Old 12-22-2019, 03:20 PM   #401
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Watched it and it was pretty awesome. You have done an amazing job on this car.
Old 12-23-2019, 12:01 AM   #402
xorox_88
Originally Posted by cosbySweater View Post
Does that guy scream as much in real life as he does on his donut media videos?
the dude you talking about had a heart attack , its some other guy there but my guess he will chill with the ''screaming'' in future videos
xorox_88 is offline   Reply With Quote
Old 12-23-2019, 07:19 AM   #403
AndrewEG
AndrewEG's Avatar
Hey Alex awesome stuff!
Saw your car featured on a Youtube video and thought I would log back into Turbobricks to check out your build.
Good to see you're still doing amazing work!
AndrewEG is offline   Reply With Quote
Old 05-18-2020, 03:05 PM   #404
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Thanks guys! Really appreciate the kind words.
Axle is coming along slowly but surely. Welded the tube flanges on this weekend and tack welded the suspension mounts in preparation for a test fit in Duder's currently axle-less 245.
Considering the new axle will have aluminum calipers and no drum brake mechanism I think another 20lb weight savings over stock is reasonable. This should put the new axle at about 50lbs lighter than the factory assembly. Not quite as good as I was hoping for but I still think it'll make a big difference in how the car drives.
Old 05-18-2020, 03:41 PM   #405
gsellstr
gsellstr's Avatar
Nicely done man!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-18-2020, 10:25 PM   #406
Chuck W
Chuck W's Avatar
Bloody hell! That is awesome work!
'78 264GLE
'97 854 T5 (Eventually to be 5spd)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 07-20-2020, 02:00 PM   #407
HiSPL
HiSPL's Avatar
Donut give's the Buchkas another shout-out in this latest video!
https://youtu.be/ZkMqRx8VP6o
Beets taste like buttfeet.
Old 07-30-2020, 12:22 PM   #408
towerymt
the real Towery
towerymt's Avatar
Significant weight savings, indeed. Nice to see my bathroom scale measuring wasn't too far off. Had noted 1030 weight at 122lbs and 1031 was +10-12lb. Maybe I saved as little as 8lb going to the 1030. Worth it for the street cred / mod sheet. My '87 always wanted to be a '79.
http://forums.turbobricks.com/showpo...97&postcount=1
Serious question: zero or non-zero degrees of camber?
Obvious question: Got a color picked out, or going natural patina?
(You should remember this one)
Old 07-30-2020, 08:03 PM   #409
Alex Buchka
8 cylinders
I've been slacking on the axle. I should get back on the horse soon though.
I do remember that one quite well. The diff housing I have was sourced from the same place, might actually be the one in your photo. Probably going to get the axle tubes yellow zinc plated. Natural patina is in these days but I think I prefer some degree of corrosion resistance.
I still have to figure out a way to straighten the tubes back out, they did get a little crooked after welding, even with the relatively sturdy fixture. I think I'm going to try and get about .25-.5 degrees of negative camber, we'll see how it pans out.
Old 07-31-2020, 06:10 AM   #410
Sander
Good news everyone!
Sander's Avatar
No idea how much your axle tubes warped so this might not be enough, but 8 years ago I worked at a company doing wheel alignments and straightening axles on trucks. We used an induction heater to straighten solid axles and get toe in/out to 0. We'd heat up the side of the axle that needs to get shorter to adjust toe in/out to a bit below the temperature needed to harden it so not affecting the metal and then cool it rapidly with water. It'll shrink further on that side than it was before heating it. Might be an idea. This was done of course with the alignment measuring equipment on the wheels to measure what's going on real time.
Old 08-02-2020, 02:38 PM   #411
brickcupra
Default Hey Amazing build!!!
hey nice job, Ive seen your 240 in the donut video!!!!
Im almost done with my build, A few things more and ready to hit the road, JACK!!!!!
congrats in the Awards!!!
Take care
DZ
brickcupra is offline   Reply With Quote
Old 08-03-2020, 12:07 PM   #412
matt b
A driveshaft shop can help with that. I know mine (Tucson Driveline and Balance) offers that service. It does involve a massive torch, but I don't know what other machines are used.
Old 08-03-2020, 01:05 PM   #413
The Librarian
When I bent an axle tube on the quick change in my race car the replcement tube must have warped a little when they welded on the caliper and shock brackets because they laid a couple of vertical beads of weld on the opposite side of the tube to straighten it.
Old 08-03-2020, 01:23 PM   #414
Dirty Rick
Dirty Rick's Avatar
A big rosebud torch and a rag full of water.....
How many torques is that center section good for?
Old 08-04-2020, 03:49 AM   #415
Alex Buchka
8 cylinders
That's basically what I'm planning on doing. We don't have an oxy-acetylene setup at the shop so I'll just lay a shallow bead across the tube with the TIG and quench it with some water. That should induce enough shrinkage to move it around a bit.
Take care
DZ
Thanks, glad you enjoyed the video!
Not sure to be honest. Driving style plays a big part in driveline reliability. I don't have a habit of dumping the clutch or doing drag race starts so I think it should be fine at the power level I have now and plan to have in the future.
Old 08-04-2020, 05:32 AM   #416
Finnish240
Finnish240's Avatar
Waiting for video from this when it happens, I've wanted to do this long time
Great build as allways!
Volvo 240 GL - not so low, but yes.... it is slow
Finnish240 is offline   Reply With Quote
