Old 06-17-2016, 07:32 PM   #51
B2fkb0
B2fkb0's Avatar
Well finally got back at it today. Got the engine and tranny pulled and the engine bay washed.
83 242 turbo Gert
http://forums.turbobricks.com/showthread.php?t=318066
98 V70r Black (Pepper)
00 V70r Laser Blue (Lazarus)
98 v70r Saffron (Saff)
01 c70 coupe black (Shadow)
04 s60r Silver
04 v70xc Nautic
Sold:93 245 Silver,98v70xc Lucy, 96 855r Casper,
99s70t5m Panther, 98 v70xc Olive, 98v70r RN/m58 swapped 426 silver - Thor, 98v70r DynoRay CaR, 94 854 NA Turquoise, 06 s40t5m, 06 s60 t5a, 01 v70t5a
Totaled, parted, crushed: 96 855r Vader
B2fkb0 is offline   Reply With Quote
Old 06-26-2016, 12:11 PM   #52
B2fkb0
B2fkb0's Avatar
Pulled the rack and cleaned it up; pulled the interior and extracted (cleaned) all the seats, mats and carpet. Found the sound deadener foam was wet on both sides of the tunnel under the dash. Pulled out all the non-stock wiring. Vacuumed everything. The musty smell is gone!
Old 06-26-2016, 12:13 PM   #53
B2fkb0
B2fkb0's Avatar
The two wire bundles that exit out of the firewall next to the brake booster; how do they come out?
Old 06-27-2016, 12:32 AM   #54
LC4CARL
Aero challenged
LC4CARL's Avatar
Busy, busy!
@PDXvolvo on IG
Old 07-16-2016, 11:14 PM   #55
B2fkb0
B2fkb0's Avatar
Gutted the engine bay and interior
Built the paint booth
Working on the motor- intake resto
https://youtu.be/KTtxZSGrknM
Old 07-16-2016, 11:19 PM   #56
B2fkb0
B2fkb0's Avatar
Interior is awesome!
Removed excess wire
Getting there; engine bay is ready for primer. Brake booster/master/lines detailed.
Interior was extracted, vacuumed sprayed and wiped down and set in the sun the dry. They're ready for re-insertion!!
Old 07-16-2016, 11:26 PM   #57
B2fkb0
B2fkb0's Avatar
My good friend Robert Spinner came by on his way East.
He helped me out by bringing the louvers I got from Steve (stove)! Oh yeah!
Old 07-17-2016, 12:24 PM   #58
B2fkb0
B2fkb0's Avatar
Started on the intake
Shiny parts!
Old 07-21-2016, 02:23 AM   #59
B2fkb0
B2fkb0's Avatar
Worked on the intake and exhaust/turbo
Start exhaust w 90+ manifold
Add in angle flange hot side from an 01 s60
Add in the rest of the 16T
Getting there! No comments?!
Old 07-21-2016, 07:45 AM   #60
okoye
okoye's Avatar
seems like you've got an attention to detail!
Old 07-21-2016, 10:21 AM   #61
B2fkb0
B2fkb0's Avatar
It's that or ocd; but thanks! Re-clocking the turbo and figuring out all the lines is taking a bit of work but it's a fun adventure. Drilling the turbo mounting holes proved to be challenging!
Old 07-21-2016, 10:33 AM   #62
SquareD
An Anomaly
SquareD's Avatar
I admire folks that have the passion and persistence to tackle projects like this. Great work, looking forward to following your progress.
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 07-21-2016, 10:34 AM   #63
cwdodson88
looks good! The angled flange downpipe should be nice, planning to run 3" all the way back?
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-21-2016, 04:21 PM   #64
DD Ranch
DD Ranch's Avatar
DD Ranch is offline   Reply With Quote
Old 07-21-2016, 09:44 PM   #65
B2fkb0
B2fkb0's Avatar
Thanks Square D, your car is definitely an inspiration!
Hi CW Plan is 3" for 3' then transition to 2.5" TME system that came with the car.
Hey DD, I used por15 engine enamel on the intake; the 90+ came to me already coated with something unknown. It was in the trunk of a 244 my friend Slicknerd and I bought for $75 and drove home. I saw that mani and noticed it was machined flat and redrilled/tapped and coated so I grabbed it!
Old 07-22-2016, 12:14 PM   #66
Why did you mill your exhaust manifold flat if you are using a volvo turbine housing?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-22-2016, 08:07 PM   #67
Matt86
Matt86's Avatar
Awesome project! I wish I had the time and energy to tackle a project of this size. Also those Louvers are killer!
2007 V70 2.4
1989 245 DL
Matt86 is offline   Reply With Quote
Old 07-22-2016, 08:18 PM   #68
AndrewNance
Amateur hour!
AndrewNance's Avatar
So you don't have to do it later?
Old 07-22-2016, 10:20 PM   #69
B2fkb0
B2fkb0's Avatar
Hi Ben
I got the 90+ manifold already milled. And it seems it was drilled and tapped as well (3/8-24 thread). I'm not sure as this is my first go around with redblocks! So much to learn.
Today I got a little more accomplished;
Removed the studs from the angle flange hot side and drilled the holes out (cobalt bit was a must, that high nickel cast is tough). Found that the upper rear stud and the hot side had a clearance issue
So I had to trim the flange to accommodate...
That was raw and it has now been smoothed out. Then a nice coat of cast iron grey from por 15
Next up is reclocking; the pins are out, the cchra is cleaned and I'll tig weld some mounting studs on the housing for the fasteners. Then the oil and water lines. Whew! I hope the 16T is worth it!
Old 07-22-2016, 10:25 PM   #70
B2fkb0
B2fkb0's Avatar
Also, thanks Matt for the kind words! Time is always an issue; I'm fortunate to have this summer off.
Robert is a great friend (transported those louvers from CA to MI) and we're lucky to have him in the Volvo community. He also has a 740 that he is building for his brother as a gift. So he likes all of them!
Old 07-25-2016, 11:58 PM   #71
B2fkb0
B2fkb0's Avatar
Mock up with the angle flange/90+/530 head with downpipe
And going to un-shroud the exhaust valves and lower the compression a bit.
Just a bit! Also gasket match the intakes and exhaust manifolds to the head.
Old 07-25-2016, 11:59 PM   #72
B2fkb0
B2fkb0's Avatar
Old 07-26-2016, 08:32 AM   #73
DanMarino
I love me some Robert DIY Spinner videos! Cool that you guys are buddies. I love your project. I don't have the cash or space to do something like this.
DanMarino is offline   Reply With Quote
Old 07-26-2016, 10:52 AM   #74
LC4CARL
Aero challenged
LC4CARL's Avatar
Unshroud = remove material at the gasket surface around the valve? And the larger chamber volume will lower the compression a bit?
Old 07-26-2016, 11:03 AM   #75
cwdodson88
Yes, you remove material from inside the combustion chamber around the valves increasing the CC of the chamber, lowering the compression.
