Old 07-19-2020, 06:40 PM   #1
Drunk_Babies
Default +T checklist
Car is a 1988 240DL, LH2.2, B230F.
Here's my parts list w/ notes so far, am I missing anything? Any tips are appreciated.
Going to upgrade from my Chrysler ignition to EZK 117 using parts from a late 80s turbo 740.
Ignition/Electrical------------------------------------------------------------
Turbo EZK 117 PN 0 261 201 012
Turbo ECU
Wiring Harness
Knock Sensor
Powerstage
Turbo/Plumbing---------------------------------------------------------------
TD04HL-15g Turbo
Radiator return hose from turbo car, tees in for turbo water return
Coolant res. lower hose- tee for water feed to turbo
90+ manifold
Turbo downpipe + exhaust(eventually)
Charge piping, intake piping
Oil feed and return lines + Fittings, Drill and tap block for return
Air filter
Hose from turbo intake to PCV (How does this connect between MAF and turbo intake?)
Bypass valve vacuum hose from intake mani (Fuel pressure reg, tee in)
Intercooler + mount
Engine-------------------------------------------------------------------------
Turbo cam
Optional-
Wide band O2 sensor for AFR
Electric fan
Turbo MAF- Do I need this if using turbo ECU?
Drunk_Babies is offline   Reply With Quote
Old 07-21-2020, 01:19 AM   #2
brendon_ak
Turbo ECU
Wiring Harness
Knock Sensor
Powerstage
TD04HL-15g Turbo
90+ manifold
Air filter
Intercooler + mount
Turbo cam
Optional-
Electric fan
Seems like a pretty complete list, I think the stock MAF should get you going. I converted to 2.4 on mine and am running the stock MAF no probs
Old 07-21-2020, 01:38 AM   #3
James M
Probably colorblind
James M's Avatar
Injectors?
Hose connects to preturbo piping, (should not see boost), run it right from the breather box to the pipe between the turbo inlet and MAF
Stock Lh2.2 maf will do
Old 07-21-2020, 08:05 AM   #4
oldschoolvolvo
oldschoolvolvo's Avatar
There is no “turbo” MAF sensor.
The LH 2.2 MAF sensor is 0280212007.
But make sure you use the "turbo" ECU / EZK boxes
ECU = 0280000541
EZK = 0261201012
Also "orange top" injectors from an 850T are a drop in replacement.
Bosch 0280150785
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-22-2020, 02:48 AM   #5
mblue240
mblue240's Avatar
You'll either need to run an efan or find a turbo fan shroud. The efan is probably easier and cheaper to find.
You can also get larger injectors from me.
https://forums.turbobricks.com/showthread.php?t=301784
-Michael
Tbricks build
Yep, Michael is right.
Old 07-24-2020, 05:10 PM   #6
autoloclys
Typically the MAF switches to the passenger side, pre-turbo. you'll need to extend the stock harness or buy a whip
I think I needed a different hose for the IAC to connect to the intake hose, but maybe you can use your stock one without kinking it?
a "nice to have" is to replace the oil pressure sender with one that outputs both gauge and warning signals so you can add an oil pressure gauge, you can can Tee this off of the feed you add for the turbo or use the sender location for the sender and pull oil from behind the alternator bracket for the turbo. ive done both without issues
on my car there were some unused ports on the intake manifold that took standard barbed fittings, so i didnt need to tee off any lines for vacuum to the turbo or to a boost gauge
autoloclys is offline   Reply With Quote
Old 07-24-2020, 05:15 PM   #7
iHateVolvoPeople
For PCV, you'll use the white "tee" piece from a turbo car to replace the flame trap. Maybe not necessary but it's what I did.
From that "tee", you'll have 1 vacuum reference that goes to the intake manifold. The larger hose on the "tee" piece goes above the valve cover to the turbo inlet pipe (between AMM and compressor housing).
Grab some nipples from a junkyard car because you'll need 1-2 more. 1 for CBV control, 1 for boost reference for a gauge, etc. of course, you could tee a lot of your vacuum stuff together, but I would avoid teeing anything for CBV or wastegate control. Those deserve dedicated references.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
'04 TSX 6MT, 210k
