Old 03-20-2017, 08:04 PM   #1
Eurobubble
Post 850 Keyless Entry in a 240 DIY
Just completed this swap and figured I would post a DIY for this particular setup.
I used these two posts to make it happen. But for people like me I could use pictures of this swap.
850 Keyless Entry in a 740:
http://forums.turbobricks.com/showthread.php?p=3557403
Generic Keyless Entry in a 240:
http://forums.turbobricks.com/showthread.php?t=224742
WHY: I wanted to have a volvo fob
Parts List:
CWT5654R Keyless Entry Brain (Found in a 93-95 850, take out the glovebox and look to right below the A pilar) take as much of the wiring harness as you can get.
CWT5653T Fob (Bought 3 of these off ebay for $7 each with new batteries)
9148481 Central Locking Relay (Found up under the dash by the driver front wheel well in a block of other relays) I tried a bunch of relays from JY cars and only this one worked for me. It was pulled from a 97 850
Volvo 240 passenger front lock solenoid (Make sure to grab the brass mounting bracker, brass rod and the black metal retainer clip) I also took the wiring (blue and yellow) all the way back to the 240 central locking relays.
Make sure the Negative terminal on the battery is disconnected during the install!
Install the passenger door lock solenoid into the drivers door.
You must flip the brass bracket to the other side of the solenoid.
install the brass rod and retainer clip onto the driver side door lock rod like so:
then take the all the door solenoid wiring and run it through the door jamb gasket with the rest of the wiring.
When you get to car body side of the door gasket push the blue and yellow wires one at a time up through a small hole in the body of the car so that the pop out above the fuse block panel. Continue the run the wiring to where the rear door solenoid harness clips into the 240 central locking relay. I attached my driver side harness to the clips of the rear door harness to avoid having to splice and solder a connection. like so :
ignore that my wiring is flipped backwards. It should be blue to blue and yellow to yellow.
At this point I wired my 9148481 850 central locking relay to my 850 Keyless Entry Brain.
The keyless entry control module/receiver has four wires coming from it.
Red: 12V at all times
Black: ground
Green/yellow: signal wire to locking relay that controls lock/unlock cycle (relay terminal ATR)
Yellow/violet: 12V with key in ignition
The central locking relay has a legend on it that shows what each post does.
ATR: green/yellow signal wire from control module/receiver
31: ground
M+: red wire (Lock)
M-: green wire (Unlock)
30: 12V at all times (Fuse 8)
15: 12V with key in ignition (Fuse 12)
The lock/unlock wires (M+/M- from the relay) I also attached the wires to this terminals so I wouldn't have to the cut and splice the original wiring
Ignore the bare wires, I did actually pull the terminal out of the clip and attach it with the existing wiring. this was during then I was testing it.
Ignore the bare wires I attached proper clips, this was just when I test wired things up to make sure it worked.
Now if you got the fobs off ebay like I did you'll have the program them using this method.
-Switch on the ignition to positions II 5 times within the space of 10 seconds, and leave the ignition on the 5th time.
-Within 30 seconds, press either the "LOCK" or "UNLOCK" button once on the transmitter. All the transmitters must be reprogrammed within 30 seconds.
-Switch off the ignition.
-Check that each of the transmitters functions properly.
I mounted the 850 central locking relay up in my dash by the fuel pump relay, and mounted 850 keyless entry brain behind the 240 central locking relays. Basically right under the dash speaker cover.
Hopes this helps someone!
Eurobubble is offline   Reply With Quote
Old 03-21-2017, 09:29 PM   #2
Eurobubble
sticky?
Old 03-24-2017, 08:22 PM   #3
Volvo265
Does this remove the original lock relays? And why the passengers side door lock rod on the drivers side door? Isnt that just a rod with no electronics? What do you do about lock/unlock switches (the ones that arent on the key fobs)
Volvo265 is offline   Reply With Quote
Old 03-24-2017, 08:49 PM   #4
TestPoint
TestPoint's Avatar
Very well done conversion of the 240 system to later all Volvo. This can also be done with ebay $15 remote fob kits and the addition of an operator for the driver door. The Volvo operators are reversible side to side and the same front to back so there are lots of JY units around.
There is already a thread in the Article Composition forum on this conversion using the aftermarket controllers. The use of later model Volvo parts description would probably be a good addition to that thread at least as a link.
Ford V8 Conversion Manual -
Old 03-28-2017, 02:01 AM   #5
Eurobubble
I does not remove the original lock relays, this mod just splices into the existing system to add the remote lock. check out the article I reference in the beginning of the thread for a more thorough wiring diagram
Old 03-28-2017, 02:04 AM   #6
Eurobubble
Thanks TestPoint, I meant this article to just to an add on to that original article to use the later model Volvo parts to keep it OEM. Ill add my first post to that thread.
Old 03-28-2017, 03:20 AM   #7
JW240
All idiot, no savant
JW240's Avatar
Nice! Thnx for the write up.
This has been on my todo list for some time now. I need to find a parts car..
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 08-27-2017, 01:09 PM   #8
Volvo265
Will the keyless entry unit from a 96+ 850 work? I have found one at my local pick your part yard in a 1997 model... looks the same as the one in the picture but i didnt see the same part number on it anywhere...
