Old 07-05-2020, 01:12 AM   #1
ogamer777
Loading...
ogamer777's Avatar
Default Manual brake bleeding taking forever and fluid/air going back in?
1984 242
I purchased and installed remanufactured front calipers, pads and rotors. I also went ahead and purged the brake fluid system and attempted to replace it. Well here lies my problem.
I do not own a power bleeder so I went with the manual bleeding method. I followed the correct order in which to bleed calipers. So as we are bleeding the rear driver side caliper, very little fluid is coming out. I am using a power bleeder bottle to catch the fluid. https://www.ipdusa.com/products/4679...ch-bottle-1820
What I am experiencing is the fluid/air will go towards the bottle, then once I close the bleeder screw, the fluid and air mixture will still go back into the caliper somehow. What is going on here? I have never experienced this while manually bleeding the brakes. When I have the hose detached, the fluid comes out and I cannot tell if any air is getting in through the bleeder valve. Fluid is going down in the reservoir. We ended up trying to bleed it for long time, like 45 minutes. At one point, it seemed like air was just coming through the hose but like I said before, the air would just go right back where it came from.
What am I doing wrong? This is my first time bleeding brakes on a 240.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 07-05-2020, 01:35 AM   #2
Default The Creek Is Rising.
When replacing calipers always install one caliper at a time starting with the fronts and immediately bleed the freshly installed caliper starting with the top bleeder since air rises.
Continue swapping calipers [or lines] until they are all swapped and bled one at a time and no bubbles are coming out.
Then bleed again at least once in the recommended order since that uses the least amount of fluid but it is not magic in and of itself.
Lord help you if you have the front[s] open and bleed the rear sending air out back to be trapped in the proportioning valves.
Last edited by Redwood Chair; 07-05-2020 at 01:38 AM.. Reason: No Paddle Or Pedal.
Old 07-05-2020, 02:46 AM   #3
ogamer777
Loading...
ogamer777's Avatar
Thanks, Ken. So what should I do if I had lots of air in the system beforehand? I think I tried expelling the fluid out long ago when the brake lines were disconnected.
When I was bleeding the rear driver caliper, all other bleeder screws were closed.
Old 07-05-2020, 09:12 AM   #4
283SD
It might be a pain but if [ you might need a helper] you open the bleeder, press the pedal down, close bleeder, release the pedal, repeat. this way you don't compress the fluid and trap air. Think of stop and go traffic ,verses an open road.
Old 07-05-2020, 10:41 AM   #5
Always bleed until there is a good pedal before proceeding in any way.
Stone age buy a Motive power bleeder.
Old 07-05-2020, 02:28 PM   #6
I used to do this manually on my 240 series. But it always is a long protracted process when doing this manually with a helper. Even when I would be successful. It would still take going around the car three or four times. One tip that helps a lot is to use a small hammer to gently tap the lines and proportioning valve, warning light valve and various bends and areas that can trap air. This will help push the bubbles to the end of the line. Another thing to do is only use the part of the master cylinder that was being used to brake with. Otherwise you may tear a seal and you need a new master cylinder. Also I've had success with bleeding the front calipers first and after both front calipers are working then go around in the standard order.
I alleviated all this work by buying a Motive power bleeder which has served me well for about 15 years. One of the tools that has paid itself back innumerable times.
Old 07-06-2020, 07:41 AM   #7
ogamer777
Loading...
ogamer777's Avatar
Are you talking about the motive power bleeder with the pressure gauge on it and you just pump it by hand? I think I read you need 20psi to go through the brake lines?
Old 07-06-2020, 10:54 AM   #8
No gravity bleeding works too and is helpful for some things like removing excess air when changing the lines and calipers but for getting a good flow and a timely job the Motive is the right tool.
Also don't forget Art's brake stick when you have the system open to fiddle with things.
Old 07-06-2020, 12:23 PM   #9
ogamer777
Loading...
ogamer777's Avatar
Thanks again, Ken. What is this brake stick you speak of?
Would this be the power bleeder you guys have used: Motive Products, European Power Brake Bleeder, 0100, Hand Pump Pressure Tank with Adapter https://www.amazon.com/dp/B0002KM5L0..._jc1aFbHAR43HH
Old 07-06-2020, 01:24 PM   #10
Yes IPD has the motive too.
https://forums.turbobricks.com/showp...0&postcount=14
Old 07-06-2020, 02:41 PM   #11
ogamer777
Loading...
ogamer777's Avatar
Much obliged
Old 07-06-2020, 03:05 PM   #12
Oh and if you do get air trapped in the rear proportioning valves get the back end of the car as high as you can safely and tap on them with the plastic handle of a screwdriver while the fluid is running so you don't completely destroy the undercoating.
Old 07-06-2020, 06:23 PM   #13
Yes, I was referring to that model of Motive. Also I use about 15psi to bleed. I used to use 20psi but it works better with the lower pressure.
Old 07-06-2020, 06:44 PM   #14
Above 15 you should probably temporarily zip tie down the MC reservoir so it can't pop off and make an ungodly mess.
Old 07-06-2020, 08:56 PM   #15
neptune
Is 19 cars too many?
neptune's Avatar
Does the same thing happen with all four? Are you sure the new calipers aren't defective? Bleed screw not sealing? I had sooo many issues with the ones I got from FCP and had to replace them again to get the car to bleed.
Or is it just so full of air that manual bleeding isn't pushing fluid to the calipers?
I pulled all four at the same time, replaced them, bled them, drove for a week, bled again, and they were ok. That said I still have a weak pedal, so maybe some air is still in there somewhere 10 years later. Didn't know to only do one at a time to avoid air entrapment.
Motive bleeder is worth the money if you don't always have a helper.
Owns 19 cars and only 4 run, so keep that in mind when taking my advice.
www.neptune242.com
1981 242 Turbo |1996 850R |1980 Coupé (Project)
1971 280SEL| 1978 280Z |1937 LaSalle (Project)
neptune is offline   Reply With Quote
Old 07-07-2020, 11:42 AM   #16
petiww
petiww's Avatar
Did you replace your old brake hoses?
I have bled numerous brake systems with one helper and pedal pushing method. Never followed bleeding sequences, just go around a few times and its done. With a clear hose it is visible how bubbly the fluid that comes through, and also can be heard nicely if the environment noise is low.
My technique to avoid air going back into the caliper is pretty simple, i just ask my helper to say with simple words when does he/she actually started to push the pedal and then stopped. This way i can close the valve exactly when fluid is actually coming out.
Never had any problem with this stone age technique, every car passed with great numbers at inspection stations.
As for the master cylinder failure (during pushing it all the way in), I think if its that far done (wear or sludge buildup) then its a good time to change it anyway...
Before pouring in new fluid, i often remove the reservoir completely, wash it with hot water and throw it back in.
1980 Brown 244 GL
Old 07-07-2020, 12:50 PM   #17
If you are doing the manual bleeding process and are replacing the master cylinder. Be sure to bench bleed the master cylinder before installation. It is extremely difficult to get the air out of the master cylinder if you don't.
Old 07-09-2020, 03:37 PM   #18
ogamer777
Loading...
ogamer777's Avatar
I threw in the towel after the weirdness with the driver side rear caliper. It sure does seem like the bleeder screw is not sealing.
I got the power bleeder that was recommended, so when it isn't raining I will put it to the test.
Old 07-09-2020, 03:40 PM   #19
ogamer777
Loading...
ogamer777's Avatar
I did replace the front rubber hoses for some stainless braided hoses. I have the two replacements for the rears that go aft of the proportioning valves, too.
One thing I did forget to mention was I replace one of the hardlines that goes from the octopus (brake distribution block) to the passenger side front caliper, the aft one, with a used line. I wouldn't think that would matter but worth mentioning.
I did the same technique as you described...for close to 45 minutes...
Old 07-11-2020, 02:29 PM   #20
Lazarus
I never heard of the replace one, bleed one method. It was probably covering some other problem, and that's what we have here.
If the OP actually observes that the air bubbles move backwards toward the caliper even after the bleeder valve is closed, then he has a faulty bleeder valve OR his bleeder hose is not sealing tight enough around the valve. Obviously, the end of the bleeder hose must be immersed in brake fluid, not just hanging in the air. I used a pretty cool and simple method for years using the spare tire for "power bleeding". Then I got the cool IPD unit. Even then you might have to struggle with the master cylinder sometimes. Be sure to observe the correct bleeding order: RR, LR, RF, LF on American cars.
I have a TSB somewhere that states that problems arise if bleeding is not performed after a brake pad replacement. It claims that pushing the pistons open forces dirt into the brake lines. Just a thought.
-L
Lazarus is offline   Reply With Quote
Old 07-11-2020, 03:26 PM   #21
-L
It's common sense, once you introduce air into the system it should be purged immediately or you will suffer the consequences of it moving around within the system.
Old 07-12-2020, 02:19 AM   #22
TimS
Is the master bad? Why did you replace the calipers? I put a new master on once and spent hours trying to bleed. My wife will never help me bleed again. Turned out it was bad from the start. New master #2. Teach son how to “ pressure ,open , down, closed“ 15 minutes, done.
TimS is offline   Reply With Quote
Old 07-15-2020, 07:08 AM   #23
ogamer777
Loading...
ogamer777's Avatar
Ok so I got a solid stream of fluid out of all but the passenger rear caliper. Fluid goes through the hardline going to the caliper but evidently not through the caliper itself. What is causing that? Should I throw on new rear calipers?
Old 07-15-2020, 12:19 PM   #24
petiww
petiww's Avatar
Bleeder valve bore is going straight to the caliper halves mating surface, where the little square seal is. I think it is possible for that little bore to rust, causing no flow. Especially if there was a little air bubble inside for a long time. If this is the case and you are lucky, you can free it up with a pin (or small drillbit, but make sure to keep the edge untouched where the bleeder valve seals) with the bleeder valve removed. If not, maybe the angle bores (which go behind the pistons) are rusty too. Or there is heavy gunk buildup inside.
Old 07-15-2020, 01:00 PM   #25
ogamer777
Loading...
ogamer777's Avatar
Thanks for your advice. I’ll take the caliper off and inspect the bore.
