Old 04-01-2020, 09:56 PM   #26
IansPlatinum
IansPlatinum's Avatar
Started assessing driver's floorboard. Found a hole about the size of a quarter after I started stripping the paint. ****. Now I guess I gotta weld a patch panel into driver's side. Looks nastier underneath.
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 04-02-2020, 11:34 AM   #27
matt b
Looking at the undercarriage, you may have more to deal with. I'm not a fan of that black tar that was sprayed by dealers in the 60's and 70's. It didn't always do what it needed to do.
Old 04-02-2020, 12:33 PM   #28
IansPlatinum
Yep, I'm going to have some work to do for sure. I'm not necessarily going for show quality, so whatever keeps the rust at bay works for me.
Plan right now is to get every piece of rust exposed, scraped down, burned out with phosphoric, and then coat with epoxy primer.
There's also rust on the seams that was hiding under the seam sealer. Wondering if I can scrape a bunch away, and then heat the seam up and let the phosphoric acid get pulled in via capillary action. I really don't want to separate the spot welds just to get the rust out.
Old 04-03-2020, 06:09 AM   #29
sksmith
sksmith's Avatar
Have fun removing that ****. This floorpan is listed for 240's but fits (with some persuasion) in 72 up: https://raybuck.com/product/1975-93-...n-driver-side/
Since you have a 71, it may not be much help, but you could give it a shot.
It looks to me like after you clean the undercoating you can get the floor braces cleaned with a good wire wheel.
Once you get into it, you'll probably need to remove more than you think to get to good metal.
A spot weld bit drills those out in no time. I also have a Steck panel buster which helped separate the remaining weld. Just don't go thru the brace like I did in a fewspots. Then, if you can weld, plug welds aren't too hard to do. Even I can do them!
Old 04-03-2020, 09:38 AM   #30
IansPlatinum
lol thanks
ended up taking apart the blinker stalk, the right blinkers would only come on if you jiggled the stalk vigorously. my god that thing was frustrating to get back together. There's a spring loaded metal cylinder that wants to push the entire assembly apart. It probably bursted out and flew across the kitchen 5 different times.
cleaned the contacts and got it back together, and voila, both blinkers work... but the right blinkers now activate the brights
bent the contact back a bit, and now it works perfectly.
Blinkers, side indicators, tail lights, brake lights, reverse lights, and running lights all work now. Head lights work too, but the driver's side has moisture so I ordered some replacements.
It's amazing how brutal the sun is
Old 04-03-2020, 08:32 PM   #31
IansPlatinum
Decided to investigate the instrument cluster after fuel gauge started acting up despite the new sender. Took it out and noticed something rattling around inside...
Might explain the speedometer not working.
Sure enough, it's the retainer for the rotation of the ribbon speedo.
Went ahead and cleaned up the circuit board too.
Turns out the voltage regulator was flopping around due to broken rubber support. Also the ground wire was barely hanging onto the solder point by 1 or 2 copper strands. Soldered in some new wires.
Rheostat was also not working. Wonder why...
Cleaned up the contacts, now it seems to work!
Verified speedo function as well. Turns out odometer turns too! Guess I got lucky
Old 04-04-2020, 01:54 AM   #32
Oerski
Oerski's Avatar
Subscribed This gives me hope for my safari rust bucket
Oerski is offline   Reply With Quote
Old 04-06-2020, 11:33 AM   #33
IansPlatinum
New motor mounts and trans mount for rusty. Wonder what year this West German engine mount was installed... needless to say, I think it has done its job. Trans mount was also west german. Unfortunately, the new mounts from VP are made in India. :(
Old 04-06-2020, 01:09 PM   #34
Duder
Comes with a free Frogurt
Duder's Avatar
India is one of the major rubber tree growing locations in the world; if the mounts are natural rubber then they're being made closer to the source. Maybe modern Indian rubber is better than whatever cold war era W. Germany could get its hands on.
Old 04-06-2020, 01:51 PM   #35
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
This wouldn't surprise me in the slightest.
1971 142 beater/fake racecar
1972 145 sh*t hauler
Originally Posted by propav8r
The incest is implied.
Old 04-06-2020, 01:59 PM   #36
IansPlatinum
You can have the best rubber in the world, but if your process & QC is out of wack then it doesn't matter. My experience is that european-made components tend to by of the highest quality compared to others. who knows, maybe these Indian motor mounts are indeed better. I probably won't be putting more than 1000 miles on the odometer this year, so it doesn't really matter. I just like the country of manufacture to be consistent/original when possible. Like how my new michelin XZX repops are stamped with 'made in serbia'
Who knows, maybe serbian tires are fine, but I'd prefer my michelins to be made in france is all...
Old 04-06-2020, 04:04 PM   #37
matt b
That's going to raise the engine and trans back to normal heights!
Old 04-06-2020, 04:06 PM   #38
IansPlatinum
And apparently take some stress off the gearbox too, less 1st gear whine
Old 04-26-2020, 12:54 AM   #39
IansPlatinum
Today rusty received 10 gallons of gas only to start spilling it onto the ground
Turns out I didn't quite seat the sender. Once I let the gas clear I reinstalled it and all seems well again
Old 05-03-2020, 11:32 PM   #40
IansPlatinum
Lol
Old 05-04-2020, 11:27 AM   #41
matt b
That rubber looks like dry cheese. How sketchy was the rear end handling ?
Old 05-05-2020, 11:58 AM   #42
IansPlatinum
I was able to make out a tiny little number from the remains, which sorta indicates a genuine part.
It was... shifty. The tiny little bit of torque produced by the b20 would very noticeably shift the rear end. Still gotta do the other side.
Old 05-06-2020, 11:32 PM   #43
IansPlatinum
Other side was just as bad.
Genuine 240 TAB tool works nicely for this application
Going in...
lol #2...
Old 05-07-2020, 11:59 AM   #44
matt b
Wow, that's not good! That car has been driven at least!
Old 05-07-2020, 12:06 PM   #45
IansPlatinum
It tracks so straight now with the new bushings. Now the gas pedal does not steer the car
Old 05-08-2020, 10:56 AM   #46
IansPlatinum
Installed an excellent condition 'correct' cluster courtesy of Alschnertz. All I can say is wow!
It fixed my sticky speedo issues as well!
Also in the works is acquiring this horn pad...
Old 05-09-2020, 04:24 PM   #47
IansPlatinum
Today I rebuilt the 12V cigarette lighter socket.
No wonder it wasn't working
Unfortunately it broke during disassembly
This spare socket from an 850 has a contact that looks good
And its a perfect fit!
Fully assembled
And it works! LR tire has a slow leak (probably the inner wheel seam)
Slowly getting there...
Old 05-10-2020, 04:06 PM   #48
Estateman
K-Jet or Bust
Estateman's Avatar
Incredible progress, looks even better in person than on here. Now that it’s running and driving you’re light years ahead of the rest of TB still on jack stands waiting for the crusher to call. I can’t wait to see this driving around town!
88 245 - M46 3.73 Gears
>>FEEDBACK<<
Estateman is offline   Reply With Quote
Old 05-10-2020, 07:37 PM   #49
svinkle
Looks like a nice wagon. Keep up the good work!
1971 Volvo 145
svinkle is offline   Reply With Quote
Old 05-12-2020, 06:40 AM   #50
Scaramanga
Well done! Nice to see your progress!
Volvo 142 1968, 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
