Old 03-15-2017, 01:35 AM   #1
keatonml53
Default Stock rear axle upgrades
I've talked to a guy that has a v8 swapped 940, but he doesn't have a ford 8.8 rear axle, but instead an upgraded volvo axle with 4.10 gears. Where can I find a 4.10 posi for a Volvo rear axle, and how much of a cost difference would it be versus getting an entire ford 8.8?
keatonml53 is offline   Reply With Quote
Old 03-15-2017, 06:17 AM   #2
ryan350ci
ryan350ci's Avatar
Your best bet for a 4:10 R&P is to post in the wanted section, somebody most likely has a set they will sell. Many Volvos had G80 lockers in them, even install Detroit Truetrac units. Another option for open diffs is to use a Richmond/PowerTrax locker, but they are fairly noisy and the locking can be quite brutal if you don't know what you are doing.
As far as the 8.8, it could be relatively cheap or ridiculously expensive. They require some modification to fit, and if you can do it all yourself, this would be the way to go. If you have to get the housing cut and brackets moved at a shop, it could cost you dearly. There are plenty of threads on how to do this modification in this forum, so do yourself a favor and read up on it first.
1977 264GL - 383/700r4
1983 242 - (shell)
1995 944 Turbo - B230FT
2006 XC90 V8 AWD (Wife's Daily)
2007 S60 2.5T AWD (Daily)
1985 300zx - V8 Swap
1989 S-10 - V8 Swap
1974 Nova SS Hatchback
1993 F150 - Straight Six
1992 Ranger 4x4 - 2.9 V6
1968 Mustang GT Fastback 428 Cobra-Jet
1988 F250 4x4 - 5.8 V8
(Sold)1989 765 Turbo/IC - B230FT
(Sold)1990 Mustang LX 5.0
Feedback Thread:
http://forums.turbobricks.com/showth...24#post5254924
ryan350ci is offline   Reply With Quote
Old 03-15-2017, 12:55 PM   #3
culberro
culberro's Avatar
Are you running a V8? What tire size in the rear? Manual or Auto? 4.10 is kind of steep. 3.73 with a 0.73od and stock sized tires is pretty buzzy for freeway driving as well. 3.53 or 3.31 would be nice for a lot of freeway driving.
You can probably find an entire axle with 4.10 gears for the same price as a set of used gears.
Trutrac 588 is the one you want for the rear, if you want to go that route. https://www.summitracing.com/parts/dtl-912a588
I'd avoid a G80 as it's just crushing disappointment if you actually want something that is smooth.
Old 03-15-2017, 09:38 PM   #4
keatonml53
I wasn't particularly meaning a 4.10, I was just wondering where I could acquire an upgrade for the stock rear axle.
Old 03-16-2017, 02:40 AM   #5
culberro
culberro's Avatar
Drop in solutions:
Trutrac, Wavetrac, Gripper, Sellholm, G80.
Old 03-16-2017, 09:02 AM   #6
Joe_Diesel
Joe_Diesel's Avatar
Where can you purchase a trutrac online as well as other rearend rebuild parts?
Joe_Diesel is offline   Reply With Quote
Old 03-16-2017, 09:25 AM   #7
roccodart440
Depends on how tall of a tire you run.
Check this out. This is friends website that helps you calculate where you want to be.
https://reillymotorsports.com/store2...alculator.html
When I doubt go 1 step taller in your ratio.
roccodart440 is offline   Reply With Quote
