Old 12-07-2019, 03:37 PM   #26
rms
rms's Avatar
Originally Posted by itlksez View Post
Nice project!
I wish you weren’t on the other corner of the country, I’d gladly take that drivetrain off your hands.
Thanks! Yes, I’m learning it’s definitely easier to be a TB’er on the West Coast.
-Ryan
rms is offline   Reply With Quote
Old 12-12-2019, 07:06 PM   #27
rms
rms's Avatar
So apparently the rear seat bottom is different between a 77 242 and a 90 244. The 90 (left) has some curves in it, while the 77 is flat. No problem, I swapped the 90 fabric onto the 77 foam and it fits perfectly. The seat backs look almost identical, so I don't anticipate any issues using the 90.
Also, had some more goodies show up from Ben and Taylor.
Old 12-12-2019, 10:40 PM   #28
volvoracer82
volvoracer82's Avatar
Awesome! looks like a solid project. those later seats look like they are in good shape, don't look like they have the "gangster lean" going on. If you don't already know, take the locking mechanisms from the early seats and put them in the later seats so you have easier access to the back seats. I think there is a write-up on that mod somewhere.
1983 242ti-Rally machine. 19/16 sways, mvp endlinks, gt braces, 17x9 ESM 004R's, Truetrack, Rx7 brakes, momo steering wheel, corbeau gt2's, 1992 B230ft, b230 int. atp ultimate WG, 3" turbo back, ported 90+ mani, k cam, Garrett t3/t4
1982 245DL-DD
1984 242ti-?
volvoracer82 is offline   Reply With Quote
Old 12-13-2019, 12:47 AM   #29
rms
rms's Avatar
Thank you! Yes, I need to look into swapping the locking mechanism, or I may just swap over the better foam...TBD.
Old 12-13-2019, 12:55 AM   #30
rms
rms's Avatar
Out with the old, and in with the SuperPros. Never seen bushings in such bad shape. I just love my HF 12ton press, it makes replacing bushings so easy!
File Type: jpeg 82766D66-4ADE-4D9A-8FD9-BC215B56A220.jpeg (132.8 KB, 507 views)
Old 12-13-2019, 09:14 AM   #31
Vol242vo
Keep it clean...
Vol242vo's Avatar
Are those BNE coilovers? Did you go standard or short? What inserts are you using?
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 12-13-2019, 09:35 AM   #32
rms
rms's Avatar
They are STS coilovers, 2” shorter made for Saab 900 inserts. I have the Bilstein B6 inserts with 300lb springs...we’ll see how they do.
Old 12-15-2019, 01:55 PM   #33
240wagonguy
Nice project. Consider your transmission choices. Deeworks makes the ones for a T5 and a CD009. With the T5 adapter you have to engineer the clutch actuation solution. The CD009 is already designed to use an LS1 throwout bearing. However if you are on a budget the cost is much lower with the T5. I joined a bunch of local mustang parts groups on facebook and eventually came up on a deal for a V8 foxbody T5.
Old 12-15-2019, 11:37 PM   #34
rms
rms's Avatar
Thanks, the CD009 looks to be ideal. However, I already have a spare T5 and the DeeWorks plate. I’m planning a Tilton hydraulic t/o bearing with the STS hydraulic clutch pedal. Hoping it all works together well.
Old 12-20-2019, 06:17 PM   #35
rms
rms's Avatar
I was able to finish up the boxing on the front control arms and get them painted. Just need to push in the SuperPros and they’ll be all set. On a side note, the bushings on these are not easy to get out. I couldn’t press them out due to the shape of the control arm, so it resulted in drilling out the rubber and chiseling out the shell.
File Type: jpeg D10C3CD5-BBAD-423B-A950-8B88578AA813.jpeg (123.9 KB, 396 views)
File Type: jpeg F9E459A9-E1DC-49EE-BCDE-5364A00BD8F5.jpeg (98.6 KB, 390 views)
Old 12-20-2019, 09:25 PM   #36
Vol242vo
Keep it clean...
Vol242vo's Avatar
They look great! What are you using for paint?
Old 12-20-2019, 09:49 PM   #37
rms
rms's Avatar
Thanks! Spray bomb satin black.
Old 01-07-2020, 07:43 PM   #38
rms
rms's Avatar
I started boxing the rear trailing arms today.
Old 01-09-2020, 09:10 AM   #39
MikeJr.
Gloss Boss
MikeJr.'s Avatar
You live in Acworth?
Old 01-09-2020, 11:03 AM   #40
rms
rms's Avatar
Yes Sir.
Old 01-09-2020, 02:56 PM   #41
rms
rms's Avatar
Pressing these Super Pro bushings in = not fun.
File Type: jpeg 09862862-3AAF-46AB-8CE2-350AD5B723A3.jpeg (86.7 KB, 272 views)
Old 01-09-2020, 05:39 PM   #42
rms
rms's Avatar
This is really the only rot on the car. That said it’s pretty horrific, and the contours are going to make it hard to make from scratch. Anybody got a parts car 242 they want to cut this section out for me? Long shot...yeah.
File Type: jpeg 59C3C296-97BF-4F50-8CDF-EADC4FA275F3.jpeg (87.1 KB, 257 views)
File Type: jpeg 3966C261-99A9-4F19-AC1C-546ECFB09692.jpeg (80.3 KB, 257 views)
Old 01-09-2020, 05:59 PM   #43
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Originally Posted by rms View Post
Yes Sir.
Have we met? We should meet up.
Old 01-09-2020, 06:10 PM   #44
rms
rms's Avatar
We have not, and that’d be great. I’m new to the Volvo scene.
Old 01-10-2020, 01:44 PM   #45
Old Iron
I Roll
Old Iron's Avatar
I need to find myself a 242 that someone has gone through like this. Great project.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 01-10-2020, 08:50 PM   #46
Turbo3er
Looking really good so far. what's going back into it for drive train?
2016 Dodge Challenger R/T Scatpack
2006 Chrysler 300C
1999 Dodge Ram 2500 Cummins
1987 BMW 325 PnP MSnS w/HEEBSPEED Tune
2008 H-D VRSCDX V-Rod 11.867 @ 113.86
The Departed
2009 Dodge Ram 3500
Turbo3er is offline   Reply With Quote
Old 01-10-2020, 10:01 PM   #47
rms
rms's Avatar
Thank you. A 6 cylinder from a 97 960 with a Mustang T5 transmission is going back in.
Old 01-17-2020, 07:37 PM   #48
rms
rms's Avatar
Today has me discouraged about using this b6304 from the 960. I pulled the majority of the wiring harness out, but to convert this to stand alone for the 242 is overwhelming. There is just so much wiring. I need to take a step back from that and continue to work on the chassis...there is still plenty to do.
Old 01-17-2020, 07:52 PM   #49
stevecole33
Don't be discouraged by wiring. Landing wires from injectors, coils, etc to the ECU is easy. Making it pretty can be time consuming. Tuning is my current issue.
stevecole33 is offline   Reply With Quote
Old 01-17-2020, 08:47 PM   #50
DET17
Reformed SAABaholic
+1
I'll suggest you get the actual wiring harness for your 242, and the other for the 960 engine management. Work between the two wiring diagrams to determine exactly what needs to be connected. I want to believe that the vast majority of the cabin wiring, climate controls and such, simply need 12V, fuses and grounds to continue to function as designed. Where your marriage of systems will get complex is the dash cluster and connection to the engine. Getting speed, rpm functional with your ancient analog instrument cluster will present some challenges.... but has been done many times.
These projects are like eating an elephant: cut off a piece, chew, swallow.
