Old 06-23-2012, 11:11 PM   #51
smokeyfan1000
Guest
For the money & longevity, and decent sound(not too quiet/not too loud) I say magnaFlow straight through muffler.
I'm running two on my n/a 240.
Old 06-24-2012, 10:37 AM   #52
g3mccotter
Originally Posted by falunbrick View Post
here you go
That sounds amazing. 4" dp and 3" straight all the way back?
g3mccotter is offline   Reply With Quote
Old 06-24-2012, 01:29 PM   #53
cosbySweater
cosbySweater's Avatar
fake cat and the magnaflow that was on there in the other video
1995 Porsche 993
2013 VW Passat TDI
Old 06-24-2012, 04:21 PM   #54
blackv
spintech muffler
blackv is offline   Reply With Quote
Old 06-26-2012, 05:15 PM   #55
542
anyone have any thoughts on the IPD sport exhaust kit?
http://www.ipdusa.com/products/5608/...n-turbo-models
or are better results found by using any of the above suggestions for aftermarket mufflers and cutting out the first resonator?
Gord
542 is offline   Reply With Quote
Old 06-26-2012, 09:23 PM   #56
mrpie
mrpie's Avatar
Here's my setup. Minus turbo though :(
Sounds like poop. Angers the neighbors. Makes me grin.
It's basically stock 2.25" header back w/cat + modified glass-pack w/3" stainless tip or might be 2.5". I got bored and started cutting lol.
First clip is the same setup with a cheap-o turbo muffler that was on when I got it.
mrpie is offline   Reply With Quote
Old 02-02-2020, 11:05 PM   #57
bennyg
Default magnaflow
anyone have a model number for the right magnaflow ,I have a 3 " downpipe and gonna go 3 inch all the way so as best I can tel an 18' magnaflow w3 ' center in/out will do the trick , anyone have any other suggestions /
bennyg is offline   Reply With Quote
Old 02-02-2020, 11:12 PM   #58
2turbotoys
Salaminizer once again
2turbotoys's Avatar
Ya, use Cherry Bomb Vortex instead. Much thicker metal, about $35 each, outlasted my Magnaflow by several years
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 02-02-2020, 11:17 PM   #59
bennyg
Default cherry bomba
I dont see a 3" center in/out vortex ,those bombas are 1/3 price of a magma blow / !
Old 02-03-2020, 07:01 PM   #60
lummert
lummert's Avatar
The longest that will fit in the available space.
Old 07-30-2020, 02:06 PM   #61
Awaffa2003
Default Raspy as a smoking grandma
Bringing this back to satisfy the search Nazi's...
IPD sport exhaust just rusted through. Running NA B21, B cam, 2.25 exhaust, w/cat. Ended up replacing the IPD muffler with straight through Magnaflow, and I don't mind the volume, but I can't stand the rasp. Anyone have a suggestion for resonators that will remove that harsh rasp?
Awaffa2003 is offline   Reply With Quote
Old 07-30-2020, 05:15 PM   #62
mikep
The MP
mikep's Avatar
Only worrying about tone? Any glasspack anywhere before the muffler.
Always this. Shawty do drone.
Old 07-30-2020, 05:33 PM   #63
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
I've wondered this too cause I LOVE turbo spool sound but could go without the raspy diesel sound
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 07-30-2020, 06:21 PM   #64
culberro
culberro's Avatar
For NA, I like a single "turbo" muffler or offset magnaflow. They both usually have some sort of fiber filling which really helps with drone.
For turbo, a simple resonator or glass pack (a good one!), or even a short magnaflow is fine.
Old 07-30-2020, 07:40 PM   #65
For the turbo I use a single rear mounted round 3" magnaflow SS. It makes a nice sound. Has a full 3" system from engine back.
The wagon has a simons sport system which helps a bit but isn't performance as it's the same 2" as stock. Just mandrel bends and better flowing mufflers.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 07-30-2020, 07:46 PM   #66
122power
dude
122power's Avatar
Flowmaster , what else lol.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
122power is online now   Reply With Quote
Old 07-30-2020, 10:50 PM   #67
Awaffa2003
Well I think the Magnaflow (my muffler) is a glasspack. You can see straight through it.
Would ANOTHER glasspack help then?
Old 07-31-2020, 01:25 AM   #68
GeneralBurrito
GeneralBurrito's Avatar
I'm NA with the 60mm exhaust from a turbo model with a Magnapack in place of the muffler. Sounds great, would be better with a turbo to muffle some of the slight rasp at 6k rpm.
Old Yesterday, 10:45 AM   #69
Fred Gwynne
I had a flowmaster 40 on my E30 325iS. The tone seem pretty mild. It really just sounded like the factory muffler but a good bit louder. Like a loud hairdryer but that was likely because of the engine itself. Almost too smoooooth.
Fred Gwynne is offline   Reply With Quote
Old Yesterday, 09:08 PM   #70
mikep
The MP
mikep's Avatar
There’s only one way to find out.
Old Yesterday, 11:40 PM   #71
Awaffa2003
True! But I was thinking more along the lines of a resonator. Same concept I suppose, but specifically, a resonator. Vibrant has some that are interesting.
Old Today, 01:43 PM   #72
Dirty Rick
Dirty Rick's Avatar
I have been told that the offset (staggered) mufflers reduce drone better than straight through.
Old Today, 03:18 PM   #73
Cwazywazy
Single jingle
Cwazywazy's Avatar
Magnaflow flowmaster big chambered thing in the back and Vibrant straight through resonator in the stock spot. Spools faster than my old turbo muffler and it's quieter.
I don't know what I have
