Old 04-24-2011, 12:43 AM   #76
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
sweet, get familiar with it! Might just leave the 242 LH 2.4.
Old 05-09-2011, 06:29 PM   #77
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
hm, the nice factory radio has decided not to turn off when the car is turned off. but it only plays from the dash speakers. wtf.
Megasquirt Tuning!
Old 05-10-2011, 12:24 PM   #78
beepee
how hard can it be?
beepee's Avatar
no it's not, mine runs
I'll put the plugs back in mine, fill it with oil and drive it down to hickstown or whatever crazy hillbilly redneck place and cave your windshield in with an old fuel ECU
then you can sell me a built aw71
beepee is offline   Reply With Quote
Old 06-27-2011, 09:31 AM   #79
linuxman51
linuxman51's Avatar
got a set of hydras this weekend (Thanks Garrett!), and of course this has been a running testbed for maf-ms2.
While I'm swappin' wheels I might go ahead and throw the 25mm front swaybar on as well as the shocks and struts I've got laying around.
Old 08-05-2011, 09:10 AM   #80
linuxman51
linuxman51's Avatar
this thing is going to get operated on here soon, the transmission is.. le tired. went to move it after letting it sit the other day, and no dice in reverse. think I've got a bleed through on the internal seals in the piston or too much clearance on that last clutch pack. I've kinda known this was coming. I'll take the opportunity to upgrade a couple odds and ends in it, and do the accumulator mod as well. toying with going ahead and yanking the engine and trans at the same time, since I'd like to address some other issues on the car and it might just be easier to do things that way.
Old 08-05-2011, 09:31 AM   #81
boosted12a
weapon of mass detonation
boosted12a's Avatar
go for it!
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L, BLUE
10 335xi, (fun has a price), black
17 expedition El, (short bus), black
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
Old 08-06-2011, 12:27 PM   #82
linuxman51
linuxman51's Avatar
raided the junkyard, got some transmission parts. they'll probably just get shelved though til I make time to address this issue. still have to gather some other odds and ends before digging in (not to mention a ****in' $150 rebuild kit, jeeeez)
Old 08-06-2011, 12:27 PM   #83
linuxman51
linuxman51's Avatar
goddamn double P
Old 08-08-2011, 10:16 AM   #84
Kjets On a Plane
Kjets On a Plane's Avatar
Nice ride. I've noted a little flat spot on used air masses under load. "Fine" at idle, but odd flat spots elsewhere. Doesn't help that the foam that they put in the lid of the airbox on 90+ cars usually falls apart and does them in...they got rid of the pre-heat that did such a good job of that on 89- cars only to replace it with foam that falls apart after the air filter.
I keep a basically brand new bosch/volvo air mass around for testing. I'm sure you are familiar with this tho.
How PSI a stock can support?
Always Be Crushing!
Old 08-08-2011, 10:24 AM   #85
linuxman51
linuxman51's Avatar
it is always something, eh? the foam is still intact on mine, but it probably won't matter much longer.
Old 09-22-2011, 08:34 AM   #86
linuxman51
linuxman51's Avatar
rebuilt the trans (to km148 specs), added the accum mod as well as a slight modification of the separator plate. rolled in fine with the wheels off the ground, if the weather isn't **** after work I'll hook the kickdown cable up and give it a ride around the block to see if it's good or something is goofed.
Old 09-22-2011, 01:08 PM   #87
linuxman51
linuxman51's Avatar
also picked up this little guy for it:
will end up similarly different to the deathwagon 3 (same concept different execution and supporting cast)
Old 09-22-2011, 01:24 PM   #88
doucheNozzle
doucheNozzle's Avatar
16g?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-22-2011, 01:26 PM   #89
linuxman51
linuxman51's Avatar
yeah, evo 8 turbo.
Old 09-22-2011, 01:31 PM   #90
doucheNozzle
Siiiick dawg.
Old 09-22-2011, 02:05 PM   #91
linuxman51
linuxman51's Avatar
should produce epic amounts of torque, and maybe a little bit of horsepowers.
Old 09-22-2011, 05:22 PM   #92
linuxman51
linuxman51's Avatar
test drive with the rebuilt aw went well. woohoo. sucked up some extra fluid, drove it around again, and it seems to be happy. yay.
Old 09-25-2011, 06:46 PM   #93
ElBertoPolvo
i would prefer not to
ElBertoPolvo's Avatar
had to check in...wagon sounds like it is doing well.....!!
1988 244....rip 4-27-11
1993 945t...gone....in the hands of the lord (brett)
2006 chevy 1500...work slut
2013 ford fusion..1.6 eco-poot
This chick better have beer for anal flavored nipples. God daaaaaamn.
Originally Posted by kahlua240 View Post
I was about to masturbate then go to bed. This thread ruined that for me.
ElBertoPolvo is offline   Reply With Quote
Old 10-25-2011, 09:13 PM   #94
linuxman51
linuxman51's Avatar
shenanigans
Old 10-25-2011, 09:36 PM   #95
Texas240
Prius Owner
Texas240's Avatar
shenanigans
how about a side shot for us non-imaginary people
93 245 LS Engine Swap Project
Old 10-25-2011, 09:38 PM   #96
linuxman51
linuxman51's Avatar
Old 10-25-2011, 09:40 PM   #97
JohnMc
JohnMc's Avatar
Hey, is that one of my left over New Belgium beers?
I like the shens.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-25-2011, 09:41 PM   #98
Texas240
Prius Owner
Texas240's Avatar
I like the shens.
HAHA...... Only john would remember that from two weeks ago when at the time of being drunk. John, you can plea the fifth on this one
Old 10-25-2011, 09:45 PM   #99
740atl
educator monkey
740atl's Avatar
bastards! I have the turbo flanges and fittings, just need the piping... and waiting for the free weekend. I wanted to be the first!!!
what size pipe are you using? 1 1/2?
looks good!
Old 10-25-2011, 09:52 PM   #100
linuxman51
linuxman51's Avatar
I like the shens.
Maybe.
looks good!
sam's has been done for a while now. I may try and have this finished this weekend, but it'll probably be a couple of months before it's actually in the car. LOONG list of **** I want to do before hand.
