Old 07-21-2020, 10:07 PM   #1
adamsbees
Question volvo 16v EMS question
Hey guys,
There is a lot of information out about the physical build of a 16v/230 turbo engine, but not much publicized about the EMS setup. I am wondering if anyone here knows about the hardware (sensors modules etc) needed to do full standalone (ignition and fuel) on a 16v turbo build? Thanks in advance :)
adamsbees is offline   Reply With Quote
Old 07-22-2020, 01:18 AM   #2
Sjeng
Sjeng's Avatar
It's exactly the same as on an 8v.
Assuming speed density:
Crank trigger, coolant temp, throttle position, inlet air temperature and MAP.
You could even use a stock ignition module, and distributor/coil.
There is a megasquirt howto on here, all applies for the 16v as well.
Optional: Fan control, boost control, idle valve control.
Old 07-22-2020, 10:50 AM   #3
JohnMc
JohnMc's Avatar
Everyone seems to mix and match their setup a little differently.
I mostly used stock sensors on my first iteration, using a single coil and the LH2.4 distributor with a Saab crab-cap on it. Using an MS1 box. I think an IAT sensor was the only thing added there (and I carried this setup over largely unchanged from the previous 8V motor).
Then I went coil-on-plug and sequential injection tfor the second go around - and used a Mitsubishi crank/cam sensor on a Yoshi adapter in place of the distributor. This used an MS3X box.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-22-2020, 11:16 AM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
buzz buzz.
anyway, it's just an engine. nothing special or different about it vs other engines with respect to EMS's
Megasquirt Tuning!
Old 07-22-2020, 02:56 PM   #5
OttoB
COP is maybe the only 16V issue here. (Coil On Plug)
