Old 06-26-2010, 08:21 PM   #1
SwedishBee
Drill em deep
SwedishBee's Avatar
Default What size tires for 240 + 15x7.5 inch wheels?
What size tires do I get for some 15x7.5 inch remotec wheels?
The car will probably not be lowered, just a stock 85 245ti.
Ive been guessing at sizes and I have a feeling there is not going to be much selection.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 06-26-2010, 09:26 PM   #2
klr142
Turbo, what?
klr142's Avatar
Intended use?
205/60, 205/55, 225/50, 215/55...
Old 06-26-2010, 09:29 PM   #3
coondog240
Homing Pigeon
coondog240 is offline   Reply With Quote
Old 06-26-2010, 09:58 PM   #4
SwedishBee
Drill em deep
SwedishBee's Avatar
Just for looks.
Old 06-26-2010, 10:32 PM   #5
lummert
lummert's Avatar
235/55R-15. But, will there be room to run a tire this wide on a 240? A 225/55R-15 might be a better fit.
Old 06-27-2010, 12:27 AM   #6
PRVersion
regretting name change
PRVersion's Avatar
wouldn't you want 225/50 for a stockish sidewall height?
PRVersion wins.
accelerate til the last possible moment, then accelerate more...
PRVersion is offline   Reply With Quote
Old 06-27-2010, 01:54 AM   #7
Mylesofsmyles
what's your car's setup and how do you drive it? 225 is a lotta rubber unless you need it...my 242 handles real well and has a nice steering weight with 195/55/16. there was a huge difference in steering weight coming from 205/55/16. plus, it'll look cooler with a stretch. i vote 195/60 or 205/60...unless there's something under the hood I should worry about.
Old 06-27-2010, 08:19 AM   #8
towerymt
the real Towery
towerymt's Avatar
I use 205/60/15 on 15x7 on my daily driver 244. I wouldn't want anything taller. 205 on a 7" (or 7.5") fits well. The sidewall is vertical and well supported. It's also a common size available in lots of different models.
It may depend on what type of tire you want.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 06-27-2010, 08:20 AM   #9
towerymt
the real Towery
towerymt's Avatar
Old 06-27-2010, 11:10 AM   #10
andysbeta
thrsh
andysbeta's Avatar
Location: Mancos, CO (no longer the Central Valley Smog Bank)
if available 205 55 r15 is great too.. i have those on the 245 here. Speedometer is pretty accrate too 69 mph = 70 mph. (sorry keyboard beer spill keys no longer working).
andysbeta is offline   Reply With Quote
Old 06-27-2010, 11:46 AM   #11
225's will probably rub unless your bushings and offset are right.
Old 06-27-2010, 03:16 PM   #12
vvpete
For the wagon, stock ride height is with 25.6 inch diameter tires, and a (near) perfect tire is a 215/60-15 which is 25.1 inch dia and your speedo will be +1 mph at 60. You will love how it handles and is much more stable than the 205/60-15, especially for loads in the cargo bay, and greatly improves the highway ride quality. I run 215's on my 245 w 15 x 7 wheels. It is about the widest tire you can fit with a 20 mm offset.
When folks say 205/60-15 it is for the sedan tire size match, not the wagon.
vvpete is offline   Reply With Quote
Old 06-27-2010, 03:25 PM   #13
vvpete
Unless you changed the speedo, that tire will give +7 mph speedo error (23.8 inches, more than 2 inches smaller diameter than stock). I have used that size on a 965 and it was a mistake, it is a puny tire, load rating is not enough for a wagon IMHO.
Old 06-27-2010, 04:09 PM   #14
klr142
Turbo, what?
klr142's Avatar
On my 244 a ~24.9-25" tire provides an accurate speedometer, not the stock sized tire. For what it's worth.
Old 06-27-2010, 05:38 PM   #15
NC244GLT
NC244GLT's Avatar
I just put a set of 205/50/15 RE11's on my 240 on Virgos. They look good, but if the car is at stock ride height, you will have massive fender gap.
'84 244TIC - 15G, Ported 90+,LAO DP, 3" full mandrel bent exhaust, NPR, Halman Pro MBC, IPD T Cam straight up, Term 11, 14-15psi of fun, front polys in, rears in..Koni Yellows on cut stock springs.
'94 945TIC - Son's first car...Project "Swagon"
Billy's, IPD springs, pretty stock...so far!
'98 S90 - Stock...couldn't pass it up.
'12 MX5 SE - What a fun car!
NC244GLT is offline   Reply With Quote
Old 06-27-2010, 07:17 PM   #16
andysbeta
thrsh
andysbeta's Avatar
Not if:
You converted an automatic 245 to m46, kept original 3.73:1 rear ratio.
Used B21FT M46 speedo gear. Mated it to later sedan mechanical speedo.
Forgot those details. Basically I am using sedan tire dimensions, if you have a sedan 205 55 r 15 will still be reasonably accurate.
Old 06-27-2010, 11:42 PM   #17
ElPiloto
Where did you find Remotec wheels?
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 06-28-2010, 12:30 AM   #18
badvlvo
Bad for Babies
badvlvo's Avatar
I run 225/50/15 on my car. The only rub is due to the car being too low and the bushings being worn with the exception of ONE spot on the fender lip and that is only because I have a very steep driveway.
Died at age 35
Old 06-28-2010, 12:34 AM   #19
Sure?
Check the undercoating on your rear inner wheel wells.
Those wheels did a job on my 82 245 before you got them.
Old 06-28-2010, 12:58 AM   #20
klr142
Turbo, what?
klr142's Avatar
Sure?
The Remotecs are likely lower offset than the stock wheels that rubbed to begin with in the odd situations that they do. Kind of like p2 cars with the 235s that rub at full lock, too. Some slight rubbing is no problem.
Old 06-28-2010, 09:11 AM   #21
towerymt
the real Towery
towerymt's Avatar
My 15x7 ET12 with 205/60/15 rarely rub on the inside rear. 8" ET20 will rub frequently when the axle articulates.
I don't count it as a rub unless it happens on compression. I've had stock size wheels/tire rub on the inside, so that's always going to be an issue regardless of wheel/tire. With my pulled fenders, I could run Virgos with 60mm spacers on the rear and still have good clearance to the fender. Probably would never rub the inside...probably.
Old 06-28-2010, 10:50 AM   #22
225-50-15 on dracos.
Old 06-28-2010, 01:59 PM   #23
SwedishBee
Drill em deep
SwedishBee's Avatar
I found them in a texas junkyard mounted to a 262c with a b21f and mint interior.
I think the offset is 10.
I will post up some pics in showroom later...
Old 06-28-2010, 02:29 PM   #24
vvpete
With the 10 mm offset you could use 225/55-15, but will probably have to roll the fenders
Originally Posted by coondog240 View Post
215/55
The elusive 215/55-15 That is (could) be a good size & fit, if they actually existed
Old 06-28-2010, 02:54 PM   #25
badvlvo
Bad for Babies
badvlvo's Avatar
Sure?
The Dracos rub, I'm talking about my good wheels. They are the correct backspace for 240's where Dracos were fitted to granny cars.
