Old 10-12-2019, 02:57 PM   #101
runslikeapenguin
Originally Posted by shoestring View Post
Please elaborate. Was this measured in an axis that is not in the same plane as the valve stem? If so, then yes, there would be disparities.
I was measuring the crank angle at max lift on intake #1. My dial indicator was at a slight angle but i was only looking for the crank angle at max lift.
I've measured this at both 0.040" mill and ~0.100" mill and it is extremely close to 1 degree per 0.010". Also, the math backs it up.
This could be due to the IPD cam gear problems you suggested.
runslikeapenguin is offline   Reply With Quote
Old 10-12-2019, 08:19 PM   #102
redblockpowered
redblockpowered's Avatar
Yeah, that old style IPD gear is junk. At least the one we measured is. Glad they redesigned it. I'm wondering if there was a redesign in the grind of their turbo cam around the same time? I seem to remember their site mentioning a 110* lobe separation on the cam and I see that is now gone. Perhaps we measured a different version of the cam? The one you had measured by Delta looks really awesome for a street turbo car whereas ours looks like a weird inbetweener grind for NA/Turbo...
I sell chips for LH 2.4!
Old 10-14-2019, 02:44 PM   #103
klr142
Turbo, what?
klr142's Avatar
I think that is how it was originally sold and advertised? But maybe not. I did run it in my NA car once and wasn't too excited about the experience because the dyno curve looked almost exactly like my A cam curve, if I remember correctly.
Old 10-14-2019, 03:10 PM   #104
redblockpowered
Maybe we can measure enough of these and find a production split. Or ask IPD.
Old 10-17-2019, 11:49 AM   #105
redblockpowered
Alright, so I sent an email to IPD, and here's the reply I got:
"The designs have been the same for awhile, the supplier has changed now that they are billet and not cast."
Hmm...
Old 10-17-2019, 01:56 PM   #106
klr142
Turbo, what?
klr142's Avatar
Hmm, indeed... I guess, did you just ask if there was a production change or did you ask if someone has actually verified that their timing marks are correct? Haha
Old 10-17-2019, 02:08 PM   #107
redblockpowered
I asked if there were any design revisions, but I suppose that's a fair question too.
Old 10-20-2019, 09:53 AM   #108
shoestring
shoestring's Avatar
K13 Turbo added.
Old 10-21-2019, 02:41 PM   #109
klr142
Turbo, what?
klr142's Avatar
K13 Turbo added.
We're running the non-turbo version in the General Leif, which should be the same aside from the 106° LSA instead of 114°. It looks like there's a large chunk of duration to gain by using tight valve clearances with this camshaft! It has much more off seat duration than even the OC352 "rally" cam, but at .025" and .035" of lift the rally cam has more duration. After that, they're equal for a little bit before the K13 takes over again having fatter and taller lobes.
The factory H cam has a smidge more duration than the K13 between .025"-.250", then after .350" the K13 has more(as well as .5mm more peak lift on the intake lobe and 1mm more peak lift on the exhaust lobe).
Maybe this OC352 rally cam isn't nearly as aggressive as you thought, Shoestring... I've run the K13 in my car and still run it LH2.4 without issues.
Maybe I should adjust the intake valves on the General Leif a bit tighter to give us some more top end.
Old 10-21-2019, 04:00 PM   #110
shoestring
shoestring's Avatar
On this K13 you can see the transition between the ramps and the flanks on the dial indicator. It was pretty crazy.
Old 10-21-2019, 04:23 PM   #111
redblockpowered
It was definitely a lot more aggressive than I expected. Side note: In the process of measuring this one up we tried to find the lift at which ENEM publishes their duration, but we were unsuccessful. Seems like it's something somewhat arbitrary, 0.8mm or the like.
Old 10-21-2019, 04:24 PM   #112
klr142
Turbo, what?
klr142's Avatar
I wonder how much difference it makes power wise to play with the lash because of it! It seems like it's definitely worth trying if there was a way to measure power. I don't know that I would want to pay for dyno time to adjust all the valves, though. Well, if I only do the 4 intakes, maybe it wouldn't take too long...
It's a "280°" camshaft according to their notes, and based on that info, indeed it seems like it's measured somewhere likely around 0.8mm. Odd! Here's the info I posted earlier:
Originally Posted by klr142 View Post
I'd like to see something that outperforms the H/K cam noticeably without giving up a lot around idle and under 2000-2500rpm, just because it's a more modern camshaft design. Why doesn't anyone make this?!
My ENEM K13 might be close, as it's 12.5mm lift and "280°" duration. Here's more information on that. [EDIT: I'd say it's pretty close!]
ENEM K13 measurements(RSI had it measured):
intake lift .490" / exhaust lift .489"
intake duration at .020" = 288° / exhaust duration at .020" = 284.2° - Don't know if these numbers are after taking up valve lash.
intake duration at .050" = 240.2° / exhaust duration at .050" = 239.6°
K13 as advertised by ENEM:
280/280/105/107/12.5/12.5/2.8/2.4/ 0.40:
In. duration 280° / Ex. duration 280º
In. centerline? 105° / Ex. centerline? 107°
In. lift 12.5mm / Ex. lift 12.5mm
In. lift at TDC? 2.8mm / Ex. lift at TDC? 2.4mm
Valve clearance or lash 0.40mm
Inlet: Open 35 BTDC - Close 65 ATDC / Exhaust: Close 33 ATDC -Open 67 BBDC.
LSA = 106 and 28 degrees of overlap @ .050
The duration at .020" as measured by RSI shows a little less duration than what you measured at .020 here. The difference between the intake and exhaust durations are pretty significant at low lift for you as well where I think the lobes are supposed to be the same.
Old 10-21-2019, 05:46 PM   #113
klr142
Turbo, what?
klr142's Avatar
I have another cam in my possession that may be an "RSI Stage 3 NA cam", or may be a copy of the ENEM C2 camshaft that measured at .550" lift, 264°/264° duration at .050" and 336° at .012" according to the same place that measured my K13 as 240°/240° at .050" and 288°/284° at .020", for what it's worth.
That seems like a big jump at .050" and explains why it's a performance beast! I'd like to get it back in a motor sometime to play with but I'm still scared to run lash caps under the buckets in addition to shims on top... When we ran this cam last(still on LH2.4!), the engine through a rod and had a piston slam the combustion chamber. One of the lash caps was missing which may have been the or maybe not because I know we were running excessive ignition timing?!
Old 10-25-2019, 01:29 AM   #114
klr142
Turbo, what?
klr142's Avatar
For reference and what it's worth, I confirmed with Reine at Agap.se that their measurements are taken at zero lash: http://www.agap.se/Utrustning-2.html.
Old 10-25-2019, 11:39 AM   #115
shoestring
shoestring's Avatar
This is good to know, because there's pretty good specs here. What's up with these cams, though? Do you buy the lobe profiles and then set the separation value you want, or what, because I don't see actual camshafts listed, just lobes.
If it is, I like it.
Old 10-25-2019, 08:25 PM   #116
klr142
Turbo, what?
klr142's Avatar
Correct! You pick LSA(or talk to them about your specs and they help*) and profile. It's an extra charge for a dual profile camshaft, but sometimes that is ideal to help with torque. Erland Cox likes to recommend that in some NA builds, I think he may have mentioned running around 10° less duration and .5mm less lift on the exhaust side(more recent discussion said it isn't always the case - maybe on more extreme examples).
Old 10-25-2019, 09:38 PM   #117
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I have another cam in my possession that may be an "RSI Stage 3 NA cam", or may be a copy of the ENEM C2 camshaft that measured at .550" lift, 264°/264° duration and 336° at .012" according to the same place that measured my K13 as 240°/240° at .050" and 288°/284° at .020", for what it's worth.
I have a C2 on the bench that I need to send in. When I send my core cams back to josh, I'll cart that with me and send it up
Megasquirt Tuning!
Old 11-05-2019, 07:02 PM   #118
klr142
Turbo, what?
klr142's Avatar
Looking at AGAP's offerings and my notes on the ENEM C2, their R33-265-14.0 is pretty close in rough measurement, it seems.
I'm waiting to hear back on what he thinks about running lash caps under the buckets in addition to the standard shims in the buckets. People say it's ok, other people say it's sketchy, and I've seen one lash cap disappear(or at least, I'm certain it was there initially) in an engine of ours that blew up, so I think it's sketch as well... But, I'd really like to try that camshaft out!!!
*EDIT: AGAP and Erland aren't scared of running lash caps, as long as there's no valve float from over revving with too weak of springs. See below and we'll toss the big cam in again!
Old 11-06-2019, 02:46 PM   #119
klr142
Turbo, what?
klr142's Avatar
And here is Peter's measurement of the Enem C2 previously posted.
http://forums.turbobricks.com/showpo...2&postcount=72
Old 11-06-2019, 03:50 PM   #120
shoestring
shoestring's Avatar
Dang
Old 11-07-2019, 12:09 PM   #121
klr142
Turbo, what?
klr142's Avatar
Me:
I do have one more question for you. I have a camshaft available to me that has a smaller base circle than stock by about 2mm that I am considering running. In your experience, is it safe to run lash caps and shims in the buckets at the same time? The camshaft’s profile is similar to your R33-264-14.0 from the specifications, so it’s pretty aggressive. I do have valve springs set up for 14mm of lift with stainless steel 46/38mm valves, but I am still cautious to run both shims and lash caps at the same time. The last engine this camshaft was in blew a rod through the block and I couldn’t find one of the lash caps after disassembly.
Am I worried about nothing and it’s common for people to run both, or should I set the clearances a different way and just use shims or lash caps to set the clearance?
Reine from AGAP:
I do not feel it is a problem to use lash caps, the ones I sell sits 2.5 mm down on the valve stem, so for those to come loose it need to be valve float with at least 2.5 mm, if that is happening it would just be a matter of time for something else to brake if there are no lash caps to come loose. The engines that I hear of with these kind of problems is if there are very aggressive, engine speed limiter or launch controls.
Maybe I'll try this out...
Old 11-08-2019, 04:36 PM   #122
shoestring
shoestring's Avatar
Grip it n rip it
Old 01-05-2020, 03:38 AM   #123
klr142
Turbo, what?
klr142's Avatar
Good old thread: http://forums.turbobricks.com/showthread.php?t=12640
Old 01-06-2020, 08:04 PM   #124
klr142
Turbo, what?
klr142's Avatar
Some of Matt's work from years ago: http://www.calgaryvolvoclub.com/foru...=1942&start=15
Old 01-07-2020, 07:38 PM   #125
Matt Dupuis
Matt Dupuis's Avatar
As a couple people have pointed out, I did a bunch of work on this back in '09. I took manual lift measurements every degree or two so that I could get a reasonable profile shape, but never published the info. What I didn't do was measure them on an engine like the OP did, which is certainly a nice touch to see how they're ground with respect to advance/retard.
What my test also did was eliminate any flex or whatever might come from having springs installed. This provides a less real-world view of things, but for my purposes it was useful because I wanted the actual lobe profile. My intent was to reverse-engineer any geometry of the bucket/lobe relationship to get a "true" lobe shape... never did. I also measured the cams' lift from the lobes themselves so I could get an idea of the way they ramped up off the base circle, so my .050" correlates to your .035 fairly well but there is some difference between my 0" "valve lift" numbers and yours, as I reported numbers where the lobe lift crossed the .016" threshold and you were using a theoretical .015" lash plus one thou, which SHOULD be the same but I imagine there could have been some variance in the accuracy of your lash.
I skimmed through your data and came up with few surprises. Most of our information agreed for the most part, though the V cam I measured was quite a bit less aggressive than yours was, to the tune of 6-8 degrees at .050". It was also good to see that the IPD Turbo and the Enem V15T indeed appear to be the same - I never got around to verifying that for myself.
Good work!
Matt Dupuis is offline   Reply With Quote
