Old 07-26-2016, 02:34 PM   #76
B2fkb0
B2fkb0's Avatar
Correct! The engine is a 95 squirter b230f (high compression NA), the head is off a 90 b230ft and was milled 2mm not too long ago. As I'm doing the plus T, I want to lower compression a bit. Anyone know a formula or have a simple method (my favorite) of figuring out how much I should take? With just removing a bit I figure I should be ok, but would rather know more about it. Also I'm gasket matching the head and the intake and exhaust manifolds. I've done v8 porting and some whiteblock porting. This is my first crack at a 530 head...
83 242 turbo Gert
http://forums.turbobricks.com/showthread.php?t=318066
98 V70r Black (Pepper)
00 V70r Laser Blue (Lazarus)
98 v70r Saffron (Saff)
01 c70 coupe black (Shadow)
04 s60r Silver
04 v70xc Nautic
Sold:93 245 Silver,98v70xc Lucy, 96 855r Casper,
99s70t5m Panther, 98 v70xc Olive, 98v70r RN/m58 swapped 426 silver - Thor, 98v70r DynoRay CaR, 94 854 NA Turquoise, 06 s40t5m, 06 s60 t5a, 01 v70t5a
Totaled, parted, crushed: 96 855r Vader
B2fkb0 is offline   Reply With Quote
Old 07-26-2016, 08:28 PM   #77
B2fkb0
B2fkb0's Avatar
Started porting today (after cleaning all the interior ductwork and washing down the exterior and the loose body parts)
Also de-shrouded the combustion chambers...
3 down one to go!
Old 07-27-2016, 03:26 PM   #78
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
This is awesome! Great work so far. Looking forward to updates.
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 07-28-2016, 08:09 AM   #79
B2fkb0
B2fkb0's Avatar
Thanks Kardboard+! Finished the last chamber
And completed all of the exhaust ports. As many have said before, lots of opportunity here. So far about 5 hours into the porting. A lot of this time was spent cleaning the carbide burr of the aluminum. Finally used muratic acid and that works like a champ!
Old 07-28-2016, 08:10 AM   #80
B2fkb0
B2fkb0's Avatar
Now which am to run; I have the Stock turbo T cam and also an A cam. Thoughts?
Old 07-28-2016, 08:47 AM   #81
oldschoolvolvo
oldschoolvolvo's Avatar
Nice work on the porting!
There are lots of opinions on which cam is "best"...both will work. The "T" has much less overlap than the "A" which is better for turbo spool. In my experience it is also a very linear cam and doesn't have an rpm where it comes "on cam"...IMO this makes for nicer driveability.
Since you have both cams I'd try them both out to see which one you like best for your application.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-28-2016, 11:02 AM   #82
B2fkb0
B2fkb0's Avatar
Thanks OldSchool! I will use the T (it's in there, shimmed, etc.) first and then try the A once I get everything running well on the 2.4. Appreciate the input!
Old 07-30-2016, 12:43 AM   #83
B2fkb0
B2fkb0's Avatar
Back to the bodywork
Engine bay degreased (3x)
Trunk 2 prep
Spoilers and pan washed/prepped
Trunk 1 prepped
The body lines on this car!
Whew!
Old 07-30-2016, 11:56 PM   #84
LC4CARL
Aero challenged
LC4CARL's Avatar
Straight lines.
@PDXvolvo on IG
Old 07-31-2016, 01:22 PM   #85
B2fkb0
B2fkb0's Avatar
Hood prep
Man this took five hours to do the underside! Rust transformer, sand, rusty metal primer, sand and re-prime and repeat! Finally ready for sealer/primer/paint. That's just the underside! Gotta flip it and get busy block sanding the top!
Old 08-11-2016, 09:48 PM   #86
B2fkb0
B2fkb0's Avatar
Well life gets in the way, but I got some stuff done on the turbo.
Fabricated the necessary stand offs for the waste gate actuator and welded them to the turbo housing. I only have a mig welder and this is my first whack at aluminum. While they rent pretty they are very sturdy and work great. I cut the stand offs from an old manifold (they were already drilled and tapped) adjusted them to fit.
Intake and exhaust ready on the bench!
And spent some time on my other baby, prepping for the VCOA this Saturday at the Gilmore!
Old 08-12-2016, 12:49 AM   #87
John V, outside agitator
3 down one to go!
Er. Uhm. Valve unshrouding on the inline valve Redblock head is done on the short ends of the chamber where the valves are close to the "walls' of the chamber... Kinda like
Looking at the intakes say if top of piccie is 12 O'clock opening out to the gasket line from about 10 O'clock to 8 O'clock and for the exhaust from 1 O'clock to 5 O'clock
Jus saying...
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-12-2016, 11:36 AM   #88
B2fkb0
B2fkb0's Avatar
Thanks John for sharing that drawing! I'll get the burr out and work on the head some more!
Old 08-12-2016, 12:13 PM   #89
Cool. Lookie what I found---Ford V4 heads with markings still on them.. For what seems like centuries I'd install 42mm intakes and 36mm exhaust valve on all customer heads---that's up from stock 37mm in and 31. sumpin exhuast, so quite a lit bigger so the walls were quite close..
Here is Stock vs the "Normal spec" (I use 44.5mm in and 38mm exhuast on my personal V4)
Maybe you can see the contouring..
Old 08-12-2016, 07:54 PM   #90
B2fkb0
B2fkb0's Avatar
Wow those valves look huge! I would like to go bigger but that's not in the budget this round. I get the contouring idea and will give that a shot! Thanks again for your help; I'm still thinking about your ralleye car pic and suggestion. That looks like a blast!
Old 08-12-2016, 10:47 PM   #91
No prob, mang..I's here to help.. Now just for pondering in the future, that BIG intake I use is more or less Redblock stock intake size; 44.5mm (aka 1.75") I, and a few serious head guys (fuel and funny car head guys I've know for a YUUUUUUUUUGE amount of time) say the 38mm aka 1.5" is a typical match up.....But Volvo uses a tiny little bitty 35mm exhaust..
Hell my "normal" exhaust (mine, not Ford's) is 36mm and this is for either a 1.5 or 1,7 liter motor...SEEMS like a big manly 2,1 or burly 2,3 would want a weeeeeeee bit bigger, like 38mm..Just sumpin to think of when you have a spare $60-75 laying around..
Old 08-18-2016, 11:21 AM   #92
B2fkb0
B2fkb0's Avatar
Life gets in the way;
Went to the VCOA show
Brought this home
Then picked this up
Put the doors on it and brought home an 82 DL. She's rough but restorable and is a future project!
Old 08-19-2016, 12:06 AM   #93
B2fkb0
B2fkb0's Avatar
Too many engines! Now that I have a second car to add to the mix, here's what I'm going to do (finally and thanks for your ideas!).
83 group A - b21ft original engine + 16T/blues
82 DL - 95 b230f +t/oranges
Old 08-19-2016, 11:57 AM   #94
SquareD
An Anomaly
SquareD's Avatar
Congrats on the award!
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 08-19-2016, 04:11 PM   #95
B2fkb0
B2fkb0's Avatar
Thank you! I really was surprised as there were a lot of really nice cars. Kinda makes all the work worth it, lol!
Old 08-20-2016, 11:49 AM   #96
rom
rom's Avatar
nice car. that downpipe though. i don't know what to say about that downpipe.
Religious people scare me.
rom is offline   Reply With Quote
Old 08-21-2016, 10:21 PM   #97
B2fkb0
B2fkb0's Avatar
I bought that downpipe on this forum. It was listed as a straight flange unit, was dirt cheap, and turned out to be an angle flange! The price I paid for the whole thing was the same as if I just bought the flange. I'm going to try running it and if it fits I'll use it as it's very sturdy, albeit not pretty. I can make a new dp easy enough with 3" ju, but hey first I'll try this guy! You have any history with this piece by chance?!
Old 08-22-2016, 08:16 PM   #98
B2fkb0
B2fkb0's Avatar
Body work is progressing; spent today taping/prepping/cleaning. First time I've used this masking film; man is it better than paper!
Sprayed hi-build primer on some of the panels/pieces.
Extra trunk lid; plan is one with a spoiler and one without...
Tomorrow is sealer and hi-build on the body and remaining parts. Then block sanding, more primer, etc...
Old 08-25-2016, 11:29 PM   #99
B2fkb0
B2fkb0's Avatar
Old 08-25-2016, 11:32 PM   #100
B2fkb0
B2fkb0's Avatar
Went to the PNP and got stuff...
