Old 05-22-2020, 02:56 AM   #1
92White240
Exclamation 240 Running a bit toasty
So I've started to notice, after bypassing the compensator, my temp reads a bit high. It never gets really uncomfortable hot, maybe a needle-width's above middle most of the time, is this normal? If not, what should I check for the cause?
92White240 is offline   Reply With Quote
Old 05-22-2020, 07:59 AM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
Do you have an infrared thermometer? Check the thermostat housing for the actual temp reading to see if it is above normal.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 05-22-2020, 12:45 PM   #3
92White240
Sorry ut how can I tell if it's an "infared"
Old 05-22-2020, 12:47 PM   #4
apachechef
Burnt Sierra Madre
this has been beaten to death.
the compensator was used to avoid questions exactly like this.
the cause is bypass of the board.
Did you not read any of the threads talking about this?
as above, use an IR thermometer on thermostat housing to eval ACTUAL temp and correlate to the gauge. the needle will not always be deadlocked on 9pm, actual temps vary slightly.
Short answer, the red zone is bad, below that, relax.
Great rela life demonstration what frustrated Volvo enough to make the faker a thing
Dammit, Lummert.
Old 05-22-2020, 12:48 PM   #5
apachechef
Burnt Sierra Madre
google infrared thermometer
Old 05-22-2020, 12:52 PM   #6
92White240
My compensator was causing the reading to be right under the red constantly, so I removed it, and I tried searching threads and all I could find it stuff on what to replace for a hot car. And I understand there's been many questions on this sort of topic, but, and not trying to be mean or sarcastic, do you really expect there to be a whole set of new content/threads everyday on this site?
Old 05-22-2020, 12:54 PM   #7
92White240
Am now realizing how stupid that question was, I thought there was some sort of other temp gauge some volvos had referred to as infrared. I understand
Old 05-22-2020, 01:19 PM   #8
apachechef
Burnt Sierra Madre
compensator "turbobricks"
159 esults on google
And I assume you must have learned a bit about the compensator when you learned that it existed and decided to bypass it.
To me, very puzzling sequence...
How does one learn to bypass the compensator without understanding what happens after
yes I do, but I also expect and know most will be rehashed already answered questions by the lazy. '
no worries, sarcasm is not troublesome to me
Old 05-22-2020, 07:45 PM   #9
92White240
[QUOTE=apachechef;6081325]compensator "turbobricks"
This is my first car and as such, don't know much about cars. I was told about compensator boards by my dad whos had a fair bit of 240s, and wasn't yet aware of turbobrick's existence, so I just knew it was the problem, and he and I bypassed it. So yea puzzling. Thanks for the feedback, just didn't know to what degree running "warm" was normal
Old 05-23-2020, 06:26 PM   #10
In general when you bypass the circuit. It causes the gauge to react properly to the engine. So you'll see the needle move about a bit more like for example as the thermostat opens and then temps level off you can see a spike on the gauge. Or if you are climbing a long hill loading the engine more. You'll see the gauge rise now because you don't have that stupid faker board in there.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 05-24-2020, 04:14 PM   #11
92White240
Makes snese, thanks
Old 05-24-2020, 06:57 PM   #12
philski o'flood
philski o'flood's Avatar
maybe try a cooler thermostat
Old 05-24-2020, 09:34 PM   #13
apachechef
Burnt Sierra Madre
Some tape over the gauge is better
