Old 05-14-2018, 01:47 PM   #1
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Default Pillows LS swap into 960 build v-log - the shade tree conversion bible
This conversion has been a longtime in the making. Thanks for the information and support of the TB members and LS1Tech Hybrid conversions along the way that have provided guidance and motivation.
Most all updates will be in text and/or video blogs on YouTube. With Photobucket gone, I have been lazy on transitioning to a different picture hosting service. YouTube integrates well on my phone, which helps post information quickly and easily. Links will be provided as progress moves along. Note that I do not edit my videos or add any bling whatsoever, sorry if they are dry but at the same time they are short and zero rambletron to waste your time. I hate watching 15 minutes of blather for no real information at all.
The victim is a 1992 Volvo 960 wagon named Savage Wagon. Nothing yet is Savage about it at all... When backs up 400ish HP then the 960 will be pretty Savage ;)
I know there are multiple ways to setup and install a LS powerplant in your Volvo swap. The goal is to retain all factory functionality with dash gauges and A/C. Basically a stock looking and functioning swap that you would be proud to daily. There are numerous swaps that have been completed that do not account for A/C, dash gauges, and any real efforts to make the car whole again as a real driver. Which is okay, but to get all the electronics right does require extra time and expense over a junkyard swap and burnouts. It really depends on what your goals are as to what you will gain out of this build thread.
All parts to make this conversion will be listed with sources and prices. Links provided to manufactures of custom parts and honest reviews of what works and what does not.
Other sites and places are dedicated to LS engine building and transmission selection. I will not bore you with drivetrain details unless someone asks. Basically it is a 5.3 truck LS engine with LS7 cam mated to a hydraulic Gen4 T5 transmission. The length and dimensions are very similar to that of a T56 and installation is basically the same. I know I have a mutant setup, it should work for me, but choose as you feel fit for your needs.
Basics:
- 2003 Silverado 5.3 engine modified with LS7 cam and supporting upgrades
- Gen4 T5 manual transmission - built up properly
- Hot Rod Works adapter plate
- SBC Truck bellhousing
- Speedway GM Hydraulic TO bearing
- 940T clutch and pedal set
- 940T Clutch Master Cylinder (M12x1.0 output)
- STS LS conversion mounts
960 engine harness will be modified to use:
- temperature sensor
- starter signal
- voltage regulation
- oil pressure gauge
- coolant temperature gauge
- power functions to control the LS ECU
ECU will be programmed by LT1SWAP.com. You can choose your functions depending on the way you pin out the loom. I plan on DBW throttle control and using the Fuel Composition Sensor for E85. Spreadsheet to follow on that detail. Note that once the car is up and running, a proper tune will need performed on the engine to optimize power and fueling.
The tunnel was pounded out per JTR 740 specifications. See their website for the PDF download... Bring a sledgehammer and move the metal quickly. Really, you will be there all day with a 3lb mini sledge.
2010 Porsche Cayenne S - My ride - 99k stock
2010 Cadillac Escalade ESV - Wifeys ride - 205k stock
2007 Audi A4 3.2 M6 - daughters ride - 166k stock
2006 Volvo XC70 Wagon - sons ride - 175k stock
1992 Volvo 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress.
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 05-15-2018, 07:41 PM   #2
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Initial walk around after tearout.
https://youtu.be/ikW_HnJ00MA
Drivetrain quick walk through.
https://youtu.be/TDxiKeW2eGw
Old 05-15-2018, 10:48 PM   #3
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
STS Machine LS swap mounts review...
https://youtu.be/LaFk0OQgVvI
Quality kit overall, but the description is 100% wrong. Many people have called BS on this before and they were right.
Plan on LS1 or LS6 (read low) intake manifold with matching throttle body.
Also you will need an alternator and power steering pump relocation bracket kit. I just purchased the ICT Billet kit as it will relocate the truck accessories without having to purchase LS1 specific parts.
Add to this you will need a LS1 water pump and standoff spacers. Again I purchased ICT Billet spacers and an AC Delco water pump.
I had an LS1 intake and TB on hand #hoarder and swapped it in. The hood will close properly with this setup. The truck DBW TB is too high. A Truck DBC will fit, but not the direction I was going. Oh yeah, the LS1 TB wiring is different, IDK what I am going to do there yet.
So for an extra ~$400 you can close the hood and not have to cut a hole in it.
Next up, headers. The C5 Z06 or trunk exhaust manifolds do not fit. More to come there.
Old 05-16-2018, 11:16 AM   #4
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Accessory drive part numbers from ICT Billet:
Item # Description Qty
551778 LS Truck Saginaw Power Steering Pump & Alternator Bracket Kit LSX LQ4 5.3L 6.0L 1
551445 LS Truck Block - Drill Template 1
551690-71 (LS1 Camaro to Truck) Water Pump Spacer .7" Adapter Swap kit LSX LS LS2 LQ4 GTO 1
and
ACDelco 252-846 Professional Water Pump Kit
Old 05-16-2018, 06:36 PM   #5
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
I just purchased a set of new take-off LS3 exhaust manifolds. Lets see if those fit.... Wait for it... Wait for it... Seriously probably a week delay at this point.
Old 05-20-2018, 08:35 AM   #6
240wagonguy
A friend of mine designed and sells LS mounts for 700/900, he said there is no way to get the LS low enough in the chassis for a truck manifold and accessories to clear the hood. His quick and dirty solution was to cut out the center of the hood and make it into a cowl hood. Obviously not a solution for everyone.
Old 05-20-2018, 05:34 PM   #7
M.H. Yount
M.H. Yount's Avatar
The versions that come on a new crate LS3 (Camaro style) won't fit in a 240; you'll give us the verdict on the 900....
Old 05-30-2018, 01:33 PM   #8
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Updates and depression.
Some of the parts for the Alt and PS pump relocation have come in, but I need a different idler pulley for the F body water pump and alternator. Good news is that the water pump and PS pump are in... Everything else is a PITA money pit.
The 2010+ Camaro SS exhaust manifolds did not fit as they poke out into the frame rails. I am on the lookout for a C6 corvette setup now. More time and expense.
Again be patient and eventually this will become a really good how-to with part numbers! And a depressing speadsheet with costs!
Old 06-03-2018, 05:12 PM   #9
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Rambletron over F Body pulleys and fitment. Pardon the slow ramble, I just wasn't on the speaking coherently train that day.
https://youtu.be/sQPzvnt_oBA
Good news is that the pulleys are done. Belt K060680 has been ordered.
Old 06-03-2018, 06:38 PM   #10
M.H. Yount
M.H. Yount's Avatar
Good for you. I bought 6 belts from O'Reilly's before I got the right one. Turns out accurately measuring for that was tougher than I thought... They don't mind the returns though.
Old 06-18-2018, 12:56 PM   #11
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Ok, I finally have the exhaust setup.
Passenger Side: LS3 crate style with center dump.
Drivers Side: Block Hugger header - Flowtech 11706FLT
https://www.jegs.com/i/Flowtech/387/11706/10002/-1
Very well made! I am impressed.
Now I need to pull the motor for some more fabrication work.
- Beat up firewall some more.
- Fuel lines.
- Throttle cable hole for Lokar cable. The stock Volvo is too big with the rubber grommet.
Progress, slow and steady
Old 06-25-2018, 07:05 PM   #12
rallydallas
A couple of quick notes based on my experience, if it helps.
Throttle cable hole--you can use some cut silicone rubber in between properly sized 1" fender washers, like stainless, sandwiched.
Look up CSF 2718 radiator on Autoplicity.com, if this fits in 96X, it's a decent cheap 2 row all-metal drop-in radiator. Works for my L33 even in the summer.
There's a temperature sensor that you can plug into one of the head spots, and wire into stock 9XX harness to give temp gauge.
What else...
ECU can obviously drive the hi/lo relay of the stock 96X fan, but the fan might have to be adapted to fit w/ the V8 accessory drive.. ECU should be able to take the A/C request from the 96X harness but I haven't quite gotten there yet myself. Not sure if the tach output for the ECU will need to be modded, on mine the 94X was 4 cylinder which matched the GM ECU output, so just plugged it up no problem. 96X should hopefully have VSS in the diff, so no need to modify that. HTH, if you were needing any.
rallydallas is offline   Reply With Quote
Old 06-26-2018, 03:08 PM   #13
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Slooow, but getting there. TY RallyDallas! I may hit you up where I get stuck.
I'm tearing into the 960 engine wiring harness now. I have the Green book (off Ebay used) plus this: http://www.autoelectric.ru/auto/volv...993/960-93.htm
But, yes, the way I see it with proper wiring the dash and all accessory functions should be ok or have a work around between the LS and 960 harness. It is just slow going. FWIW the ECU is unlocked and LS harness are ready for the swap per: http://lt1swap.com/wiringharness.htm
More to come in video, it has been so wet here lately that outside production came to a halt!
Old 06-26-2018, 03:25 PM   #14
Jack
junkman
Jack's Avatar
too much talk with no pictures
I love you even more Jack.
Old 07-10-2018, 05:10 PM   #15
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
SLOW progress. #WorldCup
Engine is back out to make more dents in the firewall. With the truck bellhousing you need a TH400 hole for the motor to sit back enough to clear the fan and allow the shifter to line up.
Fuel pump is out... The replacement of course did not work as the filter did not match the pump. KIT means this ish should match and work!
I'm ordering a 9-201-1000 - DeatschWerks Universal In-Tank Fuel Pump as it has good reviews here on TB. Walbro fakes scare me as I want something that I know is real and works.
http://deatschwerks.rpmware.com/deat.../i-527436.aspx
Bits for the clutch pedal are ordered. The pedal cluster should be swapped shortly once said parts arrive.
Fuel lines will be swapped out as well. I'll post a video on that once under way.
A good 960 swap story... Of course they blow through all the details like its nothing. Nice overview but does not chronicle the real swap details. I was let down to see they did not integrate the dash wiring. I found that lazy considering the level of effort put into the other parts.
http://drivewerks.co/?s=volvo
Old 07-10-2018, 05:47 PM   #16
rallydallas
Question
SNIP
What are the isolators are mounted to? Did you cut down the tops of the stock 960 mounts? Or...?
Old 07-10-2018, 06:17 PM   #17
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
The bases are 960 as they lay flat on the perches. The Redblock mounts are at an angle and will not work for the application.
I am using the STS kit which uses the BMW 3 series engine isolators on top of the 960 bases. The BMW isolators also give an advantage as they can rotate to adjust the engine forward or back by twisting them as the bolts are offset like a camber adjustment bolt.
Again the STS kits sits very high and honestly I think a truck oil pan would fit just fine. But you are forced to change to a F body low profile intake manifold (LS1 LS6) and F body accessories.
The kit is very nice overall, but the description on fitment is dead wrong.
PM me your number and I can text some pictures your way.
Old 07-11-2018, 10:42 AM   #18
rallydallas
Oh, I see. I found the wrong picture (see attached.) What you're saying makes sense; sorry for my confusion. I'm guessing 94X cars can use the same mounts (I custom made mine.)
Old 07-11-2018, 01:39 PM   #19
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
You had it right for a 960 in the #16 post graphic. The 960 mounts can bolt right into any 7/9. Effectively replacing the angled B230 engine mounts.
Old 10-10-2018, 04:27 PM   #20
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Fuel lines and pump are done! Yes, it was a battle.
DW200 fuel pump.
Gates Barricade Fuel hose as needed.
GM Fuel Composition sensor (E85)
GM Fuel Filter
SS 3/8 Supply hose to the engine compartment.
Stock 5/16 return line
Proper FI clamps as well.
Oddball notes:
- 18-24" of 1/2 FI hose is needed between the in tank pump and "under car" pump location. This from factory is not FI rated so it needs upgraded when putting in a FI pump in tank.
- Replace the 5/16" in tank submersible hose with new. Be sure that the 5/16" hose is Submersible rated!
Now back to the 3 pedal conversion and breaking knuckles in hard to reach locations.
Old 10-15-2018, 03:04 PM   #21
rallydallas
Pillow, FWIW, this weekend I replaced my stock 740 (3/4" bore) master cylinder with a Tilton Series-75 (7/8" bore.) I used a 3d-printed clevis, and used M6 bolts to mount it. Wasn't easy for sure since there's so little space under the dash for fiddling with the MC. Anyways, I'm not 100% certain but I think 7/8" bore might be over-shooting. With 3/4" I was getting gear teeth almost all the time during shifts. Now with the 7/8" I get *no* teeth at all, but the clutch engagement is really high up on the pedal, definitely in the first 25% of pedal travel. A 36" AN-4 stainless line (McLeod 139204-36) is long enough on mine to go from MC to the slave. I may try adjusting the pushrod a bit to see if I can change the engagement point on the pedal.
Also on mine I managed to alter my Fuel pump circuit in the fusepanel to be 12V-switched-on (from the GM ECU) as opposed to my factory ground-switched-on (from the Volvo ECU.) I basically cut a wire and re-routed it at the fuel system relay. Pretty easy. Oh and I made a shunt at the shifter box for the park/neutral switch to bypass (since the auto shifter was removed.) You could probably just cut that connector off and solder the two together.
For mine I added a little fusepanel that handles the power for each injector bank, GM ECU ignition power, and "engine sensors / O2 / MAF / reverse solenoid" with two separate relays driving these; haven't had any issues yet.
Old 10-17-2018, 09:44 AM   #22
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Thanks for the additional info RallyDallas!
Probably another week or two before turning wrenches on the 960. I had some trees taken down yesterday and I need to clean and cut up a bunch of wood. It is a good thing as I now have a space for an outbuilding 3 car garage ;)
Old 02-12-2019, 11:33 AM   #23
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Closed for winter but Cliff notes from another thread that may be helpful! I have some additional videos to upload to YT as well.
The Sloppy Pillow Installation Guide (Notes of Cliff) as I see it for Gen1 or Gen2 on a basic LM7 4.8/5.3
* Hopefully save some time, money, and effort for others.
** No chrome solution! If you want bling go ahead and set your $10k on fire.
*** This isn't Roadkill or Engine Masters, so I'm not whoring chinesium Holley i$h!
**** F Body = 2002 Camaro SS 5.7 LS1 for parts reference
- Oil Pan:
1. GM Hot Rod - cheap and works, side exit drain plug may have clearance issues with subframe depending on front or rear setback. 5 Quarts of oil.
2. Early Truck - I think this will clear. Rear exit drain that avoids subframe. (if bored I will swap this winter just to check fitment.) 6 Quarts of oil.
3. Truck 2008+ - +1" of additional clearance. Again this should work. 6 Quarts of oil.
- Intake Manifold:
1. Car style LS1/LS6
2. Aftermarket FastLSX etc. Some options are affordable and some crazy expensive. Car Craft did a great LS Intake Comparo that is worth a read so you can decide what $/HP ratio suits your build.
- Throttle Body
1. DBC Early Truck/SUV Drive By Cable - these are getting beaten due to age so hard to find clean and becoming too expensive for what they are.
2. DBC Express Van - Long production run and cheap on Gar-bay. Usually these are cleaner than the Truck versions as well. Same thing at much better price!
3. DBC Aftermarket - some people have issues with the chinesium TPS sensors etc. Buyer beware and not worth the risk IMO.
4. DBW - LS1 and Truck did not clear the hood for the Gen1 STS mounts. YMMV.
5. Lokar LS Truck (not car) throttle cable - matches up well with the Volvo pedal catch w/o issues. Good quality and works.
- Accessories (Note LM7 as F-Body LS1/LS6 engines can drop in stock)
1. A/C Compressor - fits no issues at all
2. Truck Water Pump (WP) neck is too high and also interferes with the LS1/LS6 intake manifolds and will need to be changed to an F Body water pump with stand offs to match the Truck crankshaft pulley offset.
2.A. F Body WP (rumor that Gen5 Camaro WP will work but diff outlet location - do your own homework if that interests you.)
2.B. WP Spacers with Steam Vent Breather - Bonus as you need a steam vent anyway. Aligns Truck crankshaft pulley with LS1 WP pulley. ICT Billet SKU: 551690-71 https://www.ictbillet.com/ls1-camaro...2-lq4-gto.html
3. Power Steering Pump - Truck Saginaw relocation kit. Reuse the LM7 power steering pump and relocate with ICT Billet SKU: 551321-3 https://www.ictbillet.com/5-3l-ls-he...p-4-8-6-0.html
4. F Body Alternator (NO the Truck ALT will not work as it is not made for 3 bolt point mounting)
4.A. The Truck block needs an additional hole drilled and tapped for the F Body ALT bracket. Easy, but could be difficult if you are not familiar with how to drill and tap properly - even still pucker factor is high. ICT Billet SKU: 551445 https://www.ictbillet.com/ls-truck-b...r-ls1-lsx.html
4.B. F Body Alt mounts - Stock GM if possible or ICT Billet SKU 551668-3 https://www.ictbillet.com/ls-truck-a...33-billet.html
5. Idler Pulley - Truck will not work so you will need the F Body Idler to match up.
6. Serpentine Belt... IOU what size fits.
- Exhaust Manifolds
Rant: I went through every stock GM manifold that was remotely recommended... None work to get around the 7/9 Steering shaft. I have a fine collection of manifolds on my basement as a result.
1. Drivers side = Block Huggers! Block Huggers! Block Huggers! Someone prove me wrong! Flowtech 11706FLT https://www.speedwaymotors.com/Flowt...nt,141147.html
2. Passenger side has many options available. Easy is any of the center dump and angled Corvette manifolds. Bonus on these is that the O2 sensor bung is cast into the manifold. OR just run the set of Block Huggers as you will have it on hand anyway.
As you can see this only addresses getting the LS into the engine bay. The fuel system, electrical, etc. is on you as there are many ways to skin the cat on this. I can detail sensors if anyone is interested as some of these are tricky.
Old 02-12-2019, 12:18 PM   #24
240wagonguy
Thats a truck load of info, thanks!
I think the hot ticket for a 7/9 swap would be the LS2 car intake, that way you get the 4 bolt throttle body and 90mm inlet. Then grab a chinabay 90mm throttle body to take advantage of that 90mm inlet. Good for larger displacement or boosted apps.
Like I mentioned, 2008+ truck pan is 1" shorter than the common early truck pan. Giffin Performance mounts are designed to use this pan. Usually found under $100 from salvage yard with the pickup tube.
Water pump with car intake. 2008+ silverado water pump has a lower tube on top. 2010+ L99 Camaro has truck spacing and outlet on drivers side. Thats what I will likely use with a stock radiator.
The small case 130amp truck alternator should fit an f-body bracket, I have one setup that way in an 81 Camaro.
Thats awesome news about the truck AC compressor, I was just talking to John about that this morning. I have piles of brackets and compressors that were just throwaways before this revelation.
Old 02-12-2019, 12:20 PM   #25
240wagonguy
We also plan on producing a 740 swap video series as well to hopefully cover all the nuances of a 7/9 swap. Once that is complete I will do it over again on my girlfriend's 745 DD with a 6.0L and 5 speed.
