Old 07-09-2020, 01:21 PM   #1
Texas Old Fart
Texas Old Fart's Avatar
Default Back Brakes stuck
Thanks for all the help last time.
After waiting for parts for tune up, timing belt, seals and cam, other projects got priority. I'm now back on the 244.
After installing all the above; and the engine sounding good, I test drove it. Damn, the back brakes are sticking and that warning light is on.
I don't think I cleaned up the parking brake shoes.
Since it sat since Apr could the parking brake be sticking and cause the light to come on or is there also different problem?
Thanks for any help you can give.
-Texas Old Fart-
1987 240 DL
Texas Old Fart is offline   Reply With Quote
Old 07-09-2020, 01:24 PM   #2
2manyturbos
You have two brake lights. One is for the parking brake, the other is the hydraulic system for the 4 wheel braking system. If the light for the hydraulic system is coming on, that has absolutely nothing to do with your emergency brake.
Old 07-09-2020, 06:17 PM   #3
hessam69
Jack up the rear of the car, start the engine and select a gear. See if both wheels turn freely
If only one does, put that side back on ground and jack the opposite side to free it up if it is stuck
Old 07-09-2020, 08:34 PM   #4
Texas Old Fart
Car's up in the air. both wheels are stuck. cannot turn them at all. Light is now out. I never put on the parking brake while it was sitting. Is there other things which cause rear lock up/stuck brakes?
Old 07-10-2020, 12:38 AM   #5
smeha
Tranny Whisperer
smeha's Avatar
Brake light my story, randomly one day it started to dim on the dashboard and after a month occasionally fully light up for brief moments, breaking/slowing down/accelerating unrelated.
Took me: new rotors, new set of brake pads 2 full flushes of break fluid through all lines and bleed screws and excessive cleaning of the connection plug on the brake junction box to get rid of that occasional light popping out.
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 07-10-2020, 12:40 AM   #6
c1800
Plugged rubber brake lines, they can look good on the outside, but.....
Binding e-brake cable?
Probably need a disassembly of the rear brakes and see whats up.
Old 07-10-2020, 12:34 PM   #7
2manyturbos
Bad/torn seals on the caliper pistons allowing them to rust. I have replaced plenty of calipers over the years for this reason. All of the calipers on my 1979 242 had to be replaced. On my first test drive after getting the car running the front caliper stuck about 2 miles from home. By the time I got the car back home the rotors were glowing red. I cooled them with the hose to keep the car from catching on fire. I replaced the calipers and rotors with vented rotors before driving it again.
Old 07-10-2020, 01:14 PM   #8
kyote
Living The Dream
kyote's Avatar
Oreilly has the rear calipers available. I would replace them both and the rubber hoses if I were you. Garage miles are hard on them.
Old 07-10-2020, 04:03 PM   #9
Texas Old Fart
I replaced the rubber hoses with braided steel ones front and back from IPD.
Maybe the calipers are sticking, but before when I went through the brakes, the back right was not getting any pressure to the caliper. Replacing the hoses and pads and doing a proper bleed seemed to solve the problem.
I'll pull the pads and see if they are still stuck. I think that might tell me if it is the parking brake or calipers.
Thanks
Old 07-10-2020, 04:06 PM   #10
Texas Old Fart
Thanks I may have to replace the calipers
Also Thanks Kyote
Old 07-10-2020, 04:16 PM   #11
kyote
Living The Dream
kyote's Avatar
No Problemo!
I'll be thinking of you tearing it up at River Run ATV in Jacksonville this weekend!
Old 07-30-2020, 07:17 PM   #12
Texas Old Fart
Replaced rear calipers. Prob solved.
Thanks guys
Old 07-30-2020, 08:40 PM   #13
2manyturbos
Glad you have it back on the road.
Old 07-31-2020, 10:22 AM   #14
kyote
Living The Dream
kyote's Avatar
Great news!
