replace all of the front seals and timing belt for that leak free goodness.
Find the ECU's from a 90-95 7/9 Turbo. The newer the better. Some have EGR. Some dont. This can be dealt with in a bunch of different ways.
Use the harness, sensors and MAF from the 240.
Use the flexplate and the crank position sensor from the 240 on the 740 block.
Have a downpipe made that clears the stock oil cooler and fits in the 240 (fairly easy, or you can unthread the stud from the oil cooler and thread it into the block on the 740.
Use this chance to reseal the engine, because itll never be this easy.
You can use the 7 series intercooler and piping in the 240 and it fits for the most part. A little massaging here and there and itll be good to go.
Get a set of Orange 850T injectors. They are high impedance, drop in to the stock rail and will not require resistors to be wired in like the 7 series have.
Old 07-17-2019, 12:03 PM   #22
Old 07-17-2019, 05:43 PM   #23
twowheeledlife
Take the b230FT
I'm getting some great information from you all and i appreciate it. to swap the AW71 into my 240, is the form factor the same, just different/stronger internals to handle the additional turbo power?
Old 07-17-2019, 05:53 PM   #24
Lord_Athlon
Chuckie Blows
Its the same case, just more clutches IIRC. Everything swaps over and you visually cant tell the difference.
Old 07-17-2019, 06:00 PM   #25
twowheeledlife
Awesome, hopefully the donor transmission isn't toast. How does the AW71 hold up against the M47?
