Old 09-24-2012, 01:21 PM   #101
B-lennium
[ignorant] would't the s80 v8 be a bolt on swap?[/ignorant]
Volvo 164e B30e, Megasquirt MSII extra
B-lennium is offline   Reply With Quote
Old 09-24-2012, 01:31 PM   #102
Cameron
ドクターマリオ
Cameron's Avatar
Same either way I believe.
My understanding (smothered in assumption) is that all the subframes from the P2s share attachment points/dimensions with how they bolt to the car - just different "internally" for each motor/trans combo in how the combo is mounted to the subframe. That one I posted is using the subframe from the XC90, but the control arms from the XC70 (control arms bolt to the subframe). All the V8s in the S80s and XC90s were all AWD with the TF-80SC AWD trans.
OK, I'm done derailing thread
Cameron is offline   Reply With Quote
Old 09-25-2012, 01:51 AM   #103
BassGuy
BassGuy's Avatar
I think the lift is fine on that XC70, just the wheels (rim/tire size) are off.
It's amusing that it's trailered, when it has that V8 underhood.
2003 Volvo XC70
1991 945GLE - 16v Wagon! (in pieces)
1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably
1987 760 Turbo Intercooler - dead 07/14/2011
Feedback Thread
BassGuy is offline   Reply With Quote
Old 10-05-2012, 08:53 PM   #104
spourcyrous
Cool stuff guys. I love coming home to see threads like this after a long day. True automotive-porn.
S
spourcyrous is offline   Reply With Quote
Old 10-14-2012, 08:23 AM   #105
Karl Buchka
S
Thank you!
Got some more work done on the clutch/flywheel package. The reverse mount ring gear we're using is intended for a newer 7.25" cover than what we have, so the cover needed a small amount of material removed from the OD.
Alex started by mounting the cover on the flywheel and clamping the flywheel in the soft jaws:
Checking for runout:
Turning down the OD:
Fits like a glove now. You can just barely glimpse them, but there are small alignment tabs on the bottom of the ring gear that keep it concentric with the clutch cover.
Next up: trigger wheel. It's going to be a 60-2 mounted on the starter ring gear
Found a perfect steel pipe on the material rack. Unfortunately it was pushing the limits of what fit in the horizontal band saw, so we had to get a little creative.
Almost through. We didn't trust the clamp completely, so we kept the feed low. I think it took about 15 minutes to make this one cut.
This is the part after the first setup:
Re-setting the soft jaws:
This is as far as Alex got last night. The clock struck midnight and the lathe turned back in to a pumpkin. The trigger teeth are getting cut out of that standing ring section and the other ring with the tapered step will get reduced to a few mounting ears that will bolt to the starter ring gear. Projected weight of the trigger wheel is about 150 grams.
Old 10-14-2012, 09:21 AM   #106
550
Pictures of raw materials being turned into "stuff" -- Giggity.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 10-14-2012, 07:34 PM   #107
Homer
OEMplus++
Homer's Avatar
A+ #1 would machine again.
-Jacob:
2017 allroad - Comfy DD
Old 10-17-2012, 02:42 PM   #108
klr142
Turbo, what?
klr142's Avatar
That's a big pipe.
Old 10-17-2012, 02:57 PM   #109
dbh86
What's a 16V?
dbh86's Avatar
The Swedish Navy called, they want their gun barrel back...
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 10-18-2012, 08:06 PM   #110
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Ran the (soon to be) trigger wheel through the CNC to carve out the mounting feet:
Hopefully the final result is becoming clearer. The trigger teeth will get cut out of the remaining solid ring. The step on the feet centers on the ID of the starter ring gear. The taper on the inside has to be there in order for the trigger wheel to clear the Tilton clutch cover, and helps cut a little bit of weight.
Weight so far (300 grams, ~10.5oz):
Old 10-18-2012, 08:10 PM   #111
Homer
OEMplus++
Homer's Avatar
So that just went through the cnc? Is there a conveyer belt like a car wash?
Old 10-18-2012, 08:35 PM   #112
Alex Buchka
8 cylinders
I just showed the machine a picture of what I wanted and it took care of the rest.
Old 10-19-2012, 07:04 AM   #113
Johann
Johann's Avatar
It ran
Johann is offline   Reply With Quote
Old 10-19-2012, 09:33 PM   #114
Alex Buchka
8 cylinders
Got some more work on the trigger wheel today.
Hoisted the dividing head off the shelf and set to cutting the trigger pattern in the manual mill.
Unfortunately, the above picture is about as far as we got before things went pear shaped. We fought a few different issues for a while, and when we finally made it to the last slot, it became apparent that the teeth were not evenly divided. I think the trigger wheel had been slipping imperceptibly, so by the time we got to the end, it was too late. Definitely a drag, but such is life. Gentlemen, we can rebuild it. We have the technology. Better than it was before. Better...stronger...faster.
Old 10-20-2012, 02:37 PM   #115
towerymt
the real Towery
towerymt's Avatar
Looks close enough. Ship it out!
Old 10-20-2012, 02:48 PM   #116
Mueller
Mueller's Avatar
Looks great, any worries of the teeth deflecting during high rpm spinning?
Old 10-20-2012, 03:02 PM   #117
adrianpike
adrianpike's Avatar
Make sure and deburr it first though!
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 10-20-2012, 04:39 PM   #118
Group A
240 Ninja
Group A's Avatar
What's with the flywheel issues lately? John V's disaster, RSI got a small batch from machinist with mis-alinged notches and now you guys too?!?
- Patrick Dickman
"dumb enough to start and stubborn enough to finish" - Karl Buchka
"I'm not Willy Wonka, I don't sugar coat shlt."
Group A is offline   Reply With Quote
Old 10-20-2012, 04:43 PM   #119
Jerd
Jerd's Avatar
Not even funny.
maybe a little...
Old 10-20-2012, 04:43 PM   #120
Karl Buchka
Thanks! I'm not too concerned about it. The teeth are 3mm thick, around 6mm wide, and only 12mm long.
Haha, you obviously aren't paying attention. The flywheel Alex made is perfect. This is just a trigger wheel snafu.
Old 10-20-2012, 05:26 PM   #121
Group A
240 Ninja
Group A's Avatar
All trigger issues...
Old 10-23-2012, 12:18 AM   #122
BassGuy
BassGuy's Avatar
Alex made the flywheel, you made the trigger wheel?
Old 12-25-2012, 04:07 PM   #123
Alex Buchka
8 cylinders
One hole is offset by a few millimeters. Yamaha engineers can eat a dick. But hey, why make things easy when you can make them hard?
Old 12-25-2012, 04:14 PM   #124
towerymt
the real Towery
towerymt's Avatar
How many times did you measure? One more for good measure.
What's the plan now? die grinder?
Old 12-25-2012, 04:53 PM   #125
I guess its cheaper then a dowel pin...
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
