Old 06-11-2020, 09:34 AM   #551
Swedbrick
Swedbrick's Avatar
Originally Posted by MadDog_945 View Post
does anyone know what the pink/black cable is for?
IIRC It's a part of the AC system, for the purple high pressure switch, could possibly also be towards the bumper outside temperature sensor, which were green blue in the looms I've thinned down.
Nice progress!
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Old 07-20-2020, 02:09 AM   #552
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Thx !
Made some progress here and there..
Im just trying to figure out if i can use a BMW E39 Fuelfume Breatherbox instead of the OEM one, cause it is much more compact or if the valve is missing and i need a separate one or if im just uwsing the OEM box when i find a used one.
It is not far from its second first start up
Old 07-21-2020, 12:38 AM   #553
Finnish240
Finnish240's Avatar
I was planning to get one of those bodymount shifters, but ended up doing stock style shifter mount during m90 swap to my 240. Maybe some day if you get good results using one?
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
Old 07-21-2020, 02:35 PM   #554
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
it is awesome.. i found myself sitting in the car rocking through the gears making some turbowhistle and blowoff noises like a little child :D
it is pretty easy to adapt the oem shifterbag to fit it.. retropete send me the shifter to write a how to. 8t is pretty easy to install it and the gears kick in pretty tight
Old 07-21-2020, 02:48 PM   #555
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
found an oem fuelfume filter in my slaughterhorse ;) never saw that oem mountingbracket.. in my old car it was ziptied. seems it fits everything pretty well!
Old 07-27-2020, 06:44 AM   #556
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
- Driveshaft is in
- vacuum is fully done with a really nice vacuum block for small money
- fuelfume filter is also at its place and connected
- fuelsystem doublechecked for tight connections
- both front fender and firewallpanel installed and trimmed
- headlights installed
- passenger harness completed
- driverside wiringharness alomost completed -> it misses the starter and generator connections
- gearbox linkage secured with loctite
/edit
jeeeez.. the camera in my CAT S60 really gets ****tier every day...
Old 07-27-2020, 12:12 PM   #557
Old 07-28-2020, 08:32 AM   #558
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I will try to use my better Digicam for further Pics.. that really looks not that good anymore ;)
