Old 12-13-2019, 09:44 AM   #101
itlksez
itlksez's Avatar
Thanks culberro! It’s been a journey, that’s for sure.
I have a spare pump here from an 850. I’ll pull that one apart first to learn on. I found that one should definitely be putting out 1081-1181 psi. Hopefully I can put something together between the two of them that works.
itlksez is offline   Reply With Quote
Old 12-13-2019, 11:46 AM   #102
itlksez
itlksez's Avatar
I took the relief valve out and swapped it with one from the spare pump. It’s 90% better. Still not as quick as it could be, but definitely much better. It now strains at full lock, and I can turn lock-to-lock with some speed.
I’ll put a new pump on my wish list. I think this one is worn out.
If anyone is wondering why I didn’t just switch pumps, the one from the 850 is a piggyback reservoir and it won’t fit under my radiator hose.
Old 12-15-2019, 08:21 PM   #103
itlksez
itlksez's Avatar
Punch list is getting smaller. Shifters for the t-case are done.
I chopped the shifter tower off an old Dana 18 and whipped up a mount that bolts to the transmission.
Hereís the shift pattern of a Dana 300 when you switch it to a twin stick:
So the options are:
4wd high range
4wd low range
Rear only high range
Rear only low range
Front only low range
Neutral
Old 12-17-2019, 03:53 PM   #104
itlksez
itlksez's Avatar
This parking brake (from the Isuzu Rodeo) was a pain in the butt. What I started with was close to working as it was, but just wrong enough that every piece had to be modified to some extent.
Hereís what all the brackets and linkages ended up looking like.
The cables split the cage member, and I stuck a bracket in there to keep the outer cable away from the tire.
Parking brake disengaged:
Engaged:
Old 12-17-2019, 08:06 PM   #105
bobxyz
bobxyz's Avatar
So the options are:
4wd high range
4wd low range
Rear only low range
Neutral
Awesome project, thanks for the bleacher seat build enjoyment!
For the shifters, it's one shifter per axle (L/N/H), right? Is there a lockout to prevent the bad combinations, such as Front Low + Rear High? Will it do shift-on-the-fly at all?
Long ago, I had a Series III Land Rover. There was a big red shifter - 4wd low/Neutral/2wd high, and a yellow knob that you pushed down to go into 4wd high. You could start in 4wd low and while moving, with the clutch in, go to 2wd high. You could also engage 4wd high while moving. Some clunking involved, but no grinding. It also had a Fairy overdrive that gave you a half gear in between all the other gears. Freeway speed, and merging, were still challenges.
Old 12-17-2019, 08:34 PM   #106
itlksez
itlksez's Avatar
Thanks bobxyz! I never know how many people are watching... I feel like the kid who got invited to the party because he received another kid’s heart transplant, and the family only has a connection to the heart.
Yeah, it has an internal ‘pill’ in between the shift rails that prevents any mismatched ratios. Shifting from 2wd to 4wd on the fly is possible if the front lockout hubs are engaged.
The pill removal in the old Dana 18s was necessary to run in 2wd low range, but no gearing mismatches were possible. The shifters were just high/N/low range and front axle engaged/disengaged.
I have the pill removed from the Dana 20 in my other Jeep, and that one can get weird. Left shifter is rear drive, right shifter is front drive, and any combo is possible. Binding ensues!
Old 12-17-2019, 10:37 PM   #107
2 old for this
I did the same shifter mod on our Samurai.it helped a lot being able to run low range in 2wheel. At 12000’ elevation it needed low range all the time. Only down side was that it was a guessing game on where the gears were.
Old 12-23-2019, 10:20 AM   #108
itlksez
itlksez's Avatar
I FOUND IT!!!!! Two hours of searching every box, bin, drawer, cabinet and countertop, then I decided to check outside around the scrap pile, and there it was in the mud where itís sat for probably the last four years.
In designing my center console, I really wanted to find this latch to design it around. I knew it was somewhere!
A day wasted, but worth it.
Very rough draft...
This padded topper from an early V70 (mounted backwards) will be hinged separately and held down with a magnet. Lift it to access the latch.
The small box in front is for the radio... something like this marine gauge unit.
I considered a cup holder of some sort, but it seemed like a waste of space down there. Iíll make something to clamp to the roll bar above the shifters at some point.
Here is what was behind the armrest that needed to come off in order for the lit to have full range of motion.
I had to tear the seat apart to cut this off without scarfing up the fabric or foam. You can see the plate I made to cover the hole in the fabric in the last pic in this series.
Here are the hinges on the console. I used old door hinges with removable pins. If the Volvo glove box latchís internal mechanism ever failed, I wanted to make sure I could still get the lid off without cutting it apart.
I bent some strips to 110į and welded them along the top to make the rim stiffer and pleasant to reach past. I bent the front/center area square to act as the catch for the latch.
Here is the tubing framework that got welded to the cage. The box drops down onto four studs and is secured with locknuts inside.
I raised it up a bit to work as an armrest, and I lopped off the top corners to more-properly follow the contour of the pad and compliment the look of the stereo box under it.
Upper lid open to expose the latch. You can see the magnet next to the latch. It sticks to a screw in the lid.
Opened...
The framework will get finish-welded next time the cage is out.
I took it out for a thorough test drive. I figured out the cause of some steering vagueness... all four of my tires registered at 0 psi on my gauge. The tires are so old and hard, they support the weight with no air. After I fixed that, road test felt great, and I tested 4wd with good success. Front driveshaft had no noticeable or visible vibration with hubs locked in 2wd at ~45 mph, and crawl gearing feels good. Not a hardcore rock crawler, but good general gearing at 40.5:1 compound low. This, on 32s, feels the same as my 3b that has 47:1 on 33s, plus it feels like it lugs better than the old Jeep engine. The fuel injection has a bit of a ďgovernor effectĒ down low. Also, the parking brake is very strong; it easily locks the rear tires.
Very pleased so far.
Old 12-23-2019, 10:24 AM   #109
Vol242vo
Keep it clean...
Vol242vo's Avatar
You really are a God D@mn Stud! Absolutely brilliant.....and KIX...mmmmmmmm
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 12-25-2019, 12:08 PM   #110
itlksez
itlksez's Avatar
Thanks Vol242vo!
A few little things...
I made a plate to mount one of the ECMs to. The big holes are there to tack it to the body. This one went just to the left of the driver’s feet.
The hood was missing half of the hinge. I’m too cheap to spend $30 + shipping for a new hinge, so I made one out of old door hinges.
Old 12-31-2019, 05:43 PM   #111
itlksez
itlksez's Avatar
I put all its clothes on for a beauty shot. I canít wait for this thing to be one color.
This little mount was a pain, but it turned out nice.
I made it so I could mount the ignition control module on the driverís coil spring bucket, far from any engine heat.
I spent the last two days cleaning up the wiring in the engine bay.
Now the nightmare of under-dash wiring...
My buddy stopped by and filmed a test drive.
Old 12-31-2019, 05:54 PM   #112
brickcupra
Default cj drive
well nice video . Now we see the original idea of the red block from a tractor been put into the use it was meant to do!!!
Nice ride Take care
DZ
brickcupra is offline   Reply With Quote
Old 01-28-2020, 07:00 PM   #113
itlksez
itlksez's Avatar
I had to step away from this for a little bit. Iíve decided to sell my custom made fat-tired dirt bike to fund this Jeep to the end, so I had to jump on that to strip it down, clean/blast/powdercoat/reseal.... everything to make it run great and look pretty.
Iím waiting for parts to arrive, so I had some time to jump back on the Jeep. I started working on the floor. It needs to be made in two sections so it can come out without removing the cage. I started with the rear section by cutting a bunch of 1Ē strips out of 1/8Ē material. Iím making the floor framework out of this, then filling the inside with 18g.
I made these stiffener ribs out of 18g
Iíll drill and tap the floor to bolt this down to.
All cleaned up...
Iíve started on the front. Itís a pain in the butt. More in a few days.
Old 01-28-2020, 08:30 PM   #114
Fun little test ride. Thanks!
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 03-20-2020, 08:12 PM   #115
itlksez
itlksez's Avatar
Itís been a while since Iíve updated.
Floor is basically done.
Built a cover for the battery.
Iím working on a drawer for under the rear seat.
Drawer cabinet:
Framework for the rear seat seat-back and seat belts.
Old 03-21-2020, 12:53 AM   #116
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looking good as always.
Old 03-22-2020, 10:48 AM   #117
Tfrasca
Tfrasca's Avatar
This project is so rad.
Old 03-23-2020, 02:35 PM   #118
quillc
yv1a.com
quillc's Avatar
what bender do you use to make the bends in the tubing?
Chris
www.yv1a.com
Old 03-23-2020, 02:48 PM   #119
itlksez
itlksez's Avatar
Thanks guys!
Not sure which tubing youíre referring to, so Iíll go through them all....
The main 1 3/4Ē roll cage tubing was bent with this bender:
https://www.trick-tools.com/Pro-Tool...SABEgKqgvD_BwE
I only have one die and shoe for it because theyíre so expensive.
The 1Ē spreader bars in the cage are just 3/4Ē pipe that I bent with an old $100 hydraulic pipe bender like the ones at Harbor Freight. They bend pipe just fine, but they kink tubing.
That seat was an aftermarket Kayline seat, and the frame was made from crappy galvanized conduit. I just re-used that frame and cut some bends out of the lower section and welded them in where I needed them.
Old 04-22-2020, 05:26 PM   #120
itlksez
itlksez's Avatar
Itís all back apart for hopefully the last time.
Cage and components are painted...
Body is off, ready for about a monthís worth of body work...
The cage is back in place for storage.
Old 04-22-2020, 07:04 PM   #121
matt b
What does the body need in terms of bodywork ? I remember my CJ5 having issues with rust in the rear corner, how's your tub ?
Will you sandblast it or take a grinder to it ? Looking forward to this part of the build, your attention to detail should pay off in spades.
Old 04-22-2020, 07:34 PM   #122
itlksez
itlksez's Avatar
Thanks Matt.
The tub is mostly new metal.... The trouble spots, at least. I replaced the sides at the beginning of this build and stretched the rear wheel openings 3” rearward. Enough to help lengthen the wheelbase, but not too much to look awkward.
Where the floors meet the sides inside, it needs some sort of metalwork bent to form the corners, I need to make a removable box around the distributor in the firewall, there are about 10,000 holes to fill in the wheel wells, dash, firewall, etc..., every old sheet of metal is warped from bodywork in the past being done with a torch (and the new metal from my sloppy work 10 years ago when I put the sides on), there’s a dent in the cowl I want to remove, and the list goes on. It’s just going to take a ton of patience. My shrinking disc is going to get a workout.
Since there’s not very much paint left to hit, I’ll probably hit what I can with a wire wheel, then reach the rest with a spot blaster.
Old 04-23-2020, 12:59 PM   #123
itlksez
itlksez's Avatar
Hereís what Iím dealing with everywhere. Itís 71 years of abuse and poorly executed bodywork.
Thatís a straightedge up against the inner rear wheelhouse.
Old 04-23-2020, 01:25 PM   #124
matt b
Ouch, that's wavy! You have your work cut out!
Old 04-24-2020, 09:52 PM   #125
mondo
Love all the fab work, especially the time put into making things clean while forming something convoluted like that tranny cover, or the front radius rods.
Eric
Visalia, CA
mondo is offline   Reply With Quote
