Old 03-27-2020, 12:17 PM   #1
IansPlatinum
IansPlatinum's Avatar
Default Rusty, the 1971 145S
In July of 2018, while bored on a business trip, I scolled upon a 1971 145 for sale in albuquerque, NM, on craigslist. It had missed my 145 searches because it was simply listed as "1972 volvo" (incorrectly listed year, too).
It was being parted out at a small JY in NM (nobody had bought parts off it yet), the JY owner had purchased it from the family of a mechanic who passed away. The story is unclear whether it was his car or whether he purchased it and let it sit, or whether the PO just gave it to him... either way, no title, no history.
Here are the original ad photos:
I inquired, had the JY owner take a few more pictures of areas of concern, sent a Walmart money gram, had him fax a bill of sale, and scheduled a car transporter to pick it up.
When it arrived, first order of business was to wash off that NM dust from the body and engine bay, and inspect body for rust and damage.
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 03-27-2020, 12:19 PM   #2
IansPlatinum
Squad
Wanted to see how much life I could inject into the single stage paint with some compound:
Old 03-27-2020, 12:33 PM   #3
matt b
That's not bad at all! The good thing is that most of those paints have enough thickness left for agressive methods like a wet sand, etc... Super fine steel wool and lots of Windex will bring those windows back to life too.
Can you get a bonded title out of TX for a NM car ?
Old 03-27-2020, 12:45 PM   #4
IansPlatinum
And then I neglected rusty for about a year while I focused on other car projects (and other non-car projects) instead of clearing my queue.
After a time of considering selling rusty, I finally said F*** it, and just started fixing it. Sad that it took me this long to get to this point.
The steering was slop. hmmm, wonder why?
also adjusted the steering box flange further down the splines to pull the bushings down onto the shafts.
all the plastic parts were nasty. Brake MC leaky & MC reservoir had black gunk in it. Wanted to keep to OG 'tall' reservoir, so I threw the plastic parts in the washer & vapor hone.
after:
added some new battery cables, because the old ones were downtown sketch-ville
And also replaced the positive junction with a new one from hiperf, as it too was bound to let some wiring harness smoke out
(electrical tape on positive harness to be replaced with shrink wrap once the spade is changed out for a proper butt connector)
After attempting to start it (replaced plugs, gapped points, new wires, new coil, &put fuel pump line intop remote gas can), I was greeted with the pleasant sight of gasoline dripping from the carbs. Rebuild was in order before I could start 'er up
also decided that since I had them out, I'd plug them up and send them through the vapor hone after removing the loose dirt.
Bad idea folks. Abrasive always finds a way in... especially because I didn't realize the two front holes go straight into the vacuum chamber area. I should have just disassembled them fully and then blasted them... you live and you learn. After several disassemblies to remove trapped abrasive, they're finally working right and clean at least.
I also decided to clean up the combined manifold and plug the butterfly ports with plugs from hiperf
Haven't painted it yet, planning on getting some eastwood hi temp coating
who knew the heat shields were supposed to be galvanized in appearance?
shortly after, the choke decided it didn't want to be a choke any more. hiperf hooked me up with a good used one at a great price
Old 03-27-2020, 12:56 PM   #5
svinkle
Nice work!
Where did you connect the battery ground cable? I’ve never been 100% sure whether mine is correct after having the motor out for a while a couple years ago.
1971 Volvo 145
svinkle is offline   Reply With Quote
Old 03-27-2020, 01:06 PM   #6
IansPlatinum
After the engine was confirmed to be able to run, I then set about setting up the vehicle to be able to drive
New tires were in order...
note the original spare tire on bottom:
new michelin XZX tires and freshly sandblasted / powdercoated wheels
makes the car look so much better
gotta empty out that 20 year old gasoline from the fuel tank
dropped off the radiator & gas tank at the radiator shop for some good ol fashioned deep cleaning
Boat picked up the cleaned fluid vessels after they were done:
Since the car is staying outside for the most part, the door seals needed to be replaced to keep water out.
yuck
good used seals off a '92 244, cleaned with a product as seen in another popular thread 'round these parts...
scored a new aftermarket tail light on the cheap to replace the all-red -69 style:
then I started tackling the interior:
minimal rodent turds
lots of mold
also some pretty serious rust on passenger rear floor pan
for now, I scraped up the butyl damping sheets to prevent water from getting trapped and making the rust worse. soon, the 3 good pans will get stripped back to steel and coated with POR15 and some color matched rattle can paint from VP. I have a new floor pan for the rear passenger in the garage, waiting for COVID-19 to blow over before I take it to be welded in.
unfortunately the seat skins are not original. they were reupholstered at some point (so someone cared about the car at least). probably whenever the car was repainted (90s?).
I'll need to source some OG skins to make a pattern and reupholster.
webbing was some wort of tarp material
I rewebbed the driver seat and put the skins back on so I can drive the car until I get the new skins made. Want to order new foam from skandix too.
soon.....
Old 03-27-2020, 01:07 PM   #7
IansPlatinum
Originally Posted by svinkle View Post
Nice work!
Where did you connect the battery ground cable? Ive never been 100% sure whether mine is correct after having the motor out for a while a couple years ago.
Mine goes to the side of the engine block. I have an AC compressor mounted, so it's technically sitting on the AC bracket.
Old 03-27-2020, 01:19 PM   #8
IansPlatinum
After some new braided stainless brake lines from hiperf (no pics yet) and a full brake flush, valve job, carb balancing, choke adjusting, tire inflating, diff oil changing, m40 oil topping off, coolant top off, engine oil change, ....
....rusty took it's first test drive in many years. The latest date I can find on the car is 2003 for a NM registration.
Yesterday, rusty even got to visit a gas pump for the first time under current ownership... without license plates , thanks for the registration waiver gov. greg abbott
The carb were a little challenging to tune... here's where they started out ... this is warmed up with choke OFF
With a syncrometer & adjustments to the linkages, idle set screws, mixture screws, and choke/throttle screw, they are finally balanced and run smoothly. Hot starts still take a bit of cranking (i'm suspecting hot start valves aren't working right).
On the voyage, there were some funny noises... clunks in the rear, a 1st gear whine, still sloppy steering...
on the bright side, a lot of the electronics work. alternator, front wipers, rear wiper, tail lights, headlights, brights, horn, oil pressure light, temp gauge, gas gauge...
some things that don't work: blinkers, hazards, cluster lighting, speedometer, choke light
Some parts I changed previously but don't have pictures of:
brake master cylinder - VP
brake hoses - hiperf
oil cap seal - VP
fuel hoses - autozone
fuel level sender - VP
carb seals - hiperf
ignition lock cylinder - jack
also did a warm compression test, results seem decent:
1: 150
2: 150
3: 140
4: 140
Old 03-27-2020, 01:20 PM   #9
The Librarian
Originally, the battery ground cable is bolted to the weld nut on the battery tray. The engine is grounded through the strap between the frame and one of the bolts for the trans brace on the block.
Old 03-27-2020, 01:30 PM   #10
Tfrasca
Tfrasca's Avatar
What's up with the rubber hose on the line coming out of the master cylinder?
Old 03-27-2020, 01:31 PM   #11
IansPlatinum
thanks, yes I'm not holding back on the paint. Goal right now is to get it looking OK, and protect the exposed rust areas with some color matched rattlecan until I get body work finished on it & repaint (maybe by 2022?)
oh yes, I sprayway-ed the crap outta those windows. they are actually transparent now. needs a new windshield though.
great question. I'll do some research, it might be in my best interest to actually 'lose' the bill of sale and claim the car was purchased in TX if there is legislation preventing out of state bonded titles. I purchased my 850 with a filled rear section of the title which forced me to go the bonded route, so I've done it before....
Old 03-27-2020, 01:33 PM   #12
IansPlatinum
probably to insulate the terminal... that's the side where my positive terminal sits, and the brake line would be grounded so arcing would happen should they contact. My 92 240 has the same thing from the factory, maybe the PO was attempting the same?
Old 03-27-2020, 02:29 PM   #13
IansPlatinum
Something fun showed up in the mail today.
What could that be?
Ah, a set of 4 NOS door cards! Thanks VP
It'll be a while until these get installed sadly. Haven't decided if I want to wait until after paint, but it needs to definitely be after I replace window scrapers, and installed vapor barriers on all the doors
Old 03-27-2020, 02:46 PM   #14
Oerski
what did these set you back? I got my PV cards from them a couple years back for about 250....
What could that be?
Oerski is offline   Reply With Quote
Old 03-27-2020, 03:07 PM   #15
IansPlatinum
way less than a 50 year old set of matching correct-color NOS door cards shipped from sweden should cost... $300
Old 03-27-2020, 03:24 PM   #16
IansPlatinum
Next batch of goodies- any suggestions, anyone? Goal is to get the car inspected & registered now.
Old 03-27-2020, 05:03 PM   #17
Duder
Comes with a free Frogurt
Duder's Avatar
Cool revival story - keep it up!
Old 03-27-2020, 08:31 PM   #18
sksmith
sksmith's Avatar
Looks good!
Old 03-28-2020, 10:36 PM   #19
Harry Tuttle
^^ What those guys said. Great to see you getting after it so forcefully.
That car is the same color as the '71 145 that I drove a quarter million miles some years back.
Originally Posted by sbabbs
just gutless low compression k-junk
Old 03-28-2020, 10:43 PM   #20
IansPlatinum
That's fun- this one has close to a quarter million on it. And the odometer is not turning while driving so who knows, maybe more.
There're some interesting stickers on the car too. DoD, 1981 mexico tourist...
Old 03-28-2020, 10:55 PM   #21
Harry Tuttle
Cool DOD stuff.
I should add that mine had 140K on it when I got it. Not suggesting that it went 400K with many original parts left in it...
The sad thing to think about is that when I sent it to the crusher it was probably a lot like what you started with.
Old 03-29-2020, 09:02 AM   #22
Vol242vo
Keep it clean...
Vol242vo's Avatar
Very cool story and a great looking 145! Pretty cool you were able to buy it from the junk yard, that wouldn’t happen at the yards here. You have already done some amazing work. Hope you enjoy it for years to come.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 03-29-2020, 10:09 AM   #23
IansPlatinum
Thanks everyone. It's very humbling to receive complements from people that have cars lightyears nicer than mine
Here's the engine bay when I received the car, vs how it appears now
And a video of the smooth idle with tuned carbs!
https://i.imgur.com/pIEDjYs.mp4
Old 03-30-2020, 02:48 AM   #24
Scaramanga
Great car and well done! Does your car have air condition? If you ever get tired of those front overriders Id be happy to buy them They were never popular here in Sweden...
Volvo 142 1968, 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 03-30-2020, 09:13 AM   #25
IansPlatinum
Don't know if I could ever part with those overriders, i love them!
The car did come standard with AC. I removed the belt to the compressor so i have not tried running it
