Old 07-31-2020, 11:46 AM   #1
Murploid1
Murploid1's Avatar
Default Coverlay Dash Covers
Hello,
Does anyone have experience with "Coverlay" dash covers?
https://www.ebay.com/itm/Coverlay-Ne...wAAOSwHwldrlcA
Its a plastic solution that fits over the existing dash, I received samples however none of these came close to matching my tan interior.
Now I am wondering if I should purchase and respray with some SEM tan interior paint - I have used this on other (smaller) plastic pieces and its a pretty close match.
Thoughts anyone?
Murploid1 is offline   Reply With Quote
Old 07-31-2020, 01:25 PM   #2
Alan29
Alan29's Avatar
Heard lots of good feedback from the IPD ones...which are actually quite a bit less expensive than that one on Ebay. IPD I believe also stocks the SEM spray that matches the tan interior. Whichever route you go please post up your feedback. I'm looking to do this at some point down the road so I can finally get rid of my black fuzzy dash carpet.
Signature.
Old 07-31-2020, 01:51 PM   #3
Ursan
Bored Member
Ursan's Avatar
I had one on my 80. Once in place and bonded down, you can't really tell it's a cover.
Originally Posted by 740freak View Post
how psi a stock can support?
Originally Posted by speedn_j View Post
So I’m a racist big deal who cares. Deal with it.
I admit I'm stupid...
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
Old 07-31-2020, 02:57 PM   #4
Murploid1
Murploid1's Avatar
Yes, I heard that the dash cover itself is very good, the key is going to be the color match.
I am super disappointed that the coverlay samples I received were not even close to my tan interior.
I will look into the IPD covers, otherwise will most like spray with SEM.
Old 07-31-2020, 04:31 PM   #5
TestPoint
TestPoint's Avatar
First . . . anywhere you find a 240 dash cover, IPD or JC Whitney, it is going to have been manufactured by Coverlay.
I installed one and was very happy with the results. Here is a link to my efforts: http://forums.turbobricks.com/showthread.php?t=309320
Dash out is about the only way to get it done right. The texture of the cover is smoother than Volvo's original but it is certainly much better than a 40 year old cracked dash.
I had the local auto paint store color match the interior of one of the center console kick panels and it came out very nice. Cost was not much more than the outrageous price of a can of SEM paint.
Ford V8 Conversion Manual -
Old 07-31-2020, 05:17 PM   #6
89-240gl+t
I did this with the dash in and definitely wouldn't recommend that. Take the dash out so you can clamp it down
'84 242 Turbo
Rebuilt 93 B230FT block, T5WC, MSII-Extra, EDIS, Nathan Exhaust Manifold, Ebay Turbo , 60lb injectors, 3" exhaust, Kaplhenke Coilovers Front/Rear Koni Race Single Adjustable’s, RX7 Brakes, IPD 25/25 sways
89-240gl+t is offline   Reply With Quote
Old 08-01-2020, 01:21 PM   #7
Murploid1
Murploid1's Avatar
Interesting thanks! Disappointing regarding the recommendation take dash out - not something I want to or will do. They markets these covers as an easy install solution, seems that this is not actually the case.
Old 08-01-2020, 01:50 PM   #8
TestPoint
TestPoint's Avatar
No problem with just laying it in and using a little of the high strength, high temperature glue. It will look lots better than the 40 year old cracked dash. Want it to be all it can be dash gotta come out.
Old 08-01-2020, 04:24 PM   #9
dandeluca
Here is a little video I made of my installation. https://youtu.be/ksmMu0wwhuY It looks good but the car has not left the garage much. I am a bit concerned how it will hold up in hot sun.
dandeluca is offline   Reply With Quote
Old 08-03-2020, 01:30 PM   #10
Murploid1
Murploid1's Avatar
thanks all!
Old 08-03-2020, 01:45 PM   #11
F*ck 12
My dash cover cracked in the same place the dash cracked in!!
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
