Old 06-22-2020, 12:35 AM   #1
James M
Probably colorblind
James M's Avatar
Default Matcha: The Green 245
The car:
1976 Volvo 245 that's been sitting since 2010
B21f with a blown head gasket, reason it was parked
BW55 known for great highway cruising RPM
Power steering and No AC, good thing we have cold California summers….
Brown interior in relatively good shape
Two Cherrybomb glasspacks that need removed
Named Matcha after the tea, i’ve never had it but my girlfriend likes it and says thats the color
Some rust in the hood, cowl and inside the hatch glass, worst of it being up front
20200621-102634
The plans:
Fix the head gasket
Wax it properly
Get it running well
Restore it to stock
Smog and register it
Fix the rust
Going to be a DD for my girlfriend, along with a roadtrip/camping vehicle because my wagon now has too much oil in the cargo area
I’ve been told I have to keep this one stock, mods are limited to things that help make it more drivable, no turbo unless its a BAR approved swap for highway merging, no manual swap unless I teach her how to drive manual properly.
Also going to be trying to clean up everything I touch, it comes off the car it's getting washed, degreased, painted (if it should be) or otherwise made better then it was before
Very much needs it:
20200621-131915
The story:
So i’ve been messing with some BMW stuff with my brother and we needed a transmission, he went down to Vallejo to grab one we found and sends me a snapchat:
Screenshot-20200607-135443-Snapchat
I check the DMV and it's a 76, if it was a 75 I'd be down there with cash in hand in a heartbeat. The next weekend we went back and talked to the owner. It’s been his parents' wagon since new, mom used to drive him to school, dad wouldn’t let him work on it as a kid. He had stories about installing a sedan swaybar to have his mom ask “what did you do to my car...it drives nice” and listed off everything ever done to it. Agreed on a price and to come back next weekend
20200613-121624
Went back today and loaded it up, after 10 years of sitting it’s ready for it to see the road again
20200621-103907
20200621-110507
Got it back and tore the head off. Pulled the drain plug and out came a couple gallons of milkshake, after popping off the valve cover I was greeted by some nice rust on the cam, seems like it will clean up
20200621-135505
Also found the only 11mm bolts i’ve ever seen on a volvo, why...just why
20200621-151823
Got the head off and it looks better than I feared, good looking cylinder bores and no rust (or pictures). Cleaned up the valve cover and head some, going to try rust remover on the exhaust manifold and see what I can do to clean the different aluminum parts.
Also took a swing at the paint, cleans up well with just a wash, I’ll need to wax it as well. Seller said it was repainted once, it shows in a few spots but overall looks nice
20200621-172320
20200621-172326
20200621-130959
20200621-131822
Almost sad it’s not Beige but the green looks great and it should make a good DD, very excited to get it on the road
Old 06-22-2020, 02:04 AM   #2
122power
dude
122power's Avatar
Nice find! Paint will come back its nuke proof, just takes some care. The brake lines are 11mm also.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 06-22-2020, 03:35 AM   #3
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Nice... The Bw55 (Bw35 is the B18/B20/B30 autotragic) is going to be a bit obnoxious on the highway, tho. I'd either consider swapping the 3.91 out for a 3.54 from a M46 Diesel or B21F-MPG car, or hunt down an Aw70 or 71, then make some brackets to shift the crossmember back one bolt hole per side.
The brackets can be the same thickness as the stock spacers used on the auto cars, just need to be three holes long instead of two. Weld a nut to the third hole. Use norma length bolts in the forward and rearmost bolt holes, and a couple longer bolts in the middle holes to hold the brackets and the crossmember to the frame rails.
The only other things you'd need would be the driveshaft, the shift linkage, shifter assembly and OD wiring, if you plan to retain the lockout function for the overdrive, or just the driveshaft, tranny, shift linkage, a solenoid block off plate, and the brackets, if you don't mind that it will upshift to 4th at all times. Driveplate is the same between the Bw/Aw55 and the Aw7x trannies on cars older than 1989.
@1982_volvo_242_turbo on IG
Old 06-22-2020, 07:35 AM   #4
volvowagoon
volvowagoon's Avatar
Nice score. My girlfriend loves DDing her 245. I hope yours does too!
1986 Buick Grand National - The show car
2002 Camaro V6 T5 +T - The fun car
2010 C30 T5 - My daily
1989 245 DL - Girlfriend's daily
IG: @v6buick
Old 06-22-2020, 02:12 PM   #5
Duder
Comes with a free Frogurt
Duder's Avatar
Cool, another pea green wagon. That's how they're known around here. I have a '75 and it's universally appreciated, by car people and non car people alike. Buff the paint out with a gentle compound, nothing super aggressive, and it should come out great. The color completely changes (darkens) when buffed out.
Old 06-22-2020, 05:11 PM   #6
wishicoulddrift
I can second this. Still cannot decide which way I like it more... So sometime it is green and other times it is white-ish.
wishicoulddrift is offline   Reply With Quote
Old 06-22-2020, 05:19 PM   #7
that is a great color.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-23-2020, 01:13 AM   #8
James M
Probably colorblind
James M's Avatar
Fixed, thanks for the heads up. I will propibly move to a AW70/71,being at 4,000RPM just to keep up with traffic does not sound fun
I should still have most of the shifter assembly and the driveshafts from my wagon when I took out the auto. Gonna have to reread that a few times when I start collecting parts.
I've seen pictures of both your bricks, I'm not copying you a promise.
Towing it back I had two guys in completely restored 50s/60s Alfas honk and give thumbs ups. Defiantly going to get more attention then my other bricks.
She's already quite exited about it. Got a text after work asking not when I would be home but if I was working on the car, she's got her priorities in the right places.
20200621-172426
Paint looks darker when wet, hopefully the slightly deeper green is what shows up after some polishing. Unfortunately the previous owner bent the hood some between the first time I saw it and when I picked it up. Drivers side has a gap, passengers is alright
Old 06-23-2020, 07:18 AM   #9
white855T
Hopefully it's not bent and it's just the hinge. First thing you do on an old Volvo is lubricate all the hinges.
On the trans swap, get the overdrive block out plate. $25 on Ebay. Keep it simple so you can enjoy the car.
Old 06-29-2020, 01:08 AM   #10
James M
Probably colorblind
James M's Avatar
I was hoping to spend the entire weekend on the car but ended up spending most of it dealing with my brother putting his car in a ditch and his friends car breaking on the drive back. Ended up getting a call at 11:30 friday to get the dolly and drive out to the hills. Long story short a 245 will tow an E30 and carry 8 people at the same time
On to Matcha! With the few hours I did have on the car we:
Replaced the drivers taillight lens and vacuumed the interior
20200628-143953
Cleaned the Kjet, unstuck the plunger as recommenced by your favorite local junkman
20200628-191214
20200628-192339
Got the fuel pump working with a few taps of a hammer
20200628-194348
Drained the old gas(found another 11mm)
20200628-193019
Pushed the rest out with the pump revealing some tasty apple juice
20200628-194439
Threw in a spare battery(another damn 11mm!)
20200628-124438
Removed and replaced two broken studs from the head, came out pretty easily
20200628-141115
Found some more rust under the lifter buckets
20200628-132343
Lifter buckets themselves came out after some ATF and hammer treatment, valves didn't even close on their own because the buckets where so rusty
20200628-203436
Gotta pull the valves later this week and check the related components, anyone care to confirm 530 lifter buckets, valve springs and retainers will work on a 160 head?
Old 06-29-2020, 02:28 AM   #11
John242Ti
John242Ti's Avatar
Buckets work fine. The B21FT head that's mated to the B23FT block in my 242 has shim buckets from a 1992 B230F in it. The springs are different on later 160, 398, and all 530 heads. What's called a type 2 spring is used on the later heads. The valves are the same size, tho.
Old 07-04-2020, 06:38 PM   #12
James M
Probably colorblind
James M's Avatar
Got the head town down, little worse for wear for sure. Two broken springs, lots of rust on 7/8 of them. Valves need cleaned up but seem fine. Gonna have to find the 530 head parts I've got bagged up somewhere.
20200704-153426
20200704-153419
20200704-153323
20200704-153317
20200704-153311
Head itself is covered in rust, got cracks between all intake and exhaust valves, cylinder 1 is spreading into the ports but the others look contained.
20200704-155133
20200704-155134
20200704-155233
Old 07-06-2020, 10:51 AM   #13
With how common and cheap a decent 8v heads still are, I would definitely start with something that hasn't been sitting for so long.
Old 07-07-2020, 01:50 AM   #14
122power
dude
122power's Avatar
Yeah i had a turbo 85 245 that sat needed a head gasket i was told. So i did it. Still has issues. Hmm so did more testing and more testing. Finally found the issue. There was a pin hole in the #4 exhaust port. Yipee so back off the head went.....fun times
Old 07-27-2020, 03:12 AM   #15
James M
Probably colorblind
James M's Avatar
As recommended I got a new head, well a whole motor but the bottom end is only going in if the current one doesn't do well once it runs. New head is torqued down and I started to build it back up before realizing I misplaced at least one bag of bolts, was using rust remover on them at home, now they are gone.
Real progress came in the form of interior work, old carpet was looking more green then the paint before the washes
IMG-20200726-235515-01
Pulled it up to reveal some very solid floors, can't wait to get the outside back to this color
IMG-20200726-235519-01
In went some new carpeting, from a 88 245 so a little different but fits well and looks much nicer
IMG-20200726-235517-01
IMG-20200726-235521-01
Tried to add gas but the locking cap doesn't want to unlock,
Old 07-27-2020, 12:34 PM   #16
oldschoolvolvo
oldschoolvolvo's Avatar
nice project...color is excellent.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-27-2020, 01:37 PM   #17
kampman
dunning-krugersquirt
Wow, that old carpet was gross.
1984 245T
2006 V50 T5M
Feedback Thread
kampman is online now   Reply With Quote
Old 07-28-2020, 01:48 PM   #18
Coupid
Coupid's Avatar
Nice work, I bet that carpet didn’t smell very good either. Thats
the best 240 color imho.
1988 745T
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is online now   Reply With Quote
