Old 10-25-2010, 04:22 AM   #1
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Default B230FT Thread sizes
Hi,
i searched the board and just found irritating and inconsistent stuff around..
so this time serious and with pic and maybe later with add in the FAQ?
So.. heres a nice pic of my 93* FT Block.. i think(hope) the threads dont differ between the years?
Threads used for:
1: Used for waterbased oilheatsink / plugged when using ext., air-oilcooler
2: Banjo for turbo-oilfeed
3: Oil warningcontact / alt. oilpressure
4: additional bore to main waterchannel (dunno what this is used for)
5: Oil Filter Adapter to mount without mounting Arm
6: additional bore to main oilchannel (used @ i.e. camerons Motor for oilfeed)
Thread sizes
now its your turn.. unfortunately i dont have any threadmeasurementtools except for metrical outer threads but not for inner NPTs and stuff...
1: 3/8 NPT ??
2: M14x1,5
3: M14,1,5
4: same as 1?
5: 3/4" 16tpi
6: 1/4" NPT
7: Oil drain / Pan t.b.c.
8: Oil Gallery Bellhousing t.b.c.
9: Oil Gallery Business end t.b.c.
THX ! I hope this would be, when finished, helpful in the FAQ?
Old 10-25-2010, 07:16 AM   #2
JW240
All idiot, no savant
JW240's Avatar
1: I remember this as 3/8 NPT (in your shops available as G3/8)
2: M14x1,5
3: M14,1,5
4: dont know
5: 3/4" 16tpi (Available at specialist shops, at least here)
6: 1/4" NPT
B230 = B230, no changes in threads. Some B23 stuff can be different (location/orientation, like oil feed/drain/pressure sender)
There is a thread/hardware faq in maintenance, not really updated much though..
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 10-25-2010, 08:27 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
You are my new Mr. Awesome now
1 should at least be the same than 4.. i remeber when i swapped from water heatsink to air oilcooler i stole the plug from 4 off my B234F Block to screw it into 1 in my B230FT
Old 10-25-2010, 08:57 AM   #4
JW240
JW240's Avatar
Good to know about plug 1 and 4 being the same, i didnt know that!
Old 03-08-2017, 05:53 AM   #5
FreeEMSFred
FreeEMSFred's Avatar
Thread necrophilia, but it may as well stay in one place! So:
Re 1 vs. 4, they do indeed appear to share the same thread style/size/pitch, my block drain fitting feels good screwing into the #4 hole.
I'll be sourcing a new bung for 4 soon and will update on what the thread is so the above post can be edited from red to green once I do that.
I do not have hole 2 due to natural asphyxiation, and have a question about the internal structure of it, how big is the hole through to the gallery behind in this? Anyone got a bare turbo block to measure?
Lastly, there's a few things missing from the list:
7) Oil drain fitting thread size/pitch/style? Internet says press fit, no thread, and taps to 3/4 NPT from stock, or 1/2 NPT if NA and undrillled
8) and 9) oil gallery bungs on the bell housing/business end, same as #6 I guess - they look it. Ditto sourcing soon.
My shopping list:
1 of M14x1.5 end-tap for oil feed #2
3 of #6/8/9 bungs with better drive style if possible
1 of #4 bung with better drive style if possible
Something appropriate for sealing these pressurised taper threads
Old 03-08-2017, 06:17 AM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
thx.. will update as soon as you confirm
Old 03-15-2017, 05:54 AM   #7
FreeEMSFred
How sure are you that #6 is 1/4 NPT? Ditto #1 and #4 being 3/8 NPT? I have here 1/4 and 3/8 BSPT bungs that screw right in about 4 or 5 threads before they start to come up against the taper.
IE, I think these are BSPT, not NPT. NPT appears to be an America-only standard. Correct me if I'm wrong. Calipers say that what I have matches stock. Anyone got a 1/4 NPT or 3/8 NPT handy to measure?
Old 03-15-2017, 06:18 AM   #8
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
hm.. 95% .. i ordered a 1/4NPT fitting to Dash4 and set it in with some loctite... fitted like a charm.
Old 03-16-2017, 06:14 AM   #9
FreeEMSFred
The thread cut angle is supposed to be different, and the ones I have match the stuff I took out with no visible light. Not sure how to properly measure them, but that's a pretty strong sign. Perhaps they're just so damn similar that it doesn't matter much?
Old 03-16-2017, 06:35 AM   #10
FreeEMSFred
OK, yes, they are that similar. 18 TPI vs 19 TPI and about the same diameter/taper. I'll have a closer check and see if I'm screwing things up. Likely yes? Possibly no?
Old 03-16-2017, 08:36 AM   #11
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Are you sure you screwed a 3/8BSP thingy into that oil blindhole?
https://www.mehari-offroad.de/reduzi...pt-auf-1-8-bsp
Old 03-16-2017, 09:59 AM   #12
GTJordan
Been here for too long
GTJordan's Avatar
I put a 3/8 npt in position 4- that's what the machine shop gave me. But it just threaded all the way through without tightening up. I was gonna see if I can order the Volvo part from work.
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 03-16-2017, 12:05 PM   #13
John V, outside agitator
Many countries used NPT on blocks--Japanese, German, Swedish..and merikun
Almost nobody would even conceive of using BSPT unless they were a Pommie bastid or wannabe pom.
Reckon its time to dust off those ol Punch a Pom a day T-shirts?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 03-16-2017, 12:24 PM   #14
culberro
culberro's Avatar
Yeah those area all NPT on teh ovlov.
BSPP is used on teh ovlov oil cooler, but I haven't come across BSPT yet.
