Old 01-28-2017, 07:38 PM   #176
B2fkb0
B2fkb0's Avatar
Thanks! You have a big part in this my friend!
83 242 turbo Gert
http://forums.turbobricks.com/showthread.php?t=318066
98 V70r Black (Pepper)
00 V70r Laser Blue (Lazarus)
98 v70r Saffron (Saff)
01 c70 coupe black (Shadow)
04 s60r Silver
04 v70xc Nautic
Sold:93 245 Silver,98v70xc Lucy, 96 855r Casper,
99s70t5m Panther, 98 v70xc Olive, 98v70r RN/m58 swapped 426 silver - Thor, 98v70r DynoRay CaR, 94 854 NA Turquoise, 06 s40t5m, 06 s60 t5a, 01 v70t5a
Totaled, parted, crushed: 96 855r Vader
B2fkb0 is offline   Reply With Quote
Old 01-31-2017, 10:45 PM   #177
B2fkb0
B2fkb0's Avatar
Got the driver seat completed. This one took more work as the seat had a bolster tear and the bottom suspension was broken. After repairing those, cleaning and lubing all the track and seat adjusters, adding the tilt mechanism and cleaning and detailing the leather it came out pretty decent.
Pulled out some speakers I'm going to use in the rear deck
These are oem out of a 2005 s40, keeping with the stock plus theme!
Old 02-11-2017, 11:41 AM   #178
B2fkb0
B2fkb0's Avatar
So I decided that I didn't want to cut or drill the rear deck. However, I wanted improved oem sound so I had to fabricate an adapter panel. So, I bought a sheet of 3/8" birch cabinet plywood and made adapters.
Had to make some custom spacers
Which gave me this
Times 2
Refinished the oem grills
Added new sound deadener to the deck and cleaned the carpet and
This is slow going but now is the time while I have the interior out. I've ordered some 1/16" neoprene sheeting for the vertical areas that I'll put in place and am completing the floor sound deadening today. Next will be the chipped ecu and ezk installation and the lh2.4 harness...
Old 02-12-2017, 02:39 AM   #179
slow240
Home Schooled
slow240's Avatar
this is turning out fantastic, seems like you've got a lot of work going on all at once, I wish I had the space to get some work done on my 242, but this is proving to be really inspirational.
Ill have to pick your brain when it comes time to paint, my attempt to paint my 92 244 didn't turn out so great (didn't follow instructions lol)
I'll polish your face
Old 02-12-2017, 09:35 PM   #180
B2fkb0
B2fkb0's Avatar
I'd be glad to help in any way I can. The best part about painting is that you can always fix it! We amateurs take longer and make more errors, but there's a great feeling when you pull off the tape! Your cars are very impressive!
Old 02-12-2017, 10:21 PM   #181
oldschoolvolvo
oldschoolvolvo's Avatar
Nice work with integrating newer OEM speakers! I dig it.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 02-12-2017, 10:34 PM   #182
B2fkb0
B2fkb0's Avatar
Thanks! It's keeping with the "stock plus" theme...
Old 02-17-2017, 10:06 AM   #183
B2fkb0
B2fkb0's Avatar
Got the power antenna installed
Wrapping up the trunk added in this piece which got refinished
Cleaned the carpet again and I'll add in the spare after the antenna/radio is sorted out
Started on the doors, and had to repair this door lock actuator; the wiring was toast
Rewired, soldered, heat-shrink and electrical tape and much better
Lubed all door mechanisms, linkages, installed lock cylinders with new gaskets. Next up; adding 1/16" neoprene sheeting as sound curtains on all vertical panels.
Old 02-20-2017, 09:07 PM   #184
B2fkb0
B2fkb0's Avatar
Final wiring of the power antenna
And the sound deadener is done. Peal and seal on the horizontal and 1/16" neoprene sheet on the vertical surfaces, finally!
Kinda looks like a tin can (but shouldn't sound like one!)
Old 02-22-2017, 10:19 PM   #185
BillyMaysHere
BillyMaysHere's Avatar
damn, thats thorough
Old 02-22-2017, 10:41 PM   #186
B2fkb0
B2fkb0's Avatar
Thanks, yeah I'm a bit ocd in my builds! I'm getting anxious to drive it! Got the ecu and ezk out and the 89 harness out and those go in next...
Old 03-12-2017, 12:23 AM   #187
B2fkb0
B2fkb0's Avatar
Well got the back of the back seat in
My friend who builds LS swap engine mounts wanted to offer a set for the 240 series cars so since the engine bay was empty, he mocked up his prototype mounts
Should work pretty well and be competitively priced!
And I got sidetracked with another 40 series car
Old 04-07-2017, 12:33 AM   #188
wagonfan00
#tiltyplategang
Jaw dropping build...I'm keeping tabs on this
Current: 1988 745Ti 248k (BC Coilovers, Kalphenke Adj. panhard bar, MBC @ 13psi, custom intake, Hydras) 2002 V70 NA M56 170k (M66 style singlemass flywheel and S60R clutch kit, a lotta poly, BC coilovers, Kaplhenke solid subframe mounts, R brakes and pegs)
Past: 2008 Mini Cooper S Clubman R55 (Stock) 1997 855 T5 300k
wagonfan00 is offline   Reply With Quote
Old 04-07-2017, 08:04 AM   #189
DanMarino
Wow! Your work and taste in cars are both excellent. Love the 242. Love the Saffron! Love the propus wheels!
Wish I had the extra money to try and restore a car like you are doing. So cool. Plus you even collected a free Amazon. Keep it coming!
DanMarino is offline   Reply With Quote
Old 04-09-2017, 11:18 AM   #190
B2fkb0
B2fkb0's Avatar
Thanks! I'm into a manual swap this weekend with a good friend, but we took a short break to add the snow scoop
That's his 95 t5r 855 getting m56 swapped
I learn a lot when Robert's in town! Look for his video on the swap
Old 04-09-2017, 12:10 PM   #191
adomz
Volvo 486 owner :D
adomz's Avatar
Looks great! Gives me inspiration on when i will have a start on my own 242 that's been sitting in my parking space for over a year now... Can't wait!
ADam
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 04-09-2017, 04:58 PM   #192
LC4CARL
Aero challenged
LC4CARL's Avatar
I'd like to quiet down the DL.
@PDXvolvo on IG
Old 04-10-2017, 08:13 AM   #193
DanMarino
Cool! Robert DIY!!! Last I saw he was in the hospital for something. Good to see his smiling face!
Old 04-10-2017, 07:29 PM   #194
B2fkb0
B2fkb0's Avatar
Robert is doing fine; his wagon is running well after the swap and tune!
Old 04-23-2017, 12:44 AM   #195
B2fkb0
B2fkb0's Avatar
She's runnin! What s car! 601 Red is the bomb. Amazing color and amazing mechanicals!
Gertrude is up next! Engine/trans and then wiring, she'll run..
Old 06-26-2017, 09:07 PM   #196
B2fkb0
B2fkb0's Avatar
So after being sidetracked with life and other Volvos, I finally got the lh2.4 flywheel sensor installed on the B21ft.
Marked out the holes by using a 1mm shim on the flywheel tooth and holding the sensor just touching the shim (spec is 1mm gap +/- .5mm), drilled the 13/64" hole first making sure it was just deep enough to have enough threads to hold securely, about 20mm; drilled the larger 11mm hole next to accommodate the sleeves; tapped the small hole with 6mm-1.00 tap, used two 6mm x 25mm bolts and locktighted them in. One small step closer and now I can mate the tranny to the engine!
I have to say I sure miss my Dad on a job like this; he was an excellent machinist and would have made it look easy. RIP Pa, hope it works!
Old 07-01-2017, 10:07 PM   #197
B2fkb0
B2fkb0's Avatar
More progress!
Thanks to my friends John (Jonah) and Alejandro (Slicknerd), we
got the engine and tranny mated, the exhaust manifold installed and detailed the starter. Not sure how I'm solving the turbo line scenario with the 16t; any suggestions for best routes?
Just liked this angle so I had to take a pic!
Old 07-04-2017, 05:52 PM   #198
B2fkb0
B2fkb0's Avatar
So I sourced some turbo lines; think there's enough to make a set?
Old 07-13-2017, 12:09 PM   #199
B2fkb0
B2fkb0's Avatar
Photobucket management did a dirty deed...now how to recover from their nasty, unannounced blow.
Old 04-21-2018, 09:59 AM   #200
B2fkb0
B2fkb0's Avatar
More progress! Drivetrain is in place and lh2.4 wiring is next...
