Old 05-15-2009, 09:50 AM   #101
DaButcher
Do a Burnout!
DaButcher's Avatar
Hi, this looks VERY nice and clean, however:
You need to paint your intake and the fuel rail, so it doesent look so old (yes I know it's old, but everything else looks new).
DaButcher is offline   Reply With Quote
Old 05-15-2009, 10:15 AM   #102
Jordan
Jordan's Avatar
Absolutely bangin mang.
That is the level of clutter that I will be going for in my next 240. Very nice, envy meter is off the charts.
My Buyer/Seller Feedback Thread
Jordan is offline   Reply With Quote
Old 05-16-2009, 12:16 AM   #103
spruill244
Mahalos
spruill244's Avatar
Awesome build, given some ideas for the 242 sitting in the garage.
Image and video hosting by TinyPic
68' 145S-Sold
90' 745T-Sold
95' 850R-Sold
83' 244T-Sold
96' 850R- Sold
spruill244 is offline   Reply With Quote
Old 05-16-2009, 01:51 AM   #104
llama
llama's Avatar
looks like its coming along great. what else is there to do?
Doing mysterious things with mysterious people
Originally Posted by m46destroyer View Post
Fuel distributor, may God have mercy on your soul.
llama is offline   Reply With Quote
Old 05-17-2009, 09:51 PM   #105
Bob
Away
Bob's Avatar
Mostly wiring. And figuring out what electric fan to use. And lots of other little things. And putting an interior back in it eventually
Bob is offline   Reply With Quote
Old 06-07-2009, 02:11 PM   #106
Bob
Away
Bob's Avatar
Been doing some wiring, making progress. I've actually really enjoyed the wiring process because it's fun to learn how all the different circuits work. It's just time consuming
I'm routing all of the headlight (both sides), turn signal, horn and power wires from the black plastic housing along the left strut tower and through the firewall hole underneath the hood pull cable. The hole was enlarged to 1". I'll wrap all of the those wires in expandable braided sleeving, so there is just one "main" accessory harness. I relocated the headlight relay and power block up by the radiator, to keep the fenders looking clean.
The wiper motor wiring is separated from the rest of the harness and enters just below the wiper motor. I'll run the starter, alternator, dash coolant temp, and oil pressure light/gauge wiring together beside the throttle cable. Then the MS and EDIS wiring will go through one of the large holes on the passenger side. Battery is all installed in the trunk, on the passenger side.
With any luck I'll be turning the key in the next couple weeks.
Old 06-07-2009, 05:36 PM   #107
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
This is what we like to hear.
definitely loom that up
looks good...but you're not using a grommet to go through the firewall??? Oh, and what's that dirty spot inside the hole on the inside of the passenger fenderwell in this pic? I sees pineneedles! I thought you were paying attention to detail...tisk tisk
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
Originally Posted by blkaplan View Post
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
Old 06-07-2009, 05:54 PM   #108
Bob
Away
Bob's Avatar
hah, everything will be loomed and grommeted. i just vacuumed out those pine needles before i even read your reply
Old 06-21-2009, 09:21 PM   #109
Bob
Away
Bob's Avatar
Well, I didn't work on the car for like 8 or 9 days because I had my college reunion, a bachelor party and was generally just enjoying the summer (not at my house). But now I'm back at it and hoping to have it running by the end of June. I mounted the MS box, relays, fuse block and KnocksenseMS, and started on the wiring.
I'm using stock Volvo power blocks. The bottom one pictured takes power from the battery and sends it to terminal 30 of the fuel pump (30A) and main (40A) relays. Then the top one takes power from terminal 87 off the main relay and then sends three wires to the fuse block, where they're fused appropriately for the MS box (2A) and 2 injector banks (5A each). I ran the stock fuel pump relay signal wire (blue/red, terminal 15) over, which switches on both the main and fuel pump relays when the key is in the run and crank positions. At least it's supposed to do that
It's probably overkill, but I wanted really clean power to everything, having heard about issues with MS sensitivity. For now I'm using the Ford EDIS module for ignition, but am going to mount that elsewhere in anticipation of upgrading at some point.
Now I have underhood wiring, figuring out how to mount the radiator overflow tank, getting the correct size drive belts to use with Dale's pulley, hooking up the wideband and a few other small things. Then it's startup time.
Old 06-22-2009, 01:50 PM   #110
Cameron
ドクターマリオ
Cameron's Avatar
Acrylic panel? Nice! Whole project is looking killer as usual. Taking the extra time now to properly sort the wiring will make any future trouble shooting soooooooo much easier!
Cameron is offline   Reply With Quote
Old 06-22-2009, 01:59 PM   #111
Bob
Away
Bob's Avatar
Thanks man, much appreciated. It's getting so close that it's killing me, I just have so many distractions (fun ones ) this time of the year...
Old 06-22-2009, 02:50 PM   #112
tjanson
tjanson's Avatar
Looks good, Bob.
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 07-12-2009, 04:48 PM   #113
Bob
Away
Bob's Avatar
Haven't turned the key yet, but still making consistent progress. Been busy this summer, but I've still been giving the car a lot of love This should be another good week.
Anyway...got the radiator overflow tank mounted behind the right headlight last weekend, among a few other things (set/checked TDC again, set 36-1 wheel position, got drive belts, fuel lines and some under hood wiring). The overflow tank sits a bit lower than the radiator, but I think it will be okay since the lower hose slopes downward all the way from the tank to the radiator.
Today I mounted a 100 amp breaker on the main battery cable, as well as a 20 amp fuse for my dedicated MS power line. I'm about to go out to the garage again and start building the under hood MS wiring harness, and then my EDIS wiring.
I built one wiring harness for the starter, alternator exciter, oil pressure sender, dash coolant temp and brake warning switch. It runs through the grommet originally used for the speedometer cable. This should motivate me to go T5 sooner than later. I have all of the Ford T5 swap parts, minus the gearbox itself and driveshaft. Also, I'm going to reroute the battery cable through the firewall on the driver's side.
My next big update should be the one where it runs...
Old 07-12-2009, 07:42 PM   #114
maxman142001
I like turtles
maxman142001's Avatar
Wow, placement of everything the bay is next to perfect....I hope the next project I have I will have this much attention to detail
Cant wait to see this thing run...turn the key!
as nothing is impossible with God, even turbo's fixing themselves
-2011 VW GTi
maxman142001 is offline   Reply With Quote
Old 07-12-2009, 09:44 PM   #115
RvolvoR
hrm...spent a lot of time making some stuff clean....but skipped over the details....
Old 07-12-2009, 10:49 PM   #116
spruill244
Mahalos
spruill244's Avatar
this build is awesome
Old 07-28-2009, 08:54 AM   #117
Bob
Away
Bob's Avatar
drumroll...
it runs. Started on the first try after maybe 10 cranks of the starter
The idle flew up to like 2300 rpm, so I need to figure that out. I'm not using an IAC, just the throttle body with the adjustment screw. Lots of tuning to ensue, but obviously I'm pretty happy.
Old 07-28-2009, 11:05 AM   #118
doucheNozzle
doucheNozzle's Avatar
drumroll...
Yay! Congrats! Now we just need some video proof. Oh and pics of course!
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 07-28-2009, 01:51 PM   #119
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
Nice dude, its a whole different feeling when you finally turn the key.
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
Old 07-28-2009, 01:59 PM   #120
Bob
Away
Bob's Avatar
I ran home at lunch and got the idle down to around 800 rpm by adjusting the throttle linkage. I can smell it running really rich, and I think I probably fouled the plugs because it wouldn't start again after a few brief runs. Going to pick up some 6's tonight (has 8's in it) and see if it starts again.
Definitely felt good to hear that smooth idle, and to feel some heat in that Bondo header
Old 07-28-2009, 06:36 PM   #121
Bob
Away
Bob's Avatar
Proof! Ran it for about 10 minutes, idling around 1,000 rpm. Good oil pressure, good coolant temp, seems pretty smooth. I'm going to get rid of the mechanical fan ASAP, it's just on there temporarily.
Old 07-28-2009, 06:42 PM   #122
Cameron
ドクターマリオ
Cameron's Avatar
Sounds good!
Old 07-28-2009, 07:27 PM   #123
Karl Buchka
Congratulations!
Old 07-28-2009, 10:52 PM   #124
1990_740turbo
JDM yellow fogs
1990_740turbo's Avatar
awesome car man. im thinking about doing FMIC in my car someday.
1990_740turbo is offline   Reply With Quote
Old 07-28-2009, 11:04 PM   #125
maxman142001
I like turtles
OMG! Nicest, practical 240 on the board FTW!
Awesome job!
