Old 11-24-2007, 02:53 AM   #1
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
Default using an eaton M90 (supercharged 2007 bump)
GM used them extensivly with the 3.8L v6's
so it comes to reason that one might be able to work resonably well with the redblock or even with the whiteblock motors
the m90 is rated to a max of 12,000rpm, knowing i'm going for a happy 7k motor
that gives me a pully ratio of up to 1.7-1.8
i've found some crappy but usefull maps here
http://www.capa.com.au/eaton_m90data.htm
considering it can supply over 550cfm then it would appear to supply more than enough for killing the stock rods
the question comes on how to pick a ratio for it, my goal is to limit it to its rather dam efficient 5psi opperation
is there any good way to guess from the maps what sort of ratio to start with?
Tentacle SUV 07 xc90 D5; Has been to Cape York and back and survived (look it up)
recently crushed Volvo's
Old 11-24-2007, 03:00 AM   #2
VQ
Not such a PRVert Anymore
VQ's Avatar
The 12,000rpm speed is usually attained with it set up to about 12-14psi, as running one to one rpm's woudn't give much boost.
Old 11-24-2007, 10:05 AM   #3
Matt Dupuis
Matt Dupuis's Avatar
Eaton has an online calculator that lets you play with ratios & stuff, and should give you an idea of the boost you'll getting out of it. It's not going to be dead-nuts accurate, but it'll be a decent starting point.
Matt Dupuis is offline   Reply With Quote
Old 11-24-2007, 06:41 PM   #4
Forg
Forg's Avatar
Would not a reasonable rule-of-thumb be to work-out what RPM GM were running it at on the 3.8L engine, and figure it needs to slow-down by approximately 3.8/2.3 on a 2.3L engine? I think they were only using about 5-6psi, weren't they?
Officially more comely than Paul Buck.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 11-24-2007, 06:46 PM   #5
MrDoug
"Forty-threee dollars"
MrDoug's Avatar
Didn't the 89-95 Ford Supercoupe use the M90 as well?
"Mah? Is that her first name? Is she Vietnamese?
MrDoug is offline   Reply With Quote
Old 11-24-2007, 07:26 PM   #6
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
if your going to the trouble of doing this wouldn't you just set the eaton up to hit max it's RPM at the Max RPM your going to run the engine at, then just use MS to tune for what ever boost you end up running, i mean if your gonna do it might as well go all the way.
MikeHardy is offline   Reply With Quote
Old 11-24-2007, 09:53 PM   #7
shaved240
shaved240's Avatar
yea I think he's referring to the m90 that was used on the thunderbird 3.6 v6
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 11-24-2007, 10:01 PM   #8
frostburner
Just make sure you do your math right, double and triple check so you don't have headaches later, you should get some nice gains at 5-6 psi.
frostburner is offline   Reply With Quote
Old 11-24-2007, 10:32 PM   #9
Lord Tentacle
Anime Lord
dont put words into my mouth
i wouldn't touch the ford with a 10 foot pole
GM L67 series II 3800 v6
Originally Posted by wiki
The L67 is the supercharged version of the Series II L36 and appeared in 1996, one year after the normally-aspirated version. It uses the Eaton Generation 3 M90 supercharger with a 3.8" pulley, a different throttle body, fuel injectors, cylinder heads, and lower intake manifold than the L36 uses. Both engines share the same engine blocks, but compression is reduced from 9.4:1 in the L36 to 8.5:1 for the L67. Power is up to 240 hp (180 kW) and 280 ftlbf (380 Nm) of torque. Final drive ratios are reduced in most applications, for better fuel economy and more use of the engine's torque in the low range. The engine is built in Flint, Michigan. The engine was certified LEV in 2001.
This engine was used in the following cars:
1996-2005 Buick Park Avenue Ultra
1997.5-2004 Buick Regal GS
1996-1999 Buick Riviera (optional 1996-97, std. 1998-99)
2004-2005 Chevrolet Impala SS
2004-2005 Chevrolet Monte Carlo SS
1996-2004 Holden Commodore (VS, VT, VX, VY)
2001-2004 Holden Monaro
1996-1999 Oldsmobile Eighty-Eight LSS (limited)
1996-2003 Pontiac Bonneville SSEi
1997-2003 Pontiac Grand Prix GTP
not really
that would give me something close to 20lb of boost from talking to some of the GM guys with the 3800v6
going over 5psi requires using an intercooler from the heating of the air, even at 5 psi its still 60-80F
i'm not sure if there is space for the pluming of an air to air intercooler which would meen fabricating some sort of air to water setup to sit between the carger and the plenum
thus is where it gets expensive and complicated
Old 11-24-2007, 11:02 PM   #10
thelostartof
unbalanced chemical
thelostartof's Avatar
using the ford unit(same damn thing almost) should allow you to use an intercooler as the fords had intercoolers on them mounted next to the rad
Old 11-24-2007, 11:10 PM   #11
jutny
seems like all that work for only 5-6 psi would be.... eh
do it right, intercool it, you know you want to. i got an ebay intercooler in the front of my car without having to move the radiator more than an inch back (and only at the bottom, its angled) so you should still be fine with clearance (which i assume is your concern about intercooling)
*2001 Audi S4 Avant, Chipped, Exhausted, Suspended. Fun!
*1999 Ford E350 Extended Hi-Top, 7.3 Powerstroke.
*First Gen RX7's, Motorcycles, Mountain Bikes
jutny is offline   Reply With Quote
Old 11-25-2007, 12:53 AM   #12
dbh86
What's a 16V?
dbh86's Avatar
Why not use something properly sized?
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 11-25-2007, 01:13 AM   #13
thelostartof
unbalanced chemical
on an engine that already makes 208bhp adding 6+psi on a DOHC engine with a good intercooler and header should be able to push it up to 300+bhp and make for a really really fun car to drive
Old 11-25-2007, 02:27 AM   #14
Lord Tentacle
Anime Lord
exactly
i think i'm going to draw this **** out tonight, makes it easier to explain
uggg... i think i know a car a little to well if i can visualize all this stuff easily
Old 11-25-2007, 03:21 AM   #15
MrDoug
MrDoug's Avatar
Do it! The sound alone will be worth it.
Old 11-25-2007, 04:01 AM   #16
Forg
Forg's Avatar
There is. The Eaton won't just mount-up onto your head &/or intake manifold without any custom messing-around; you'll need some sort of piping anyway, may as well set that piping up to involve an intercooler.
Old 11-25-2007, 04:50 AM   #17
suterman
suterman's Avatar
I was thinking about using a 2:1 ratio so that the SC is doing 12000 rpm to the engines 6000rpm. I was also planning to use a normal SC bypass valve combined with an adjustable cbv, venting to atmosphere to bleed excessive boost, and if there was too much air get a different pulley in the end.
There would be a lot of piping around the place using an air/air IC so I'm planning a water/air cooler.
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 11-25-2007, 06:24 AM   #18
MikeHardy
MikeHardy's Avatar
i ran this last night on eatons site, it was a well tuned 200hp NA B230 that i made up on dyno2003 sometime back with a maxed out eaton M112
HP is on the left torque is on the right in NM
Old 11-25-2007, 02:45 PM   #19
suterman
suterman's Avatar
Sorry for pinching the photo 740atl
This is an idea for the intercooler I had, it could be made with steel sheet and a heater matrix cheaply enough I reckon,
you get the idea
Old 11-25-2007, 04:18 PM   #20
Boosted2003
Boosted2003's Avatar
The m112 from the ford lighting. Yeah, it damn near perfect match to the m90.
Also try gen 3 m90 off the series 3 3.8l v6 (L32)
2006 VW Passat 2.0t 6 Speed - Current
2005 Dodge Magnum R/T - Sold
2005 Dodge Ram 2500 - Sold
1998 Dodge Ram 1500 - Sold
1990 Volvo 760 Turbo - Sold
Boosted2003 is offline   Reply With Quote
Old 04-12-2011, 02:42 PM   #21
chubsky
What is the displacement for the 3rd gen m90?
chubsky is offline   Reply With Quote
Old 04-12-2011, 02:55 PM   #22
vivalavolvo
vivalavolvo's Avatar
http://cgi.ebay.com/ebaymotors/Adapt...s#ht_500wt_845
1978 242DL - 1995 855 T5 ARD Green - 1992 Volvo 745
vivalavolvo is offline   Reply With Quote
Old 04-12-2011, 04:23 PM   #23
You could run the thing to 11000 RPM and set a wastegate to 6 PSI.
Not efficient but safe
Old 04-12-2011, 04:23 PM   #24
Old 04-12-2011, 04:23 PM   #25
Mueller
Mueller's Avatar
still 90, no matter what generation....
