Old 12-27-2012, 11:21 AM   #151
Karl Buchka
Replacement MS main board. Takes an MS3 processor. Has hardware for 8 spark outputs, 8 injector outputs, four cam VVT, dual map sensors, six wheel speed inputs, real time clock, knock sensor interface, spots for two SLC DIY wideband drivers, on board CAN I/O expander with 16 analog inputs and 8 digital inputs, and waterproof automotive grade connectors. There's a bunch of other stuff in there as well. It's a long list.
Not available, not for sale, so don't ask.
Old 12-27-2012, 11:31 AM   #152
towerymt
the real Towery
towerymt's Avatar
Good, I didn't want one anyway.
Old 12-27-2012, 11:45 AM   #153
JohnMc
JohnMc's Avatar
Plus those white plastic electrical connections aren't going to work anyhow.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 12-27-2012, 05:39 PM   #154
njbrickwithboost
njbrickwithboost's Avatar
Awesome...Good luck with the build
Originally Posted by Pennybridge Pioneer View Post
It's upsetting that Stanley has stolen the title of biggest toolmaker from b4_ford's parents...
Originally Posted by miguels244 View Post
you live in New Jersey and that's the worst you can come up with to bitch about?
^In reply to "i hate the snow here"
-1998 V70 XC: Sirius setup : Whelen LED's : 221k Daily
--1995 Dodge Ram Van 3500 5.9L V8 145k Hauler: Party Van
VOLVO FAMILY-4-Life
njbrickwithboost is offline   Reply With Quote
Old 12-28-2012, 02:55 PM   #155
Karl Buchka
What's better than a B8444S?
Two B8444S's.
This second motor is most definitely trashed to some extent. Looks like the previous owner drove it with a bad balance shaft bearing and popped the timing chain. Not sure how badly the top end is damaged, but we'll be tearing it down shortly. Should make for a great mock-up engine and extra parts source. It also came with a few boxes of crap and a complete transmission (woo!).
Thanks!
Old 12-28-2012, 10:11 PM   #156
FlyingTog
B6304 douche
FlyingTog's Avatar
Cool beans. I'm glued to this build thread. Good stuff, guys!
Just a 960 bumper returning to its original form.
97 965R M90 My car! It's Purple! 267K+! 15.66@89.14
83 Group A 242. 7k+ original miles. Long term project.
98 V90 Parts car. Olive Green. 197K+
98 V90 Parts car. Tropical Green. 177K+
59 Austin Healey Bugeye Sprite. Project car.
94 Miata. Weekend car with 66K+ original miles!
94 Miata. LeMons project.
960 build thread: http://forums.turbobricks.com/showthread.php?t=231763
FlyingTog is offline   Reply With Quote
Old 12-28-2012, 10:21 PM   #157
Karl Buchka
Got it fully torn down. Block, crank, rods, and pistons look pretty good. Other than that, it's fairly wasted.
The failure mode was fairly obvious once we got the balance shaft out. Rear balance shaft bearing seized up and fell apart, leading to failure of the front balance shaft bearing. Once the shaft was unable to spin, the sprocket sheared off and the timing chain suffered... shall we say "spontaneous catastrophic disassembly". The chain cracked the oil pump housing and broke one of the tensioners. Also found some bent valves.
Haven't looked too closely at anything yet, but first impressions of the design are good. The castings look to be very high quality and the designers have clearly gone to some lengths in order to make a compact and light weight engine.
Old 12-29-2012, 12:01 AM   #158
BassGuy
BassGuy's Avatar
I saw "two" and I was all HELLS YES
2003 Volvo XC70
1991 945GLE - 16v Wagon! (in pieces)
1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably
1987 760 Turbo Intercooler - dead 07/14/2011
Feedback Thread
BassGuy is offline   Reply With Quote
Old 12-29-2012, 11:45 AM   #159
doucheNozzle
doucheNozzle's Avatar
After seeing the balance shaft failure, are you going to try and eliminate that?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 12-29-2012, 11:56 AM   #160
Karl Buchka
Yes, we're going to eliminate the failure by installing a new bearing. The shaft is staying. I don't see a good reason to remove it.
Old 12-29-2012, 12:11 PM   #161
Volvorules
Has a Built Trans!
Volvorules's Avatar
Scotty, the balance shaft failure was caused by water intrusion into the V of the engine. At the rear, the bearing is a sealed unit, and the water would collect and cause the bearing to rust and fail. There is a bulletin from Volvo on drilling a drain hole for the water so that it can no longer fill up the valley and damage the bearing.
Awesome that you got 2, Buchkas! Gonna be epic when you're done for sure. Hope I'm still alive to witness it...
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 12-29-2012, 12:13 PM   #162
doucheNozzle
What would you know RP? It's not like you work on them or something
Old 12-29-2012, 03:40 PM   #163
M.H. Yount
M.H. Yount's Avatar
Water from condensation inside the motor?
Old 12-29-2012, 06:33 PM   #164
Volvorules
Has a Built Trans!
Volvorules's Avatar
No, water from washing the engine, etc. It would have to be quite a bit of water, but it just pooled and had nowhere to go.
Old 12-30-2012, 06:55 PM   #165
satanburns1
Satanburns2
satanburns1's Avatar
Originally Posted by volvorules View Post
scotty, the balance shaft failure was caused by water intrusion into the v of the engine. At the rear, the bearing is a sealed unit, and the water would collect and cause the bearing to rust and fail. There is a bulletin from volvo on drilling a drain hole for the water so that it can no longer fill up the valley and damage the bearing.
Awesome that you got 2, buchkas! Gonna be epic when you're done for sure. Hope i'm still alive to witness it...
drill the hole!!!
satanburns1 is offline   Reply With Quote
Old 12-31-2012, 11:56 AM   #166
Karl Buchka
Thanks, Rob! We're pre-emptively adding wheelchair access to the car so we can finally drive it when we're all old and decrepit.
Dropped the engine in the bay last night. It's within a few millimeters of the intended position. Looks like the cowl area is going to need some modifying to fit the intake manifold. Firewall will also come back a bit to make room for the coolant manifold that bolts to the back of the heads.
The front two cylinders line up with the front axle centerline. Not quite mid engine. :(
This pic shows how the exhaust ports are offset from the ports. The front one is especially bad. "Fixing" it would be a pretty ****ty task that neither of us is interested in doing. Hopefully we can get a head on a flow bench to see how it matches the other ports.
Old 12-31-2012, 12:03 PM   #167
CMillet86
That thing is extremely similar to a Cadillac Northstar.
1991 245 Bright Red, +t with 15g on 15 PSI, AW71L Accumulator mod and a big ass tranny cooler. 3" Stainless Turbo back. DW300 Fuel Pump, RS500 Intercooler, Microsquirt V3 with LQ coils.
CMillet86 is offline   Reply With Quote
Old 12-31-2012, 12:08 PM   #168
Group A
240 Ninja
Group A's Avatar
Not much 240 left. You should just rename the car.
- Patrick Dickman
"dumb enough to start and stubborn enough to finish" - Karl Buchka
"I'm not Willy Wonka, I don't sugar coat shlt."
Group A is offline   Reply With Quote
Old 12-31-2012, 12:10 PM   #169
Karl Buchka
Is it? Any good Northstar pics around?
I'm open to suggestions.
Old 12-31-2012, 12:14 PM   #170
M.H. Yount
M.H. Yount's Avatar
It has morphed from a brick - to a cinder block.
Old 12-31-2012, 12:24 PM   #171
M.H. Yount
M.H. Yount's Avatar
Just to the left of the 'front' exhaust port in the last pic above are two bosses/holes where something attached. Was making room for that accessory the reason they moved that port rearward? (talking about the 2 larger holes, to the 2 smaller over/under ones....) Both heads configured similarly?
Old 12-31-2012, 12:32 PM   #172
Karl Buchka
Yeah, it's to make room for the water pump and alternator. You can see the water pump here:
Old 12-31-2012, 12:35 PM   #173
towerymt
the real Towery
towerymt's Avatar
MikeP had a northstar on a stand forever...probably still does??? Ask him
Old 12-31-2012, 02:27 PM   #174
poulrais
poulrais's Avatar
http://www.google.ca/search?num=10&h....1.cgjFXMHSscA
Happy New Year!
1990, Volvo 740 16v +T
Old 12-31-2012, 03:00 PM   #175
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Originally Posted by poulrais View Post
Thank you for the useless post.
