Old 07-01-2020, 08:45 PM   #26
Estateman
K-Jet or Bust
Estateman's Avatar
Originally Posted by white855T View Post
Steel diff covers use a gasket. It's recommend to use a Volvo gasket. Aluminum cover uses a sealant. I've personally used the green rtv and it works well. No leaks to report.
Which years did the steel cover come on? I ordered a rubber looking diff gasket genuine Volvo.
88 245 - M46 3.73 Gears
>>FEEDBACK<<
Estateman is offline   Reply With Quote
Old 07-01-2020, 09:32 PM   #27
white855T
Everything up to 91 for 240 uses a steel cover. 92-93 240s are the only years that had the aluminum cover.
Old 07-09-2020, 11:04 AM   #28
esmth
1991 244 LH2.4 m46 330k? miles
Old 07-13-2020, 02:21 PM   #29
esmth
I got a thing. i want to make the exhaust less obnoxious
the volvo assumed shadetree hackery position
so there is no way to just clamp on the muffler without it hitting something on my current exhaust. I ended up just pulling the whole back side of the exhaust to get some better measurements. screw working on wet gravel.
I want to put it here, where the original resonator should have went. but it will definately needs to be welded and the hangers replaced. No way the clamps would seal on the bends.
I put it on the end just to see what it'd sound like. it is definately better but i bet it'll sound better/quieter in the res spot.
Sorry for no rev video. didn't want to piss off my neighbors!
Old 07-13-2020, 06:13 PM   #30
IansPlatinum
IansPlatinum's Avatar
Just drive it like that!
But in all seriousness, that still sounds too loud even with the resonator. I'd be willing to bet your muffler is wasted. I didn't realize they could degrade internally until I took my old one off and looked inside. They have steel baffles inside that corrode away and eventually stop producing the acoustic effects that they were engineered to produce.
My car has no resonator and a new stock muffler. It is quieter than what I heard on your video... the only time I notice my car's exhaust it on the highway, when I hit the resonance around 2.5-2.7K RPM. Even then, it's not that loud, just could be quieter, ya know?
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
IansPlatinum is online now   Reply With Quote
Old 07-13-2020, 10:09 PM   #31
esmth
Itís not the stock muffler, itís a mangaflow 18x6x6 2.5Ē straight thru glass pack haha. nothing else in the exhaust. It doesnít sound horrible but it hits maximum fart cannon like you mention from 2800-3100 rpm. Sounded nice when a turbo was muffling the tractor noise but now that itís NA and the glass pack is getting worn out itís pretty obnoxious!!
