Old 03-23-2020, 01:09 AM   #76
James M
Probably colorblind
James M's Avatar
Originally Posted by honeylake View Post
nice! I'll bribe ya to come put it in my 242
If the bribe is another (hopefully) clean T5
Gonna need it once your 19t goes on
Old 03-24-2020, 11:54 PM   #77
James M
Probably colorblind
James M's Avatar
More boxes arrived, southbend clutch disc, a straight copy of 940 16 valve's disc
DSC-0084
Along with the small clutch box was a MUCH larger box, containing a pre-welded oil pan from a guy on sweedspeed who was hoping to do the conversion before getting his car crushed by a tree. Phone number wonderfully censored by Siena (aforementioned GF)
DSC-0085
Old 03-31-2020, 12:33 AM   #78
James M
Probably colorblind
James M's Avatar
Last piece of the swap (before I get nickled and dimed on little **** I forgot) came in recently. Whiteblock to 5t adapter, input shaft bearing (one of the things I forgot) driveshaft and 850r clutch kit for the pressure plate, anyone want the disc?
20200325-220021
Pounded the bearing on with the help of a freezer, shimmed the input shaft and bolted up the adapter/bellhousing
20200330-002619
In the process I figured out my 96 850 block is missing mounting bosses for 960 motor mounts. Time to get better at welding
IMG-20200329-175618-01
Old 03-31-2020, 09:45 AM   #79
Broke4speed
Broke4speed's Avatar
An 850 block doesn't have the bosses? That's bizarre.
Old 03-31-2020, 10:39 AM   #80
James M
Probably colorblind
James M's Avatar
Bizarre indeed. 96 b534t5. Should be to the left of the axle bearing mount holes correct?
20200329-175236
Old 03-31-2020, 11:37 AM   #81
940 16 valve
940 16 valve's Avatar
A lot of very familiar looking parts there! We're on pretty much the same pace.
Is there 1 or 2 of the mounting bosses for the mount there?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 03-31-2020, 12:18 PM   #82
kampman
dunning-krugersquirt
Just to double check, you realize you have the mount arm the wrong way round in your picture, correct? The end that you have resting against the engine is supposed to be touching the blue towel (or crossmember, but since the towel is in the photo) and the side that's touching the towel should be against the engine block. There might still be some missing bosses/holes but that should give you a better idea of where they are.
If you knew that then carry on.
1984 245T
2006 V50 T5M
Feedback Thread
kampman is offline   Reply With Quote
Old 03-31-2020, 01:43 PM   #83
James M
Probably colorblind
James M's Avatar
Yeah I just set it down in frustration for a picture
You might be a few steps ahead with the motor in the car and everything. Find a flywheel yet? I'm starting to think a trip to the ER wasn't where a bad trade for one of those suckers
Looking under a 850 and V70 in a junkyard a while back you can see 2 more mounting bosses in the 850(top photo) and 1 on the v70. Both are missing from my block
20200216-120127
20200216-115442
Old 04-01-2020, 04:20 AM   #84
James M
Probably colorblind
James M's Avatar
After work got to throw the 242 on the lift, guess the one good thing about quarantine is that it means less jobs and more time
20200331-165921
20200331-201601
20200331-204612
20200331-211456
20200331-233910
Motor came out quite easily, no hacking of the harness necessary, just unclip 2 plugs and the harness can be draped on the engine.
Lining it up to make some mounts tomorrow, drivers side 960 mount should work but for the passenger I'll have to make an upper mount.
From the looks of it the center line on the top of the engine is this ridge in the valve cover, seem right?
20200331-233659
Should have weighed the 242 beforehand and then after to see how much the 5th cylinder ads, can't be too much since the whole new drivetrain and a hoist loads right into a 245 on lowering springs and still rubs less then an unloaded bimmer
20200331-203028
Old 04-03-2020, 03:51 AM   #85
James M
Probably colorblind
James M's Avatar
Motor and transmission are now mounted, my engine stands look like pure dog**** but are sturdy. Pan sits very close to the steering rack so both might get a visit from a sanding wheel. Wiring as a peice of cake since the whole b23 harness came right out leaving me switched 12v and 12v cracking signals in the right places.
20200401-201048
20200402-202309
20200403-003236
Got the oil system sealed (besides the pcv port on the 960 pan, what do y'all do with it) so I fired it up while jumping the pump. Tomorrow I'll have to figure out the fuel pump relay and then it will be all the ignition switch.
Still gotta figure out the cooling system, put together the clutch setup, driveshaft and charged air pipes, along with buying an intercooler, but it runs
Old 04-03-2020, 09:07 AM   #86
The Full Banana
not yet good enough
The Full Banana's Avatar
That port on the pan is a great spot for an oil separator/catch can return
-Tom 1980 242 T5
Old 04-04-2020, 03:12 AM   #87
James M
Probably colorblind
James M's Avatar
Smart thinking, maybe too smart for me but Ill try.
Ran the motor a little more today for ****s and giggles, installed the pilot bearing(6003LLBC3), clutch and pressure plate, banged my head against a wall trying to make the mustang throw out bearing fit the m46 fork.
A few pictures of my ugly mounts so I can flux my welding skills, forgot to take pictures tonight since the fork was too upsetting
20200401-230813
20200401-220425
Old 04-05-2020, 04:25 AM   #88
James M
Probably colorblind
James M's Avatar
Got the clutch setup in and working, had a real fun time trying to find out why the motor was nearly locked up whenever I'd torque down the bellhousing. Turns out my ebay input shaft was a hair too long and pushed into the back of the crank, ground it down a tad and it turns free. After some creative reworking to the clutch fork I was able to use all stock parts. M46 Fork&pivot ball, V6 mustang TOB, 242 cable and bracket. Seems like you have the opposite problem as a redblock with a t5 on these, the pressure plate is too far back to run the stock parts without some cutting.
Bracket needs welded on better then my brazing job, but I don;t have 100% argon so that's for later. Had to made a little space in the floor for the fork, but I'm not too mad about it
IMG-1836
Also made a real sexy looking downpipe out of 4 different bits I had.
IMG-1831
Reworked the transmission mount as well so it fits better. No pictures but its damn pretty don't worry
Need to put the yokes on the driveshaft and get the charged air/cooling systems in, then some test drives so I can find the stuff I ****ed up
Old 04-07-2020, 07:17 AM   #89
James M
Probably colorblind
James M's Avatar
I've ****ed my sleep schedule with this car, 4am and I'm just showering now
Keeping power steering so first up was sorting out hoses, everything I read said a custom hose was needed but after pulling the fittings out of the 850 pump and the B23 pump I saw they where about the same, b23 fitting went right into the whiteblock pump and the hose fits well, the sheath is even the perfect size
20200407-025710
20200407-025737
20200407-030027
Next the reservoir, didn't want to cut and fail to weld the manifold so I grabbed another ACE hardware sitting (that makes 5 in this swap), cut the old elbow off, tapped and applied some plastic apoxy as threadlock/sealant.
20200406-125019
20200406-125600
Fuel feed line done, its the 850 hardline fitting to a bit of copper tubing up to the rail
20200406-141521
Then came the throttle linkage, redblock spool and bracket hacked apart, some ****ty welds and the deeworks throttle body adapter later I now have a gas petal again
20200407-021318
Last for today was a little more wiring, fuel pump relay in place (still gotta find the m4.4 fuel pump trigger signal), alternator idiot light wired up and maf wires extended for RWD use. Mocked all the intake pipes up and ran the car for a little, just sitting there at idle makes me want to drive this thing
Old 04-07-2020, 10:38 PM   #90
James M
Probably colorblind
James M's Avatar
Took the car on its first test-drive. Had to steal the intercooler out of a freinds car the driveshaft out of the wagon but she runs and drives now
20200407-193719
Drove the car home tonight, open downpipe is a little loud, needs a shifter and serpentine belt
IMG-0588
Old 04-08-2020, 10:39 PM   #91
James M
Probably colorblind
James M's Avatar
Slapped a belt on and drove the car to lunch today, power steering works great and it changes as it should, back to looking sexy with the front end on too
20200408-193433
Wired up the fan relay after work, didn't get it to temp yet since I have no temp gauge, been shutting it off at lights. IACV hoses are all over the place since I don't know it's final placement yet, might have to get some preshapped hearer core hose to run it out of the way without really long bends
Old 04-08-2020, 11:24 PM   #92
honeylake
Lookin' good! Video of that sweet white block song?
honeylake is offline   Reply With Quote
Old 04-08-2020, 11:45 PM   #93
James M
Probably colorblind
James M's Avatar
I'll have to get some clips, might be time for a muffler. It's a little loud with the open downpipe. I threw a magnaflow on for a second and it sounded pretty damn good revving it
Old 04-11-2020, 07:56 PM   #94
James M
Probably colorblind
James M's Avatar
Turns out the car had been running on 4 cylinders, after some multi metering I opened up the ECU to find I had put a resistor in the wrong place Runs MUCH better now, made it to and from Vacaville today without issue
20200410-174147
Also fixed an oil leak, no more oil slicks down the undercarriage or oil in the driveway
20200409-182426
After looking at the underside of hood some spots look like Beigeish, some graffiti remover takes off the black rattle can paint, looks almost beige, but I might still buy some paint
20200411-152128
20200411-162710
Unrelated but funny I locked my only key in the car last night
20200410-223643
I couldn't fit my hands threw the hold in the transmission tunnel and didn't have any metal hangers, Siena's arms where just small enough to fit. I thought it was funny getting the keys out, she did not
20200409-180752
Old 04-12-2020, 12:06 AM   #95
940 16 valve
You've been busy! Must be nice to see it running. I like the solution for the power steering return line. Interesting to hear how it holds up after a few months.
Old 04-12-2020, 01:08 AM   #96
James M
Probably colorblind
James M's Avatar
I pretty much lost a week of my life to this swap, but it was well worth it
I'm keeping my eye on it, no leaks yet. Seemed like a better option then cutting the intake to me.
You ever figure out the M4.4 fuel pump relay trigger? I've got it jumped to the ECU switched 12v signal but that's probably not the best (or safest)
Old 04-12-2020, 11:37 AM   #97
Vol242vo
Keep it clean...
Vol242vo's Avatar
Locked keys in 242?
Use a large Phillips screwdriver and take out the rear window...
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 04-12-2020, 06:18 PM   #98
mblue240
mblue240's Avatar
Originally Posted by Vol242vo View Post
Locked keys in 242?
I've done this at least 4 times since I got my 242. Eventually I'll swap locks like my 89 has, so you can only lock the driver door with a key.
-Michael
Tbricks build
Yep, Michael is right.
Old 04-12-2020, 06:25 PM   #99
James M
Probably colorblind
James M's Avatar
Locked keys in 242?
I tried but the screws seemed ceased. Fishing for the keys is cheaper then buying a new latch
Removing the paint is slow. I forgot to get gloves and thus stuff isn't that nice on your skin.
Seems like there is several versions of 172 rose beige, anyone know how to get the right paint for a 83? Looks like the cowl has been repaired, or maybe the whole car?
20200412-152925
20200412-152914
Old 04-13-2020, 11:34 AM   #100
J ripper
The fella I got it from said he had some paint “matched up” and painted the cowl vent and I believe the A pillars were done too.
People love it when you lose, they love dirty laundry.
J ripper is offline   Reply With Quote
