Old 07-16-2020, 01:19 PM   #1
142 guy
Default Aluminum trunk lids
While trying to fix a leaky trunk on my 1971 142 E, I checked to make sure that I had the correct gasket and that I had it installed correctly. Turns out the gasket is still available directly from Volvo and when looking at some of the on-line Volvo dealer sites I noticed an annotation on the product page about being suitable for use with the aluminum trunk lid. This piqued my curiosity so I did some more checking and it appears that some (all ?) of the 1975 -78 240 and 260 models had aluminum trunk lids.
I had a 1979 242 GT and the 1979 had a revised back end and I don't remember the trunk lid being aluminum. My 1987 745 T definitely had an aluminum tailgate. Looking at pictures of the 1975 - 78 240s the trunk lid appears to be very similar to the 140 trunk lid. Does anybody know whether the '75-78 240 trunk lid is a direct fit or easily fittable on the pre '73 140?
I am all about trying to reduce weight rather than extract more hp from the B20E.
Old 07-16-2020, 01:29 PM   #2
240wagonguy
All the 7/9 series wagons had aluminum tail gates. Nice n light.
Don't know about the 140/240 tho.
Old 07-16-2020, 01:32 PM   #3
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Early 240s look like pretty close... but I'm aware that in '74 Volvo switched to metric fasteners, so the hinges might not bolt on directly.
If you're that interested in shaving weight, why not just get a fiberglass trunk lid?
Doing the wrong thing the right way.
fatcatbestcat is online now   Reply With Quote
Old 07-16-2020, 01:46 PM   #4
The Librarian
140 and early 240 use the same trunk lid (part #1255079) so an aluminum one should bolt right on but it's probably going to be easier to find a fiberglass or carbon fiber one.
https://www.acm.se/category/baklucka-19
The 164 catalog shows a different part number (1203554) that's also listed in the 240 catalog but it updates to 1255079. It's probably the aluminum one.
Old 07-16-2020, 02:57 PM   #5
2manyturbos
I don't know where you got the idea most of the 75-78 240s came with an aluminum trunk lid. I've had many 240s of that vintage and have never encountered one with an aluminum lid. I'll have to check the cars I come across in the future. I wasn't aware until your post that this was an option.
Old 07-16-2020, 03:43 PM   #6
The Librarian
I'm guessing but I think the 164 lids were aluminum based on the different part number. Volvo probably used up the left over aluminum lids on the early 240's then switched over to steel which is why both numbers are shown in the 240 parts catalog.
Does anyone with a 164 or '75 240 want to take a magnet to their trunk lid? I have one that I took off a 164 but it may have been replaced 'cause it's magnetic.
Old 07-16-2020, 03:46 PM   #7
2manyturbos
I have zero experience with 164s. A friend of mine has one. I’ll have to ask him to run a magnet over his trunk lid.
Old 07-16-2020, 05:22 PM   #8
OttoB
*looks for a magnet*
Old 07-16-2020, 05:51 PM   #9
classicswede
Volvo upgrades
non of the 164's I have had or seen had a alloy boot lid
Old 07-16-2020, 05:56 PM   #10
fatcatbestcat
Professional Hack
The trunk lid on my 144 was pulled off a 164... not magnetic.
It was a '72, so maybe it's a late-model change?
EDIT: Oofers. Meant it's magnetic, not aluminum.
Old 07-16-2020, 07:42 PM   #11
142 guy
I said some (all?) 240 and 260 not most, specifically not knowing whether this was hit and miss or perhaps market sensitive. All I was going by was the reference in the Volvo application guide that listed the 240 and 260 from 75 - 78 as cars that potentially had the aluminum trunk lid.
The on-line Volvo application listing did not include the 164 as one of the cars that might have the aluminum lid so I can't comment on the part number difference question.
The possibility that the 75-78 240 might have an aluminum lid was attractive as there might be a remote possibility that I could pick up one from a salvage yard for a nice price. If I were buying fiberglass or Carbon I would want to lay eyes on them before purchase because so much of that stuff is sketchy (and heavy).
Old 07-16-2020, 08:29 PM   #12
onelow89s10
The 9xx also has an aluminum hood
onelow89s10 is offline   Reply With Quote
Old 07-16-2020, 08:45 PM   #13
gsellstr
gsellstr's Avatar
I have a trunk lid from a 77 264 on my 140, definitely NOT aluminum.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-16-2020, 09:49 PM   #14
Never heard of or seen such a thing.
Old 07-16-2020, 11:10 PM   #15
142 guy
So, it seems to be hit and miss with all misses so far. This is one of the references I found that mentions the aluminum lid on variants between '75 and '78. Different sites mention both 240 and 260 under the 'What This Fits' tab.
https://parts.volvocarsannapolis.com...1/1213755.html
The aluminum lids have an identifying sticker (Fig #38). Maybe as hiperfauto suggests it was some kind of end of production run thing (all though why list all the way until the end of 1978) or maybe there were some specific variants of the 240 and 260 that got them. It appears likely they would fit my 1971 when you look at the parts drawing as the latches and hinges appear identical, now I just have to keep an eye open for these unicorns.
Old 07-17-2020, 01:34 AM   #16
gsellstr
gsellstr's Avatar
If 71 and 74 will swap, then you should be fine, since I can confirm the 77 trunk on my 74 was a bolt on affair.
Old 07-17-2020, 02:00 AM   #17
OttoB
Was there specific (weaker) springs for aluminium lids?
Old 07-17-2020, 10:02 AM   #18
Tfrasca
Tfrasca's Avatar
The trunk on my 142 is from a 164, and like the others, it's steel.
Old 07-17-2020, 10:35 AM   #19
F*ck 12
I can't believe all you guys don't have matching numbers boot lids, think about the resale value!
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 07-17-2020, 10:42 AM   #20
This sounds like its based on some internet rumor stuff. Will not believe these existed until someone actually has one in hand.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 07-17-2020, 10:51 AM   #21
Ya just THINK about it because it'll never happen.
+1
Old 07-17-2020, 11:32 AM   #22
Dan
Watching the World burn
Dan's Avatar
I know of aluminum hoods (700s) never heard of aluminum trunk lids in my 40 years of Volvoing. They made the hoods for (heavy motor) diesel cars to save weight, not sure what reason would be to make trunk lids out of it. But they made wagon hatches out of aluminum, so dunno, following
1985 Chevy TPI V8 740.
Dan is online now   Reply With Quote
Old 07-17-2020, 03:59 PM   #23
700 900 cars got various aluminum body panel options throughout the years.
Not the 240s. I heard of aluminum flat hoods for 240s but can not confirm they actually exist.
Old 07-17-2020, 04:29 PM   #24
The Librarian
I can confirm the existence of an aluminum flat hood and trunk lid for 240. I worked on this car before it was sold and it had a polished aluminum hood and trunk lid.
https://forums.turbobricks.com/showt...num+hood+trunk
Old 07-17-2020, 04:48 PM   #25
2manyturbos
Talk about “blinded by the light”. I can’t imagine driving that thing.
