Old 01-10-2013, 01:52 AM   #201
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Thanks Pat. The tube sizes and basic geometry are from the FIA Group N manual. Not building it to fit into any certain racing class, just trying to make a safe cage that won't become a box of spears in the event of a roll-over or collision.
Old 01-10-2013, 10:17 AM   #202
gdogg16
You're a Subtotal
gdogg16's Avatar
awesome.
Greg
'66 Locort
'72 Fulvia 1600HF Lusso
'74 142
'83 911SC
'99 2500 Ram
'13 TDI Sportwagen
'15 TDI Sportwagen
gdogg16 is offline   Reply With Quote
Old 01-11-2013, 02:05 AM   #203
Alex Buchka
8 cylinders
More tubes:
The tube that goes across the front of the windshield is bent and notched, just needs a little more trimming to fit in. The first batch of DOM tube is now all used on the car. Probably going to need an extra 60-80ft to finish up the entire cage structure.
Old 01-11-2013, 03:21 AM   #204
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
FYI, you really should grind the fishmouths back until they are full thickness. Welding them like that, you either need to back way off on the pedal in order to not burn the edge of the tube away because it is so thin, which means the effective weld cross section and tube wall thickness of that part of the joint is much less than nominal. Or, you have to "chase" the melting away edge around the pipe which is also not great.
Awesome to see progress though!
Originally Posted by Alex Buchka View Post
More tubes:
-Kenny
Old 01-11-2013, 03:52 AM   #205
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
how do you bend the tubes?
Siliconesand and Fire? Or do you have a bender?
Old 01-11-2013, 10:24 AM   #206
Alex Buchka
8 cylinders
Thanks for the tip Kenny. I've encountered both of those issues before. I just don't do much tube fitting so grinding the fishmouths back never occurred to me. *facepalm*
JD-Squared Model 3. It's a really high quality machine.
http://jd2.com/p-32-model-3-bender.aspx
Old 01-11-2013, 11:11 AM   #207
M.H. Yount
M.H. Yount's Avatar
Bit of a change of subject -- do opposing pistons share a common crank throw (odd-fire) or is it an even-fire crank? I know there's a balance shaft to deal with the 60 degree/V8 dynamic balance issues, I assume it's also odd fire and the balance shaft deals with that also. All of that to ask -- what's the exhaust note sound like on one of these?
Old 01-11-2013, 11:47 AM   #208
Karl Buchka
The crank pins are split, making it even fire. You can see the pins here:
This is the best exhaust video I've been able to find. I think it sounds good.
Noble M600 videos aren't really indicative because of the turbochargers.
Old 01-11-2013, 03:04 PM   #209
M.H. Yount
M.H. Yount's Avatar
Does sound nice - bit higher pitched and dare I say more exotic than a 90-degree V8 without a flat plane crank ('domestic' V8).
Old 01-11-2013, 07:26 PM   #210
Volvorules
Has a Built Trans!
Volvorules's Avatar
I've heard the V8 uncorked a few times, when replacing cat-back exhaust systems on them at the dealer. Sounds pretty bad ass, unfortunately couldn't drive it around like that, but revving it sounded wicked. Really wanted a Bertone that sounded like that...
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 01-13-2013, 11:31 PM   #211
Alex Buchka
8 cylinders
I couldn't help myself so I hung the front wheel on there with a piece of string. It's a little too high where it's sitting but it paints a good picture. Gave me a real boost of motivation.
Measured the cams:
Old 01-13-2013, 11:38 PM   #212
Josh
lookin good
Josh is offline   Reply With Quote
Old 01-13-2013, 11:46 PM   #213
550
Dat's epic.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 01-14-2013, 12:37 AM   #214
towerymt
the real Towery
towerymt's Avatar
Dice not hangin...
Old 01-14-2013, 02:12 AM   #215
Group A
240 Ninja
Group A's Avatar
Hang a door and fender on it so I can use it as a desktop
- Patrick Dickman
"dumb enough to start and stubborn enough to finish" - Karl Buchka
"I'm not Willy Wonka, I don't sugar coat shlt."
Group A is offline   Reply With Quote
Old 01-14-2013, 02:33 AM   #216
towerymt
the real Towery
towerymt's Avatar
Fin
Old 01-14-2013, 03:21 AM   #217
Group A
240 Ninja
Group A's Avatar
Old 01-14-2013, 05:57 AM   #218
volvobrage
This car will look AMAZING!
volvobrage is offline   Reply With Quote
Old 01-14-2013, 11:28 AM   #219
Ryan_R
Cool! Any pics of the balance shaft wackiness?
Thanks!
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
2011 XC60 3.2L AWD - Wife-mobile
Ryan_R is offline   Reply With Quote
Old 01-14-2013, 11:45 AM   #220
JohnMc
JohnMc's Avatar
Dice not hangin...
Aero testing.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-14-2013, 06:52 PM   #221
Poik
Backwards Turbo
Poik's Avatar
Nice fitment on those tubes.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 01-14-2013, 07:13 PM   #222
satanburns1
Satanburns2
satanburns1's Avatar
Thanks!
-Ryan
You dont ever want to see deep enough inside to get into that balance shaft. Just plain no fun to do in the car & they dont pay you to pull it out. Im jealous that he gets to really play with a b8444s. We dont see to many thru the shop. I can confirm that they sound nasty w/o the exhaust hooked up. You have to drop a section to replace the rack on a XC90. Always get started before i reinstall.
I'll assume you are going to fab an intake to rework the stock ETM being at the rear. And that dopey 3200RPM intake runner switchover. Very nice build.
satanburns1 is offline   Reply With Quote
Old 01-14-2013, 09:46 PM   #223
pwschuh
Rolling...
Nice fitment
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 01-14-2013, 10:30 PM   #224
M.H. Yount
M.H. Yount's Avatar
I believe the phrase he meant to use was 'a nice level of fitivity.'
Old 01-14-2013, 10:33 PM   #225
gross polluter
They see me trollin'
gross polluter's Avatar
Measured the cams:
Wow. So simple. I need to do this to the stock GTE VVTi cams to figure out what they're closest to since nobody seems to have info on those cams. Pretty neat for basic tools.
