Old 10-25-2011, 09:53 PM   #101
Texas240
Prius Owner
Texas240's Avatar
sam's has been done for a while now. I may try and have this finished this weekend, but it'll probably be a couple of months before it's actually in the car. LOONG list of **** I want to do before hand.
I Know that feeling
93 245 LS Engine Swap Project
Old 10-25-2011, 09:56 PM   #102
JohnMc
JohnMc's Avatar
Originally Posted by Texas240 View Post
HAHA...... Only john would remember that from two weeks ago when at the time of being drunk. John, you can plea the fifth on this one
The next morning there were two sad little beers left in my cooler, so I stuck them in Kenny's so they'd have some company.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-25-2011, 10:01 PM   #103
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
ah, that probably wasn't one of them then, that particular companion came from a 6 pack. which just means I probably already consumed the others earlier :D
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 10-25-2011, 11:24 PM   #104
olov
doing something stupid
where are ya'll finding the flange for the end of the manifold?
Old 10-25-2011, 11:34 PM   #105
linuxman51
linuxman51's Avatar
which one?
Old 10-25-2011, 11:37 PM   #106
beepee
how hard can it be?
beepee's Avatar
Originally Posted by linuxman51;394c0951
you cheeky rat bastard
beepee is offline   Reply With Quote
Old 10-25-2011, 11:44 PM   #107
olov
which one?
the one at the end of the manifold - start of the up pipe. just cutting off the stock exhaust and re-using the flange? cutting it yourself? or does someone sell them?
Old 10-25-2011, 11:47 PM   #108
linuxman51
linuxman51's Avatar
I had it made. sam used one from an na downpipe and felt it was a little too thin. shouldn't be a really big deal to get someone to cut a couple out.
Old 10-28-2011, 02:12 AM   #109
I wanna see how this J-pipe dealio works.
Old 10-28-2011, 06:18 AM   #110
Trevor+
Volvo Friends
Trevor+'s Avatar
You connect the manifold to the hotside via a steel tube.
Then blow
Trevor+ is offline   Reply With Quote
Old 10-28-2011, 10:26 AM   #111
No ****. I meant how effectively it would work
Old 10-28-2011, 10:50 AM   #112
linuxman51
linuxman51's Avatar
does well on sam's 8v. my fab skills blow ass though, first time for everything I guess. shoulda started with the rear runner and then moved to the front runner.
Old 10-30-2011, 08:04 PM   #113
linuxman51
linuxman51's Avatar
tacked up for a test fit on an 8v (fit well. I'll post those pics later)
going together, a showcase in ****ty welds:
both runners on there, even closer view of ugly welds
and welded up. bolted it back together and re-welded the support brace and let it sit and cool off
still have to smooth out the ends where I welded both on the inside and out. ding in that pipe was the result of grabbing the wrong hammer. meant to get the deadblow, oh well. I'm going to smooth the welds down a little bit and wrap the pipe, so it won't matter much as long as it doesn't leak.
Old 10-30-2011, 09:12 PM   #114
linuxman51
linuxman51's Avatar
smoothed out the ports and played with some new bits I bought last week.. they work great, woohoo.
Old 10-30-2011, 09:34 PM   #115
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
mild steel wire? stainless is hard to grind.
Old 10-30-2011, 10:26 PM   #116
linuxman51
linuxman51's Avatar
yea, regular mig wire. it'll rust, but like I said above, it's going to get wrapped.
Old 10-30-2011, 10:28 PM   #117
DNAsEqUeNcE
†John3:16
word, so who cares
Old 10-30-2011, 10:59 PM   #118
Texas240
Prius Owner
Texas240's Avatar
Since when?
Old 10-30-2011, 11:26 PM   #119
DNAsEqUeNcE
†John3:16
Since when?
since building very expensive stainless steel downpipes
Old 10-31-2011, 08:49 AM   #120
linuxman51
linuxman51's Avatar
test fit pics. if it doesn't work out like I want, I can re-purpose it for 8v use and pass it off one one of you bricksters.
side view:
not bolted up yet either, so a bit more vertical clearance.
Old 10-31-2011, 10:17 AM   #121
linuxman51
linuxman51's Avatar
Originally Posted by Roy 940 View Post
Very nice job, but shorter is the header, better it is...
I'm not sure that I'm inclined to believe that. the stock turbo manifold is short as hell and it sucks the sweat off a dead guy's sack
Old 10-31-2011, 10:55 AM   #122
740atl
educator monkey
740atl's Avatar
Yeah. No.
Old 10-31-2011, 11:45 AM   #123
olov
i was told short for high rpm power, long for a broader range.
looking good, i want one now
Old 10-31-2011, 11:46 AM   #124
linuxman51
linuxman51's Avatar
Originally Posted by 740atl View Post
Yeah. No.
they're all generalisms. if short was good for high rpm power, log manifolds wouldn't suck so bad.
ordered a bunch of seals and gaskets and ****, $350 after the coupon at fcp.
Old 10-31-2011, 12:02 PM   #125
olov
i think the crappy collector negates logs from the discussion
