Old 07-16-2020, 10:57 PM   #1
Markos Simopoulos
Default 16v nic nacs 2.0
Hey working on getting my 16v running right, and I need to degree the cams. If any one has any info for the stock b234f cams and recommendations for overlap and what have you for an N/A engine. also I am currently running a block distributor if anyone can tell me what spark plug wires they are using. currently I am using the stock b230f wires but they are a pain in the ass to plug and unplug.
thanks
Markos Simopoulos is offline   Reply With Quote
Old 07-17-2020, 08:53 AM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
NGK HE57 plug wires (94 Honda Accord) work well with a "crab" distributor cap in a 240.
If you are getting the engine running as a baseline, I would just stick with the stock cam timing using the marks on the valve cover if you do not have the plastic timing cover.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-17-2020, 05:41 PM   #3
Markos Simopoulos
Thank you for the pictures. I have the car running now but lining up the timing marks with the valve cover is not accurate enough because the cams where to advanced, so I retarded it 5 degrees and my intermittent misfire went away. I would like to get the cams as close to stock as possible with a degree wheel and I dial indicator, it would be helpful to know some information about the cams so I can double check my work.
Old 07-17-2020, 05:47 PM   #4
Markos Simopoulos
also if anyone knows the cam bolt dimensions that would be helpful not necessary.
thanks
Old 07-17-2020, 05:49 PM   #5
oldschoolvolvo
Have you had a lot of material removed from the head? The marks on the valve cover are the same as the marks on the plastic timing cover AFAIK.
Old 07-17-2020, 08:52 PM   #6
The Librarian
Page 7 has the cam lift specs and valve timing.
https://www.volvoclub.org.uk/tech/da...1_94-Sec2a.pdf
The cam bolt is M10x50mm.
Old 07-27-2020, 12:28 PM   #7
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I timed the stock cams straight up, seemed to work the best for me
Megasquirt Tuning!
Old Today, 11:21 AM   #8
Markos Simopoulos
gold thank you so much
Old Today, 11:37 AM   #9
Markos Simopoulos
I'm not using the stock timing belt set up, I have lower compression everything's different. so the stock marks will get it to run but the cam is too advanced with my set up.
