Old 09-25-2018, 02:16 AM   #1
DrZiplok
DrZiplok's Avatar
Default Lower control arm extension for 240
After prototyping these (very roughly) in hand-cut and drilled 1/2" steel, I figured I'd get a couple machined up.
Uses a box of Dorman 610-378 wheel studs and corresponding M12x1.25 nuts, plus a suitable bolt from e.g. the set supplied with a new balljoint. A longer tie rod is required; we're using 2000 Ford Focus rods, but others have noted that 940 rods are also suitable.
-3° camber on otherwise stock struts.
Now, it's probable that steel is overkill for this application, but I didn't want to get them made in Aluminium and then discover the hard way that it wasn't up to it...
Happy to share the eMachineShop design file / DXF for anyone that's interested, though in low volume they were not particularly cheap.
DrZiplok is offline   Reply With Quote
Old 09-25-2018, 07:04 AM   #2
MSGGrunt
Pardon my ignorance, but is this what I would need if I was LIFTING my wagon to bring the front alignment back within spec? My assumption being that my 2" lift on coil-overs will effectively "shorten" the distance from the control arm pivot point on the frame to the outer end of the control arm balljoint mount.
What is "not particularly cheap" if you don't mind sharing?
I am interested in the file. msgdhorn@yahoo.com
1969 Triumph TR6
1986 BMW E30 325E, Auto, 2-door coupe.
1987 Volvo 240 Wagon Auto
1989 BMW E30 325iX 5-speed
1990 Volvo DL 240 Auto
1991 Volvo 240 Auto
1992 Volvo 240 GL Auto
1993 Volvo 245 5-speed.
2015 Volvo XC60 Platinum
MSGGrunt is offline   Reply With Quote
Old 09-25-2018, 07:27 AM   #3
Hen
Hen's Avatar
Good thinking to use wheel studs to secure them. I did something very similar, but used countersunk bolts and tack welded them in place. It meant that I could start with relatively cheap laser cut blanks then hand finish them. I also angled the balljoint slightly forward to gain more caster.
It worked, but form memory the steering arm/tie rod/something ended up very close to the nuts used on top of the control arm. And I reckon if I were to do it again I'd strongly consider just chopping two sets of arms and rewelding them to make an extended set.
1990 240 driftwagon - B230FX+T - M90 - other fun stuff. Now sold unfortunately.
Hen is offline   Reply With Quote
Old 09-25-2018, 10:55 AM   #4
Those look nice, better to be sure and reinforce the flimsy factory arms if you will be extending them.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-25-2018, 12:07 PM   #5
culberro
culberro's Avatar
Pretty neat, and thanks for sharing the file! And definitely reinforce the stock arms.
I thought about doing that, but then went with these for the "easy" approach: https://shop.klracing.se/sv/artiklar...-special-.html
25mm wider per side, and the ball joint is moved forward 15mm for added caster.
Old 09-25-2018, 12:27 PM   #6
J_Jones
J_Jones's Avatar
Nice find, will order.
Old 09-25-2018, 01:19 PM   #7
culberro
culberro's Avatar
If getting rowdy, definitely plate the tops. I already bent one drifting, but it was a big hit.
Old 09-25-2018, 01:29 PM   #8
Hopefully at some point I will release my adjustable control arms. Got some new equipment in the pipeline which should speed up my productivity.
Old 09-25-2018, 02:08 PM   #9
John V, outside agitator
Lagerstatus: Tillfälligt slut
Artnr: 07088
Hyllplats:I5-1F2
Temporarily slut.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-25-2018, 07:13 PM   #10
DrZiplok
DrZiplok's Avatar
As a stopgap, something like this would be a great stocking stuffer. Perhaps pair it with some precut LCA boxing plates (or a piece of cardboard in the correct shape, since cutting them isn't hard...) ?
Old 05-20-2019, 05:48 PM   #11
klr142
Turbo, what?
klr142's Avatar
Cool stuff. I have a spare set of arms for me to extend one day...
Yoshifab has some: https://yoshifab.com/store/volvo-240...ox-plates.html
Old 03-23-2020, 12:50 PM   #12
hamfisted idiot
I would like this file if it is still available. I have a machinists ready to go. Thanks drZiplok!
hamfisted idiot is offline   Reply With Quote
Old 03-23-2020, 10:55 PM   #13
towerymt
the real Towery
towerymt's Avatar
Here are some pics from our old lemons car. Our spacers were made from sheet steel cut/welded up. The control arm failed first. Camber was significant, probably around -3 degrees or more when using stock upper strut mounts.
The trouble with the pre-cut plates for enclosing the underside of the control arm is that they interfered with the bolts for the spacers, so someone cut some of it away. We would have been better off to reinforce the top side of the control arm, and then re-box the underside.
The inner tie-rod was lengthened with a section cut from another tie rod.
Old 03-24-2020, 01:58 PM   #14
For added win, the BNE QSRCs in the middle setting will work with unmodified inner tie rods and the ackermann on the v1 units will be a lit better than with stock arms.
Old 06-21-2020, 10:15 PM   #15
Canadan
Canadan's Avatar
Does anyone still have the file for this?
Canadan is offline   Reply With Quote
Old 07-18-2020, 10:10 PM   #16
DrZiplok
DrZiplok's Avatar
I do 8)
PM me an email address and I'll shoot you the files. Haven't been around much, sorry.
