Old 07-24-2020, 09:18 PM   #26
DrZiplok
DrZiplok's Avatar
Originally Posted by VB242 View Post
I'm using the water/oil cooler off a 940T, thank you very much. I also have a crank scraper, just FYI.
Just saying; if you are pushing hard enough to need to worry about this, you will want to run a real oil cooler.
A lot cheaper than a cooked engine, or a even just a wasted track day.
DrZiplok is offline   Reply With Quote
Old 07-26-2020, 12:32 PM   #27
sbabbs
sbabbs's Avatar
Why isn't the oil to water oil cooler heat exchanger thing real enough for you? Volvo thought they where. They do have a bigger radiator in those cars.
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 07-26-2020, 10:05 PM   #28
F*ck 12
Right and I have that bigger radiator in my 242 to support it. Good enough for 6.8L John Deere turbo diesel as well.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
