Old 07-15-2020, 03:02 PM   #1
TurboDutch
Default LSD diff for reasonable price
https://racingdiffs.com/products/vol...OOrjACENuV9_Z8
Any one of you using such thing?
For dutch fb group we are currently doing groupbuy for this.
Looks and seems quite promosing!
TurboDutch is offline   Reply With Quote
Old 07-15-2020, 04:38 PM   #2
culberro
culberro's Avatar
Paging Harlard
Old 07-15-2020, 04:53 PM   #3
I put one of those in the E39 wagon. Will report back on how terrible it is, once some miles are actually driven.
Old 07-15-2020, 05:33 PM   #4
Im confused where the clutches are?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-15-2020, 05:54 PM   #5
It jams the spider gears together, brah.
Old 07-15-2020, 05:54 PM   #6
culberro
culberro's Avatar
It uses the backside of the side gears and the diff case (or thrust bushing) as the friction surface.
Not the best idea as wear may be an issue if there's a lot of slipping from a large traction differential.
It also might not be that bad, as it's similar to the way VW 020 transmissions and a the "poor mans quaife" kit work. I had one for many thousands of miles with great results.
Old 07-15-2020, 07:37 PM   #7
F*ck 12
Looks like the phantom grip I put I in my Matrix
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 07-15-2020, 08:32 PM   #8
So how's that working out for you?
Old 07-15-2020, 08:59 PM   #9
F*ck 12
You talking to me? It was great, it did it's job until I drove over something and put a hole in the transmission. When it was replaced they did not replace the phantom grip as I couldn't find the receipt for it.
Old 07-15-2020, 09:23 PM   #10
Better than nothing is good enough for me then
Old 07-16-2020, 02:21 AM   #11
TurboDutch
This one seems a bit better than Phantom grip because they have a shim between the actual diff and the spider gear.
So the wear should be a bit more spread or how to say?
I was quite happy to find these for our volvo's since the lunchbox diffs are giving people a hard time, locking when power off or unlocking on strange moments.
They seem to be more for offroading than to be a LSD against one tire fire.
So this might actually even work :D :D
Old 07-16-2020, 05:05 PM   #12
I like how it fits into the diff housing so you don't have to mess with getting a tone ring to work. Just a bit less work to install is nice.
Old 07-16-2020, 06:11 PM   #13
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Can't be worse than welding your diff, right?
Doing the wrong thing the right way.
fatcatbestcat is offline   Reply With Quote
Old 07-17-2020, 05:06 AM   #14
TurboDutch
After a private message from dl242gt I've checked with the seller and they are willing to ship to usa for same conditions as Dutch groupbuy.
So should I also start a groupbuy thread here for these diffs?
Old 07-18-2020, 02:10 AM   #15
TurboDutch
So seems like not to many people for a group buy then...
Old 07-20-2020, 11:56 AM   #16
53titan
Whats the special rate?
53titan is offline   Reply With Quote
Old 07-21-2020, 10:07 AM   #17
crogthomas
crogthomas's Avatar
Their website states that machining is required for some models. Is the Volvo one of them?
crogthomas is offline   Reply With Quote
Old 07-21-2020, 11:28 AM   #18
No machining needed: https://www.facebook.com/31066449595...8136621544780/
Old 07-21-2020, 11:55 AM   #19
esmth
seems scary to me to use the stock gears as the friction faces. I'm running a spartan lunchbox-style locker and it uses a similar locking process, except with the center pin driving two dedicated dog clutches together. (instead of the gears into the carrier.) It is a rough little bugger no doubt, but it leaves two stripes and that is what counts
1991 244 LH2.4 m46 330k? miles
Old 07-21-2020, 12:03 PM   #20
A stock diff is not worth anything. If you don't like it, take out the unit and pop a new pair of carrier gears on. Otherwise grab another axle for $100 and be on your merry way.
Old 07-21-2020, 12:59 PM   #21
TurboDutch
Special price is 190 euro!
Edit: missed out on the term "poor mans quaife" really like it!
And yes I think you could see it that way.
Old 07-22-2020, 10:38 AM   #22
TurboDutch
http://forums.turbobricks.com/showth...wpost&t=356069
Above link to groupbuy topic
Old 07-22-2020, 10:53 AM   #23
Chuck W
Chuck W's Avatar
An affordable option for a street car, perhaps?
I was looking into something to use on the 240 that is waiting to be built.
'78 264GLE
'97 854 T5 (Eventually to be 5spd)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 07-22-2020, 01:28 PM   #24
TurboDutch
I've been also looking for good options, until a friend pointed me on this. I think it will be exactly what we need!
Old 07-22-2020, 02:53 PM   #25
John V, outside agitator
Looks like its the junk sold for a couple of decades in USA as "Phantom Grip"
Its just a big stupid spring thing that jams open diff side-gears into the side of the case..
You'll wonder what phantom took your money away when the diff wears out and all grip disappears like a phantom..
Shameless that people still sell these to unsuspecting victims
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
