Old 07-21-2019, 02:13 PM   #1
90volvo
Default would MSD stablize
Im doing a +T conversion on my 90 Volvo 240 NA car. I would love to do the megasquirt conversion but money tree isnt growning fast enough. I have a MSD 7AL laying around. I know it will boost the spart etc and give me some control over rev limiter and timing retarding. But will it help stablize the timing. If not is there a cheaper way to help in a turbo situation. I plan to pull my head and port it with manifold etc. Run a bigger cam. Hoping to get in 200+ range. I know the factory ignition isnt very stable. Thanks for any wisdom.
Old 07-21-2019, 05:40 PM   #2
iHateVolvoPeople
I thought 2.4 timing was pretty stable? It’s the Chrysler ignition on 2.2 240s that is very unstable.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 07-21-2019, 05:54 PM   #3
The stock ignition with LH2.4 will be fine unless you start running much higher boost than stock.
Old 07-21-2019, 08:55 PM   #4
90volvo
Yes I would and plan to run higher boost.
Old 07-21-2019, 09:07 PM   #5
vwbusman66
Eisen-Stein
vwbusman66's Avatar
How much higher? TLAO can speak to how far he has pushed it. I believe Kenny (linuxman51) has also pushed lh2.4 pretty hard.
1971 142 DD/beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 07-21-2019, 10:22 PM   #6
90volvo
12-13 psi. I’ll start stock then work my way up. If the factory 2.4 will work then I won’t worry about it. I appreciate the help.
Old 07-21-2019, 11:54 PM   #7
gsellstr
gsellstr's Avatar
Honestly, coming from a guy running a 6A for over a decade, just recently I've swapped back to stock ignition, but a nice BlasterSS coil. Seems to actually run a touch better than with the 6A on there.
Keep in mind, the MSD setup still gets a signal on when to fire from the EZK box, so no, you won't be any more stable with the 7AL than without.
FWIW, I've been running around 18psi for over a decade, the last few days I've been doing pulls at 26 with no issues at all.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-22-2019, 02:50 PM   #8
If you go above 12-13psi. You may need to make the spark plug gap a bit smaller or change to plugs that fire at a lower voltage like platinum or iridium with a smaller gap as well.
Old 07-22-2019, 04:44 PM   #9
iHateVolvoPeople
Do redblocks do okay on iridium or platinum plugs if you’re using the stock coil and distributor?
Old 07-22-2019, 09:16 PM   #10
gsellstr
gsellstr's Avatar
If gapped right, iridiums are fine. I ran those for a few years until my supplier realized they had them priced wrong. lol
Old 07-22-2019, 11:24 PM   #11
iHateVolvoPeople
thats awesome
What are the risks if they are not properly gapped? Just burnt out coil?
Old 07-23-2019, 12:00 AM   #12
gsellstr
gsellstr's Avatar
Bigger chance of misfire is the worst usually, though that can lead to failed plug wires or arcing in the cap.
