Old 08-31-2019, 12:13 PM   #1
Jaypee_6680
Default Manifold identification
So I have in my possession two turbo manifolds that seem to fit my Garrett T3 turbo.
Any idea which is best?
Part number are:
3514275 (came attached to a B230FT)
1366992 (came as a random spare with the B230FT)
I did a search and couldn’t find anything conclusive.
John
Jaypee_6680 is offline   Reply With Quote
Old 08-31-2019, 12:15 PM   #2
Jaypee_6680
https://drive.google.com/open?id=1L3...Z2io8CcH7W1idn
Old 08-31-2019, 03:14 PM   #3
sbabbs
sbabbs's Avatar
We'll for a turbo redblock everybody like the later 1990 or newer style flows better turbo manifold. Can't see your pics. Anyway the later better style has studs you nut your turbo on with, the earlier style has bolts and nuts.
Old 09-01-2019, 03:42 AM   #4
Jaypee_6680
It seems I may have a 90+ Manifold then!
The picture link should work now, thanks though!
John
Old 09-01-2019, 03:59 AM   #5
redblockpowered
redblockpowered's Avatar
Better flowing manifold is on the right in your picture. Stamped 3514275.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (330k!)
Old 09-03-2019, 02:47 PM   #6
Then you port the opening for the turbo on the manifold to better match the inlet to the turbo. Now you have even more flow with less heat built up in the manifold which will help avoid cracking. Use a standard T3 gasket as the template to open up the manifold.
Old 09-03-2019, 09:29 PM   #7
Dirty Rick
Dirty Rick's Avatar
Use the manifold with no cracks.
The one with the bars between the head ports is better, less warping.
Port match it for more flow.
