Hydra center cap question
92White240
pnw
I like the look of Hydras without the centercaps so you can see the lugs but I don't like the hub exposed, is there any small centercaps wether it be on IPD or from other wheels that fit in the small center hole?
set of 4 VOLVO 850 S60 S70 S80 V50 V70 XC70 XC90 Black Wheel Center Cap 3546923
Redwood has the hook up. If you want to gamble and be a bit different you could search 65mm centerbore wheel caps on Google for a hand full of generics. The Volvo center bore is 65.1mm. I wouldnt expect any of them to reliably lock in without a little adhesive or tape.
:nod:
I've got a set here TB?heap as well.
I don't have Hydras but not sure the Virgo cap will fit the bearing cap. I know it doesn't work with Corona wheels. Also the black cap barely works with Corona wheels. Perhaps the Hydra hub is different????
