Old 06-18-2012, 11:26 PM   #201
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
discovered a WOT issue, one of the hoses is collapsing just about the time this thing should be getting fun (around 4500). not sure which one yet, could be either of the intercooler couplers or the jackleg throttlebody coupler. will spend some time ****ing around with that issue after I get back in town.
Got the ostrich on the car, started dorking around with the tune. regained some of the lowend torque, and it cruises effortlessly around 60, practically zero throttle input. A/c is also working fabulously. valve cover still leaks, damnit, but at the moment everything else appears to be functioning correctly.
Megasquirt Tuning!
Old 06-18-2012, 11:35 PM   #202
klr142
Turbo, what?
klr142's Avatar
Correctly is good!
Old 06-19-2012, 07:02 AM   #203
550
OOO! Me too!
...hey wait a second
I'll get a couple after work. not much to look at right now.
Me three!
10-4
I figure the dyno vids will be nothing short of impressive.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 06-19-2012, 09:18 AM   #204
linuxman51
linuxman51's Avatar
impressively boring maybe. course, we don't have a dyno right now, so it'll be a while. I should walk outside and get a couple of pics.
Old 06-19-2012, 10:51 AM   #205
linuxman51
linuxman51's Avatar
here's some pictures of this collection of horse****.
960 brake booster
dolphin wouldn't fit down in that hole for the breather, so I was forced to use a plastic bottle for the time being.
corrected belt alignment
and the disappointment of NA
this would work a whole lot better if the amm was on the driver's side and I wasn't drawing through the intercooler. I may work on that, but it'd be a temporary thing since it will be turbocharged before long.
Old 06-19-2012, 12:24 PM   #206
940guy
940guy's Avatar
how did you correct the belt alignment?
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 06-19-2012, 12:47 PM   #207
linuxman51
linuxman51's Avatar
PFM.
Old 06-19-2012, 02:10 PM   #208
doucheNozzle
doucheNozzle's Avatar
So how much HP did you gain with the IC?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-19-2012, 02:20 PM   #209
linuxman51
linuxman51's Avatar
it's probably costing me right now.
Old 06-19-2012, 02:23 PM   #210
doucheNozzle
But the internet sayz it works
Old 06-19-2012, 02:27 PM   #211
linuxman51
linuxman51's Avatar
cool off ambient air to ambient temps.
Old 06-19-2012, 02:33 PM   #212
doucheNozzle
oh and DEI. Can't forget the DEI. That's what I thought Sam was building his Kludge pipe for.
Old 06-20-2012, 07:27 AM   #213
550
It's so...
It's so BEAUTIFUL!
What Turdblow are you running again?
Old 06-20-2012, 07:44 AM   #214
linuxman51
linuxman51's Avatar
evo 8 16g.
Old 06-20-2012, 08:01 AM   #215
Super Matty P
Bear Juden ist eine Golum
Super Matty P's Avatar
That E-fan freed up a lot of space there between the block and radiator. Looking good!
What do expect the performance gains to be between this 16v set-up you're going to be running and the exact same set-up with an original 8v head?
Originally Posted by Lord Tentacle View Post
That's like real money
Try finding a running one without a dead Asian in it for $500
Super Matty P is offline   Reply With Quote
Old 06-20-2012, 08:35 AM   #216
550
Will be nice to see how that goes. I mean, that shoud be a *real easy* 300 wheel HP right?
Old 06-20-2012, 08:38 AM   #217
linuxman51
linuxman51's Avatar
the e-fan is oe on the 940, but it does make for more space. the intercooler mounting underneath the crossmember in the front also frees up space vs the older style.
the car should easily make 300hp without leaning on it hard, I'm just going to have to put a zipper on the bellhousing to keep fresh aw71's in there ;)
Old 06-20-2012, 08:42 AM   #218
550
If you do indeed start blowing through them that quickly, are you going to swap to manual, or maybe find a different autobox to use?
Old 06-20-2012, 08:42 AM   #219
550
Old 06-20-2012, 09:23 AM   #220
linuxman51
linuxman51's Avatar
I'll have to cross that bridge when it starts to happen, I'm not really sure. the first thing I'll probably do is go in and add more clutches like I did for the transmission in the deathwagon 3. I also don't plan to turn it up much higher than the 8v, so hopefully that won't put quite as much strain on it as I did with the older car.
Old 06-20-2012, 01:08 PM   #221
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Are you using the stock intercooler?
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 06-20-2012, 03:03 PM   #222
linuxman51
linuxman51's Avatar
sure why not
Old 06-20-2012, 03:18 PM   #223
WindowsBreakerG4
IIRC it has no fins inside so it's kinda lacking. If you ever want an upgrade Evo 8 IC works well and they're cheap. (harald put one in his car).
Old 06-20-2012, 03:26 PM   #224
linuxman51
linuxman51's Avatar
yeah. i've got a plethora of options at IC should I decide to ditch the 940 unit. when I get ms on the car, it'll answer questions about how well the thing works.
Old 06-21-2012, 08:48 AM   #225
linuxman51
linuxman51's Avatar
I'm thinking pvc running across the front of the engine bay to bypass the intercooler. this sucking shut at 4500 **** has got to go.
also need to adjust the kickdown, it's 'lazy' right now (probably a difference in spools there, the aw72 has a different 'cam' on the valve body), wouldn't be so bad if it'd turn up but it won't. also need to get the last 2k tuned out. fuel map is a little jacked up still, but hey. going to start fabbing up the stuff for the ms install when I get back in town.
